felixx Posted February 11, 2012 Share Posted February 11, 2012 OK so neighbours 300zx has dot3 only on its master cylinder I have some dot4 here... is it ok to use? Quote Link to comment Share on other sites More sharing options...
Simon Posted February 11, 2012 Share Posted February 11, 2012 Yes Quote Link to comment Share on other sites More sharing options...
felixx Posted February 11, 2012 Author Share Posted February 11, 2012 thought so but thought i better check, not my car Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted February 11, 2012 Share Posted February 11, 2012 DOT4 supersedes DOT3 Quote Link to comment Share on other sites More sharing options...
morkster Posted February 11, 2012 Share Posted February 11, 2012 i've got a reservoir that says dot 3 only - i bought some castrol response dot 4 which is suitable for all dot 3 and most dot 4 fluid applications - i found dot 3 hard to find Quote Link to comment Share on other sites More sharing options...
felixx Posted February 11, 2012 Author Share Posted February 11, 2012 Well it is in now, brakes almost all bled. Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted February 11, 2012 Share Posted February 11, 2012 sweet, i try and rock 5.1 when i can Quote Link to comment Share on other sites More sharing options...
felixx Posted February 11, 2012 Author Share Posted February 11, 2012 hehe thats the flash stuff, isnt it different colours so you know that you have flushed it all out? Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted February 11, 2012 Share Posted February 11, 2012 yea sometimes, its supposed to be impossible to boil Quote Link to comment Share on other sites More sharing options...
felixx Posted February 11, 2012 Author Share Posted February 11, 2012 Amazing! So no brake fade? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted February 11, 2012 Share Posted February 11, 2012 Pads can still overheat and make things weird Quote Link to comment Share on other sites More sharing options...
Hemi Posted February 11, 2012 Share Posted February 11, 2012 as far as im aware 5.1 is also silicone based as opposed to a glycol-ether dot3-4 fluids .pretty sure that makes in non hydroscopic (wont absorb water over time). Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted February 11, 2012 Share Posted February 11, 2012 Nah, Dot 5 is silicon based, 5.1 is the standard mineral stuff. If you mix the two they turn to jelly Super Dot 4 can equal a Dot 5.1 as well, not all Dot 5.1 fluid is the same. Quote Link to comment Share on other sites More sharing options...
Yammies Posted February 16, 2012 Share Posted February 16, 2012 dot 3 is the best fluid to use, but absorbs water like a motherfucker. DOT4 is the compromise and is also what most manufacturers use as it extends the brake fluid life as it doesn't absorb water as readily. In saying that, there is no reason you can't put DOT4 into a system that previously had DOT3. Any improvement will be due to a deteriorated fluid, and I would imagine that the majority of people wouldn't see/feel the differeence Quote Link to comment Share on other sites More sharing options...
DavidTheCreator Posted February 16, 2012 Share Posted February 16, 2012 why is dot 3 the best? Quote Link to comment Share on other sites More sharing options...
keltik Posted February 16, 2012 Share Posted February 16, 2012 Have used 4 and 5.1 in my wagon. 5.1 was an improvement over the normal 4 i was using, but still boiled on Taupo before my pads gave out. Switched to Motul RBF660 dot 4 and it seems to equal or better the 5.1 performance. I think on paper its actually superior. Either way, around manfeild i set my best lap times using it and made my brake rotors explode before i got serious fade. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 16, 2012 Share Posted February 16, 2012 Note for young players - you can't mix 3 or 4 with 5 5 is silcone based (repels water) 3 and 4 is glycol based (attracts water) Quote Link to comment Share on other sites More sharing options...
xsspeed Posted February 16, 2012 Share Posted February 16, 2012 and 5.1 is? also glycol? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted February 16, 2012 Share Posted February 16, 2012 tis silicone.. Quote Link to comment Share on other sites More sharing options...
keltik Posted February 16, 2012 Share Posted February 16, 2012 tis silicone.. 5 is the silicone one. 5.1 goes back to glycol. As covered further up the page Quote Link to comment Share on other sites More sharing options...
