kyteler Posted June 22, 2009 Share Posted June 22, 2009 As Raizer says, S13 Silvia is 4x114.3 but people rock the 5stud conversion on them all the time and use the M-Spec 4pot brakes from the Turbo Skylines etc. Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted June 22, 2009 Share Posted June 22, 2009 whatever discs you run you'll have to remove bearing to get old backing plate off (or cut with grinder) and also get outter edge of drive flange machined down on lath to sit nicely inside new disc im gonna be doing the s13disc and ae92 calliper to mine soon, did some rough measureing wen i got the setup and i think if you got a plate cut from 16mm? steel it would all line up pretty easy, i think the s14 are 5 stud so have a look at there disc's? Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 3, 2009 Author Share Posted July 3, 2009 ae92 is a corolla fxgt dude or a levin tureno equivilent has to be a 4age one or it most likely wont have disks at the back.. Has easy handbrake cables to setup This what i need spencer? http://www.trademe.co.nz/Browse/Listing ... =226789771 Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted July 3, 2009 Share Posted July 3, 2009 EB falcon rear disks and calipers are a good option the inside of the disk fits over the axle flange and the off-set of the disk and calipers is perfect. Mounting bracket for the calipers is simple to make similar to that orange diff. Falcon disks are 5x114 as well to which is handy if you don't wana re-stud cause that can be costly. Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 3, 2009 Author Share Posted July 3, 2009 Oh really that sounds like a good option also could be one of them at pick a part What year falcon would i find them in etc? Quote Link to comment Share on other sites More sharing options...
Ke36 Posted July 3, 2009 Share Posted July 3, 2009 ive got s14/15 non turbo rears on mine with bluebird discs Quote Link to comment Share on other sites More sharing options...
Burntrubber Posted July 3, 2009 Share Posted July 3, 2009 EA may be the same 89 to 93 or 94 I think. Quote Link to comment Share on other sites More sharing options...
kpr Posted July 3, 2009 Share Posted July 3, 2009 ae92 is a corolla fxgt dude or a levin tureno equivilent has to be a 4age one or it most likely wont have disks at the back.. Has easy handbrake cables to setup This what i need spencer? http://www.trademe.co.nz/Browse/Listing ... =226789771 yeh, dont pay that much for them tho. should be able to pick up some for half that price Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 20, 2009 Author Share Posted July 20, 2009 Ok just picked up some ae92 fx-gt calipers Who has some pictures of theres setup? What cables etc did you guys use? Whats a reasonable price for some 5 studd s14 disks? Iv found these for $100, but should i be able to find some cheaper? Or is that reasonable? http://www.trademe.co.nz/Trade-Me-Motor ... 947770.htm Quote Link to comment Share on other sites More sharing options...
Gaz Posted July 20, 2009 Share Posted July 20, 2009 I would look into new price before you buy any for $100. I think I will do the exact conversion but using the s13 4x113.4 disc. Also Aiden should be able to spin up the axle in UJ's lathe if the bed is long enough. Gaz Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 20, 2009 Author Share Posted July 20, 2009 I would look into new price before you buy any for $100.I think I will do the exact conversion but using the s13 4x113.4 disc. Also Aiden should be able to spin up the axle in UJ's lathe if the bed is long enough. Gaz I didn't think i needed to turn anything on my axles because mine has the smaller 5 stud center? / the mags fit over them fine. will see i guess. The calipers are mint a good size for rear brakes IMO. Just need to get my head around how to do the linkages Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted July 21, 2009 Share Posted July 21, 2009 its not normally the center or (spigot) that needs maching down its the outter surface around the studs because the new disc is now gonna slot over top of studs insted of bolting from behind.... IMO sechond hand disc's are worth about $40-50, price up some new ones, they might only be $130 or so, maybe even some slotted ones if you wanna get fancy Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted July 21, 2009 Author Share Posted July 21, 2009 Oh ok will have to have a look. My grinder makes go fast slots Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted July 21, 2009 Share Posted July 21, 2009 also alot of the time you end up havin to machine up a spacer for the spigot because the disc center is usally bigger, i think you need this for cert, and if your wheels dont align on the spigot yet its a good time to machine up a spacer that does both cause most cert guys want the wheels hubcentric Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted August 5, 2009 Author Share Posted August 5, 2009 Ow k, I now have the fxgt calipers and S14 disks Does anyone have a CAD file or similar for getting the bracket cut for the caliper to mount to diff, and what thickness steel did you guys use? Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted August 5, 2009 Share Posted August 5, 2009 if you send me a mint pic with a 1=1 scale i cud cut em out mint, i wud use 10mm if you hav to thread it Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted August 5, 2009 Author Share Posted August 5, 2009 if you send me a mint pic with a 1=1 scale i cud cut em out mint, i wud use 10mm if you hav to thread it GC I was more asking about thickness to get the correct offset, doesn't need thread tap ... i don't think. Hmmm need a copy or AutoCAD to draw it up. taking a 1:1 pic sounds difficult. I already have a template to use for gazas mount that is the same to the housing so can copy that just need to draw something up for caliper part. Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted August 5, 2009 Share Posted August 5, 2009 bro i mean draw it on a bit of paper 1=1 Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted August 5, 2009 Author Share Posted August 5, 2009 bro i mean draw it on a bit of paper 1=1 Well that would be allot easier than taking a picture one to one wouldn't it haaaaaaaahaaaaaa! Will draw on auto cad, do a print to scale and stick on cardboard to test then get a nigger to hook a brother up / request two one for gaz also and anyone else who wants some? What year Autocad does your CNC run off? will save it as what ever year you require as works is now spanking 2010. Chur bow Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted August 5, 2009 Share Posted August 5, 2009 bro i mean draw it on a bit of paper 1=1 Well that would be allot easier than taking a picture one to one wouldn't it haaaaaaaahaaaaaa! Will draw on auto cad, do a print to scale and stick on cardboard to test then get a nigger to hook a brother up / request two one for gaz also and anyone else who wants some? What year Autocad does your CNC run off? will save it as what ever year you require as works is now spanking 2010. Chur bow my auto cad runs off the ink of a pen. you draw a pic and it cuts that shit. magic eye. Quote Link to comment Share on other sites More sharing options...
