tortron 64,058 Posted May 31, 2020 Report Share Posted May 31, 2020 Thermostat measured at fully open temp not start to open temp Quote Link to post Share on other sites
sheepers 20,824 Posted May 31, 2020 Report Share Posted May 31, 2020 yea, na. none of the thermostats ive tested are even beginning to open at their stated temps. they all seem to be just cracking a few degrees above the stated temp. 1 Quote Link to post Share on other sites
Mof 13,338 Posted May 31, 2020 Report Share Posted May 31, 2020 Has the coolant level dropped at all? Quote Link to post Share on other sites
sheepers 20,824 Posted May 31, 2020 Report Share Posted May 31, 2020 Na, it's pretty good and the recovery system seems to be working fine 1 Quote Link to post Share on other sites
Mof 13,338 Posted May 31, 2020 Report Share Posted May 31, 2020 So maybe not an airlock problem, it should've worked it's way out to the cap or reservoir by now if it was do you think Quote Link to post Share on other sites
JoKer 18,589 Posted May 31, 2020 Report Share Posted May 31, 2020 is.. (I should click a few pages back) it actually hot? Ie to the touch, or visiulay? maybe ignore the meter / sensor? and roll as is Quote Link to post Share on other sites
Mof 13,338 Posted May 31, 2020 Report Share Posted May 31, 2020 Just now, JoKer said: is.. (I should click a few pages back) it actually hot? Ie to the touch, or visiulay? maybe ignore the meter / sensor? and roll as is Remember though, it shows normal temp when driving. 1 Quote Link to post Share on other sites
sheepers 20,824 Posted May 31, 2020 Report Share Posted May 31, 2020 And as ive said many times it's got two temp gauges and they both correlate. 1 Quote Link to post Share on other sites
Nominal 56,462 Posted May 31, 2020 Report Share Posted May 31, 2020 Have you considered a 2ZZ? 1 2 Quote Link to post Share on other sites
yetchh 6,268 Posted June 1, 2020 Report Share Posted June 1, 2020 Fuck yeah.. Progress. Was totally looking forward to you taking me for a drive in this at nats.. Next time hopefully... Definitely 2 Quote Link to post Share on other sites
tortron 64,058 Posted June 1, 2020 Report Share Posted June 1, 2020 Been watching a bunch of engines getting built in YouTube. One guy had his water jackets half full of goo from what was probably old stop leak. Another had issues with a newish engine always running warm, full of casting sand still Both discovered after knocking out the Welsh plugs and highpressuring it out. Probably you hottanked your block or whatever tho Quote Link to post Share on other sites
Yowzer 33,853 Posted June 21, 2020 Report Share Posted June 21, 2020 That sounds glorious 1 Quote Link to post Share on other sites
sheepers 20,824 Posted June 21, 2020 Report Share Posted June 21, 2020 sounds pretty ace when your driving it too. 2 Quote Link to post Share on other sites
kyteler 60,493 Posted June 21, 2020 Report Share Posted June 21, 2020 Must have been a relief to find the timing issue. Good shit. 1 Quote Link to post Share on other sites
Yowzer 33,853 Posted June 21, 2020 Report Share Posted June 21, 2020 Better do a skid just to confirm though 1 Quote Link to post Share on other sites
Popular Post sheepers 20,824 Posted June 21, 2020 Popular Post Report Share Posted June 21, 2020 fuck man, i did like a million skids on the way home from the dyno. 12 2 2 Quote Link to post Share on other sites
mjrstar 2,868 Posted June 21, 2020 Report Share Posted June 21, 2020 Is the consensus that the max retard was the root of the temperature issues? Sounds rather glorious it's safe to say, you must be stoked.. 1 Quote Link to post Share on other sites
Yowzer 33,853 Posted June 21, 2020 Report Share Posted June 21, 2020 Just now, sheepers said: fuck man, i did like a million skids on the way home from the dyno. Yeeee! Quote Link to post Share on other sites
sheepers 20,824 Posted June 21, 2020 Report Share Posted June 21, 2020 hard to say exactly tbh. temps did drop once we'd sorted the timing issue, but they were getting better all the time. the more load and running it saw the better it got. so maybe a combo tight new motor and timing issue caused it? i did learn that you cant use the trigger wire to the coil as the trigger for your timing light because it gives a false reading. i dont know by how much, couple of degrees i would imagine. but it is false. 2 1 Quote Link to post Share on other sites
yetchh 6,268 Posted June 21, 2020 Report Share Posted June 21, 2020 On 16/02/2020 at 20:31, cletus said: How retarded is the timing? That can make things overheat Good old Clint.. Stoked it's going good.. 1 1 Quote Link to post Share on other sites
