Brennan's, ke70 Corolla, 3sge Beams powered.
Brennan
Can't be a vacuum leak, surely?
Spray some stuff at the inlet manifold while it's running and see if it changes anything.
Otherwise it could be something like a sticky valve? I've seen it happen on some engines (just happened on a friends 1mz) - the valves get stuck in the guides after sitting for to long. Check the clearances to work that out.
  • Replies 322
My car's probably a little heavier than this, and I went 3.5kgmm in the back and it's perfect.
That's coming from springs which were previously... way way too hard, way too hard, too hard, then 3.5kg.
I'd rather see this thing raised a bit and doorting around some back roads than barely scraping along the highway without fear of killing yourself.
It's not too much of a drama about the PCV - because if you look at the size of the hole in the valve, it's effing tiny... And it's got a valve in there to stop it from sucking too much air through. It also makes your engine a bit healthier by sucking out the crappy fumes etc while you are idling. So it's not a bad thing, just cunty to try and fit in some how.
You could probably get away with plumbing it into just one or two of your throttles perhaps. Easy way to get a rugged sounding idle hahaha.
Unless of course he's also saying that you need the other crankcase vent line connected to the intake too, in which case... aaahhh... yeah.
Dunno how that would work.
It's pretty awesome how much you've managed to get done on this car in this time frame, A++ would read thread again.
