Kiwibirdman Posted September 7, 2015 Share Posted September 7, 2015 What kind of strange things? Surging and cutting out turning right on trailing throttle. The cheap and nasty stock replacement fuel pump on my Camaro put out just under 7psi. Regulated the pressure down to the book level of 5.5 from memory and all was sweetness and light. I don't mind admitting that one took a while to find because no one would believe that the pump did that much pressure. The other thing to check is the float level, not always set right from teh factory. I'm on my 3rd one of these carbies and they all needed adjustment. An electric fuel pump is a good idea for a car that sits round a lot, the Firebird always takes a while to fire up when its been left for more than a week. Daily drivers not such a problem. 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 7, 2015 Author Share Posted September 7, 2015 Cheers for that.Quick question you may know the answer to. Why does it have 2 mounting holes per corner of the carb.I presumed one is for square bore and one for spread bore but all the guff I am reading tonight indicates I'll need an adapter to run this carb (cos it has a squarebore mounting) on a spreadbore manifold. 1 Quote Link to comment Share on other sites More sharing options...
Kiwibirdman Posted September 7, 2015 Share Posted September 7, 2015 You are right, the 2 sets of holes are to allow bolting up to either type of intake. You will need the adapter to run on a spreadbore manifold. I have always used a paper gasket with gasket sealer between the adapter and manifold. Every time I didn't there was an air leak. Â 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 7, 2015 Author Share Posted September 7, 2015 Cool - I'm totally down with buying an adapter for the EP but it mystifies me why the EP comes with 2 sets of holes if you are going to need an adapter anyway. All the adapters I have seen adapt the bolt pattern so having them on the carb is pointless?. Â (sound like a rookie as comment but this is the first time I have needed to run an adapter as I have always had matched carb and manifold types) Â Only thing I can think of is some unusual adapter that requires a very long set of studs running right through the carb and adapter as one piece. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted September 7, 2015 Share Posted September 7, 2015 Giz Q jet plz 1 Quote Link to comment Share on other sites More sharing options...
Spencer Posted September 7, 2015 Share Posted September 7, 2015 It's a Holden Q-jet also? They are the good cores to have usually. 1 Quote Link to comment Share on other sites More sharing options...
dr.wylde Posted September 8, 2015 Share Posted September 8, 2015 My Q-jet does that anyway. If I don't drive it for a week I have to crank it for 15-20 seconds to fire it up. So I'm used to it. LOL Â Â same here. wind over for 20 secs waiting for the gas. then boom! Â Â 1 Quote Link to comment Share on other sites More sharing options...
73crownwagon Posted September 16, 2015 Share Posted September 16, 2015 Good job man! Mine seems to be running sweet. been dailying all week very cool carb Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted September 16, 2015 Share Posted September 16, 2015 We getting one very very soon after I've sold Rezs scooter 1 Quote Link to comment Share on other sites More sharing options...
yetchh Posted September 16, 2015 Share Posted September 16, 2015 Had a fair few problems with my performer(850, waaay too big and the bowls seem very small).. in the end I bought a demon Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 16, 2015 Author Share Posted September 16, 2015 An 850? on what size motor? Quote Link to comment Share on other sites More sharing options...
yetchh Posted September 16, 2015 Share Posted September 16, 2015 351.. it came with it, ran ok but would run out of gas at wot.. also had some weird stumble whilst being stalled.. had a few guys look at it to no avail.. so I changed it.. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 16, 2015 Author Share Posted September 16, 2015 351.. it came with it, ran ok but would run out of gas at wot.. also had some weird stumble whilst being stalled.. had a few guys look at it to no avail.. so I changed it.. 351 with an 850 - theres ya problem there. Unless you were pulling 8000 rpm. 1 Quote Link to comment Share on other sites More sharing options...
yetchh Posted September 16, 2015 Share Posted September 16, 2015 It started great tho.. 1 Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted November 11, 2015 Share Posted November 11, 2015 che!  sweet scooter! sweet motor! 1 Quote Link to comment Share on other sites More sharing options...
Shakotom Posted November 11, 2015 Share Posted November 11, 2015 Sweet scooter Giz Quote Link to comment Share on other sites More sharing options...
dr.wylde Posted November 12, 2015 Share Posted November 12, 2015 mmmmm roller cam  Whats your plan from here, slot in a new cam? rebuild?  Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 12, 2015 Author Share Posted November 12, 2015 Just assessing options at the moment. Â Going to pull the heads anyway and take a look at the bores, then take a geeze at the bearings and see if I should rebuild or just haul ass. Â I know how lazy I am and I should really do it right the first time and rebuild the motor but $$$ may not allow that. Will wait till I get the pants off and look at it. Quote Link to comment Share on other sites More sharing options...
Threeonthetree Posted November 12, 2015 Share Posted November 12, 2015 Take your time to perfect the beat And you'll still have love for the streets, it's the 304.. Do it once, do it right. Even if it takes a few weeks/months to accrue enough funds to do so. 1 Quote Link to comment Share on other sites More sharing options...
KKtrips Posted November 12, 2015 Author Share Posted November 12, 2015 If I do what I want to do its probably a year to do. Of course you are right though. Quote Link to comment Share on other sites More sharing options...
