Brennan Posted November 14, 2012 Author Share Posted November 14, 2012 Yea I really like those. Don't like the idea of expensive imported wheels tho. I do have some big plans for future wheels though. Top secret wheels Quote Link to comment Share on other sites More sharing options...
Truenotch Posted December 24, 2012 Share Posted December 24, 2012 What price are you selling the adapters for on trademe? I know a guy who was considering one (from Te Aroha) and I reckon you should be able to sell heaps of them... These engines are the new 4AGE. Quote Link to comment Share on other sites More sharing options...
Brennan Posted December 24, 2012 Author Share Posted December 24, 2012 Sold a couple $250-260 to try cover pattern costs. ONO on here. Quote Link to comment Share on other sites More sharing options...
corey_jorg Posted January 5, 2013 Share Posted January 5, 2013 hey, off topic but can you remember how wide the mx5 subframe was? thinking about doing the conversion to a dx. cheers corey. Quote Link to comment Share on other sites More sharing options...
Brennan Posted January 5, 2013 Author Share Posted January 5, 2013 about 1500mm wide. 90mm wider than a ke70. Ive seen s13 done before into an ae86 which looked like it worked alright. otherwise if i was to attempt it again i would go with a altezza rear, because they are so cheap, easy to find, have great lsd options and are good ratios. And simply shorten the driveshafts and control arms or make some new ones. Problem would be if you wanted to run small wheels and the brakes may be to big. Quote Link to comment Share on other sites More sharing options...
corey_jorg Posted January 6, 2013 Share Posted January 6, 2013 but is the altezza irs setup as straight forward as the mx5? nice and square. the silvia setup look like it would be a mish but mx5 would be easier. im not worried about width as will be running some 13x10s with huge dish and wana run boso style guards to get some looks. will do abit more googling. cheers. Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted January 26, 2013 Share Posted January 26, 2013 What the hell, you cast your own rotors??? Quote Link to comment Share on other sites More sharing options...
Brennan Posted January 26, 2013 Author Share Posted January 26, 2013 yea, the ones i brought had to many holes. So when i converted them from 5 stud to 4 stud. it wasn't a very nice fit. Quote Link to comment Share on other sites More sharing options...
Dell'orto Posted January 26, 2013 Share Posted January 26, 2013 Dedication! Quote Link to comment Share on other sites More sharing options...
Guest pluk Posted April 16, 2013 Share Posted April 16, 2013 hi, nice project............ could you tell me which ecu is using to remove the AFM. thanks pluk Quote Link to comment Share on other sites More sharing options...
Guest Brennan Posted April 18, 2013 Share Posted April 18, 2013 Yea. A link g4 ecu. Made here in New Zealand. Quote Link to comment Share on other sites More sharing options...
Guest Nominal Posted April 24, 2013 Share Posted April 24, 2013 Old-school Mini's and Morris Minors had a basic sheetmetal box type heater with fan. No fresh air intake though, and would probably need recored. In my experience most 'modern' heater units are ugly plastic things that are hard to adapt. Could use the core from one, and make a steel box for it though. I cut up a NOS Morris 1100 heater to use for my project. This is the basic one I'm thinking of: Quote Link to comment Share on other sites More sharing options...
Guest flyingbrick Posted April 24, 2013 Share Posted April 24, 2013 Hey man. The heater core does not need to be a heater core! You can use any radiator or oil cooler ( use anti corrosion stuff in ur water if its a steel core) Those extruded aluminum round finned oil coolers would be ideal! Mounted in a PVC pipe with air blowing past!! For fans you have many many options- just depends on how much blow you want. Quote Link to comment Share on other sites More sharing options...
Brennan Posted May 11, 2013 Author Share Posted May 11, 2013 Cheers guys. pretty sweet idea to use a small oil cooler as a a core, will have to remember that for future projects Quote Link to comment Share on other sites More sharing options...
BDA780 Posted May 24, 2013 Share Posted May 24, 2013 Amazing work! Super cool that you cast your own brake rotors. Ā A friend is building a new rally car for the new Extreme rules and is using one of the Demon Tweeks heaters. They are tiny and appear to be converted radiator cores from Computer cooling systems with a computer fan. Ā Keep up the sweet work, Quote Link to comment Share on other sites More sharing options...
Brennan Posted May 25, 2013 Author Share Posted May 25, 2013 Mmmm very interesting. just looked up water cooled computer radiators, and they look pretty sweet. might have to use next time. Quote Link to comment Share on other sites More sharing options...
coldturkey Posted June 6, 2013 Share Posted June 6, 2013 Where did you get them sexy little numbers from? (the coilovers) Quote Link to comment Share on other sites More sharing options...
Brennan Posted June 6, 2013 Author Share Posted June 6, 2013 poweredbymax.net They have a NZ distributor through the same site. Quote Link to comment Share on other sites More sharing options...
J-Calico Posted June 9, 2013 Share Posted June 9, 2013 swweeet man do mine now? heheĀ Quote Link to comment Share on other sites More sharing options...
Brennan Posted June 9, 2013 Author Share Posted June 9, 2013 pretty keen to have a look at your bc's to see how they compare to the max front setup.see which can go lower etc. Quote Link to comment Share on other sites More sharing options...
