My name is Russell Posted June 22, 2009 Share Posted June 22, 2009 What brake settups have people used? From gloogling oldschool iv found the following mentioned; ae92 callipers and s13 disks s14 calipers s15 rear calipers with u13 bluebird discs ae92 & s13 rotor ae92 fx-gt u12 bluebird type with EBC pads s4 rx7 m/ga70 supra calipers JZA70 Supra 180sx callipers http://www.trademe.co.nz/Browse/Listing ... =224807059 Are 180sx callipers handbrakes cable or hydraulicly operated? Iv been offered some RWD 5x114.3 hilux disks for $50 which are the same studd paturn as i'm running so should i grab them for starters, which would mean i dont need to re drill disks, or is it likely the disks will be to thick for the calipers i go with? Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted June 22, 2009 Share Posted June 22, 2009 PM OSC, he has recently done a hilux rear end into a mk2 escort using AE101 or 111 disks. I'm sure theres a few people on here who have done the conversions. Quote Link to comment Share on other sites More sharing options...
BobbyBreeze Posted June 22, 2009 Share Posted June 22, 2009 You need to get the disk with the right offset - so i'd make sure the ones you are looking at will fit with your intended calipers. AFAIK all handbrakes have to be cable operated. I don't think you can have hydraulic ones on a road car even with a separate system. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted June 22, 2009 Share Posted June 22, 2009 Have a look on toymods, lots of guys using hilux diffs in little KE corollas and Celicas etc. Lots of detail, believe *A70 supra calipers are the common conversion Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 22, 2009 Share Posted June 22, 2009 I wouldnt use A70 caliper, means you have to run internal drum hand brake. While it will be a better performing handbrake Its not worth setting it up. So use a calliper with a handbrake mechanisim, Ive built one setup with a friend using ae92 rear callipers and s13 disks worked out well calliper bracket was flat and easy to make Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 22, 2009 Author Share Posted June 22, 2009 I wouldn't use A70 caliper, means you have to run internal drum hand brake. While it will be a better performing handbrake Its not worth setting it up. So use a caliper with a handbrake mechanism, Ive built one setup with a friend using ae92 rear calipers and s13 disks worked out well caliper bracket was flat and easy to make Ok sweet thats exactly the type of info i needed. s13 are 5 stud, so easy to re stud = good and there should be some ae92's at pick a part = Good (i know nothing about these cars is it a common a Toyota corolla?) Just ordered some U bolts so i can get her back to a role n body for when the daily breeds emergency work. Cheers boes Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 22, 2009 Share Posted June 22, 2009 I think these are A32 cefiro brakes. (NOT MINE) Quote Link to comment Share on other sites More sharing options...
kpr Posted June 22, 2009 Share Posted June 22, 2009 am running ae92 s13 combo as well. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 22, 2009 Author Share Posted June 22, 2009 s13 disks Were the s13 disks front or rear disks Spencer? Quote Link to comment Share on other sites More sharing options...
kpr Posted June 22, 2009 Share Posted June 22, 2009 rear, 9mm thick. same thickness as ae92 ones Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 22, 2009 Author Share Posted June 22, 2009 rear, 9mm thick. same thickness as ae92 ones Sweet cheers mate will have to keep an eye out for some. May have to buy them new as i cant see them turning up at pick a part. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 22, 2009 Author Share Posted June 22, 2009 Cheers for picture How does the nut on the stud that holds the caliper on get tightened, wouldn't it hit the disk? Quote Link to comment Share on other sites More sharing options...
kpr Posted June 22, 2009 Share Posted June 22, 2009 guessing a normal bolt is spose to go in there and caliper has thread in it. yeh the s13 rotors were pretty cheap new from memory. Quote Link to comment Share on other sites More sharing options...
Mick Doohan Posted June 22, 2009 Share Posted June 22, 2009 i used sw20 rear callipers and vented landcrusier disc's on mine .. it is 6 stud though Quote Link to comment Share on other sites More sharing options...
RUNAMUCK Posted June 22, 2009 Share Posted June 22, 2009 How does the nut on the stud that holds the caliper on get tightened, wouldn't it hit the disk? I think that stud was just put there to mock it up for the purposes of taking that photo. Quote Link to comment Share on other sites More sharing options...
Spencer Posted June 22, 2009 Share Posted June 22, 2009 ae92 is a corolla fxgt dude or a levin tureno equivilent has to be a 4age one or it most likely wont have disks at the back.. Has easy handbrake cables to setup Quote Link to comment Share on other sites More sharing options...
Gaz Posted June 22, 2009 Share Posted June 22, 2009 Isnt s13 silvia 4stud? 4x100? If it was 5stud however it would be the right pattern for what you want I think... 5x114.3 . So if it is 5speed then Id tend to go for the S13 discs. Are the K's even 5stud? Gaz Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 22, 2009 Author Share Posted June 22, 2009 ae92 is a corolla fxgt dude or a levin tureno equivilent has to be a 4age one or it most likely wont have disks at the back.. Has easy handbrake cables to setup Sweet cheers dude, showing my lack of cars knowledge Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted June 22, 2009 Author Share Posted June 22, 2009 Isnt s13 silvia 4stud? 4x100?If it was 5stud however it would be the right pattern for what you want I think... 5x114.3 . So if it is 5speed then Id tend to go for the S13 discs. Are the K's even 5stud? Gaz Haha dono i gloogled s13 wheels and 5 stud mags came up Arrr were is that stud pattern thread when you need it Quote Link to comment Share on other sites More sharing options...
Raizer Posted June 22, 2009 Share Posted June 22, 2009 Isnt s13 silvia 4stud? 4x100? 114 Quote Link to comment Share on other sites More sharing options...
