Ollie B Posted June 15, 2019 Share Posted June 15, 2019 What engine mounts did you use man? Quote Link to comment Share on other sites More sharing options...
Brennan Posted August 25, 2019 Author Share Posted August 25, 2019 On 15/06/2019 at 13:49, Ollie B said: What engine mounts did you use man? Hey Ollie. Sorry about the late reply. Don’t come on here too often anymore. Was the altezza rubber mounts. And x2 “n” shape mild steel welded to the cross member with a. Hole drilled in the top to accept the rubber mount. And enough room beneath for a spanner and a nut. Quote Link to comment Share on other sites More sharing options...
CrazyCraig Posted April 12, 2022 Share Posted April 12, 2022 Hi Brennan, sick DX build mate, I have one too with a 3SGE that was a rally car, so I’m looking to put in coil overs in more suitable for circuit and fit sway bars. What brand coil overs did you use? Did you do sway bars as the OEM one hits the 3SGE sump…??? cheers from Craig Quote Link to comment Share on other sites More sharing options...
