Truenotch Posted July 14, 2013 Share Posted July 14, 2013 You can have a copy of my tune if you want. The main advantage is in the VVTi map. 1 Quote Link to comment Share on other sites More sharing options...
Brennan Posted July 14, 2013 Author Share Posted July 14, 2013 If its no problem for you to get off, it may help No rush anyway, will be a month or so before tuning yet. 1 Quote Link to comment Share on other sites More sharing options...
Truenotch Posted July 15, 2013 Share Posted July 15, 2013 Yeah man, it's easy enough to get the file off and email it down. Colby Resonator? ? I'm not a huge fan of how the Flowmaster copy sounds on my 86, it's a bit tinny/raspy. IMO a decent straight through muffler and a resonator should be enough. Something like this: Quote Link to comment Share on other sites More sharing options...
Mitch.W Posted July 15, 2013 Share Posted July 15, 2013 was it worth the wait to get the parts max in the rear end now? lol stainless straight pipe nothing lol quite is no fun at all! Quote Link to comment Share on other sites More sharing options...
Brennan Posted July 15, 2013 Author Share Posted July 15, 2013 Yip Mainland is branching out into resonators, haha. Has to be quiet. was no fun with the last noisy ke70. received far to much attention. Do you know what flowmaster exhaust you have a copy of? I was looking at a 50 series, or a 60 series, if Pro Parts stock them. there Pricing is pretty sharp, compared to getting it from Summit. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted July 15, 2013 Share Posted July 15, 2013 I have a 50 series Flowmaster that I want to sell. It's 3" but I have 2.5" reducers to go with it if you like. Owes me over $150 so would take offers around that if you are keen. Quote Link to comment Share on other sites More sharing options...
Brennan Posted July 15, 2013 Author Share Posted July 15, 2013 Very tempting! Will see if pro parts can do a 60 series or a super 50 and get back to you. 1 Quote Link to comment Share on other sites More sharing options...
Truenotch Posted July 15, 2013 Share Posted July 15, 2013 No idea, but it looks like this: Quote Link to comment Share on other sites More sharing options...
NicT Posted July 19, 2013 Share Posted July 19, 2013 No idea, but it looks like this: I dont like chase parts, they are overpriced for everything flanges/mufflers/pipe. Autobend and Tube Bending NZ ltd are my new favourite places to shop. I like the idea of a silent car. If there is minimal power loss, whats the disadvantage of having a silent weapon? If only they could make silent skidding tires, then you could have a ninja manji car. 2 Quote Link to comment Share on other sites More sharing options...
Brennan Posted July 19, 2013 Author Share Posted July 19, 2013 thats the plan, the 3sge should have more than enough power for me anyhow, so the power lost from a quiet exhaust shouldn't be a problem. Quote Link to comment Share on other sites More sharing options...
Truenotch Posted July 20, 2013 Share Posted July 20, 2013 Mine cost $100 Nic, so they're not exactly expensive. I've got no idea whether it actually came from chase, doubt it by the sounds of your comment. But yeah, average muffler that's going to be replaced by something else. Quote Link to comment Share on other sites More sharing options...
Brennan Posted July 27, 2013 Author Share Posted July 27, 2013 What would you recommend to do with/about the PCV valve? I do have a ventilated catch can there to use. Should i remove the valve? I noticed on yours, @truenotch, that you had two right angles on top. did you block off the side hole where the valve was? Quote Link to comment Share on other sites More sharing options...
ketodriftke70wagon Posted August 15, 2013 Share Posted August 15, 2013 this is awesoommmmmmmme!! keep the good work coming! Quote Link to comment Share on other sites More sharing options...
Truenotch Posted August 16, 2013 Share Posted August 16, 2013 The cam cover I used had two rubber grommets for factory breathers / PCV valves. I've replaced them with 90° steel fittings from some form of water pipe. They're just jammed in there and clamped on with a steel bracket: Quote Link to comment Share on other sites More sharing options...
Brennan Posted August 17, 2013 Author Share Posted August 17, 2013 Ok, So it didnt look like this then I think im going to try find a U bend to come out of the throttle side, then from there copy you. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted August 17, 2013 Share Posted August 17, 2013 If you want it to be full sick I could weld some threaded fittings on the top to take a proper braided hose fitting. And weld up the unused hole on the manifold side. Cars lookn mint too man 1 Quote Link to comment Share on other sites More sharing options...
crooked Posted August 17, 2013 Share Posted August 17, 2013 Currently working on getting a 3sge into my corona, super nice build thread and ke70. Just a question, I'm going to strengthen my shock mounts and fit something similar to your coilovers in the rear. Is it best to have them sitting upwards like that? Correct the huge angle the factory shocks have? Quote Link to comment Share on other sites More sharing options...
Truenotch Posted August 25, 2013 Share Posted August 25, 2013 Ok, So it didnt look like this then I think im going to try find a U bend to come out of the throttle side, then from there copy you. Mine had the PCV where the round blank is on the top of your rocker cover. I just jammed in a spare 90° fitting from another cover and turned them to my preferred direction. You could easily block off that PCV hole and just drill a hole for another 90° fitting - they're just an interference fit. Question: Did you make new hanger mounts to keep the 2-piece driveshaft? Looks good! I'd like to go 2-piece and will have to do the same. Quote Link to comment Share on other sites More sharing options...
Brennan Posted August 25, 2013 Author Share Posted August 25, 2013 @crooked my rear coilovers still have as much angle as we could get on them, with the caliper in the way. They should be close to the same angle as factory. @eke_zetec that sounds like far to much work to me haha and braided is far to fancy. Quote Link to comment Share on other sites More sharing options...
Brennan Posted August 25, 2013 Author Share Posted August 25, 2013 Ok, I started on a u bend yesterday to come out of the side and up over the top. On two piece Drive Shaft, yea we mounted the bearing in the middle with a little bracket on each side. Altezza two piece shafts are <$100 from ToyoTas Nissin Parts world. When are you down next? so i can grab that basemap? Getting close to needing a tune Quote Link to comment Share on other sites More sharing options...
