PAINT THREAD
dylan
When I painted the engine bay most of it turned out quite nice. Better than I thought it would.
I did have trouble with fisheyes on the firewall in an area that still had original paint on. I had sanded and cleaned it with a degreaser and primed it and it all seemed ok. When the topcoat went on I got these fisheyes. I let all dry and harden up, sanded it back and cleaned it again several times and re-primed it and it looked good, but when the topcoat went on the fish were looking back at me again.
There must be something in the original paint in that area causing it but why isn't it happening in the primer. There are going to be other areas I am going to paint like the boot that I don't really want to strip all the original paint off but I don't want this happening either.
  • Replies 1.9k
There could be oil or grease in the seam above it that's leeching out.
Not uncommon in engine bays
Sometimes overdoing the prepsol can actually wick grease and oil out of seams
If the base coat fisheyes again. Let it dry for about an hour till its dry to the touch and give it a scuff with some 400g then dust a few real light dust coats on the sanded area then one over the whole lot and clear it. Hopefully comes right
Yo. I would like some advice about treating steel with phosphoric acid.
I have some Oakite 33 left over from when we did powder coating, I brushed some onto something half rusty and half shiny and left it, it pretty much sorted it out.
However I imagine it would be best to rinse it and wipe it off, is that the case? If so with what?
This is so whatever I do to the Fiat is going to last....
35 minutes ago, tortron said:
Deoxidine instructions say wipe off with a clean damp rag before it drys.
Then wipe with a clean dry rag or prepsol before paint
Ok I just watched a vid of someone using it, it made sense. It looks like deoxidine is essentially the same thing as Oakite.
I might mess with a panel and see what happens.
25 minutes ago, JustHarry said:
We use phosphoric acid regularly at work.
Rinse with water because it's cheaper than meths but b quick with a prepsol and a scotch brite to clean the flash rust off. Doesnt takes a minit
So what is prepsol? Just a solvent?
Wouldnt the scotch Brite expose more bare metal to rust up again?
Also what happens with the phosphoric etc of there is still paint on there or should it all come off?
Google prepsol. It's a wax and grease remover
The scotch brite is for scrubbing the surface clean of any rust after rinsing with water.
I would paint strip any paint off or use mechanical stripping methods. Phosphoric acid is for getting the rust and shit off
Glasurit metal cleaner 360-4 is what you need to use to get the metal properly clean for paint if it's a good job that matters. It's like prepsol on steroids. Dont breath the fumes lol.  Use that with the scotch brite and the metal will shine up brilliant clean silver with no impurities
Once its prepped you need to paint asap. Like same day spec
5 hours ago, Kerry-TGI said:
Can zinc it spray be over painted with epoxy primer? Or if you used that on your welds you'd want to get it off first?
Never paint epoxy over a rattle can product.
If you've just got some overspray sorta stuff round your seams etc just clean it off.
Most zinc rattle cans will wipe off with prepsol. Or thinners at the worst
  • 5 weeks later...
The flattening agent is mixed in by the paint shop, there is some limit where it goes to shit so they are usually scared to add too much in. But if you get someone who will mix it up (or buy your own and test) you should be able to get it pretty flat in 2K.
Fresh lacquer paint looks better in matt black but its not durable at all (it will stain and go chalky at some point), 2K single stage urethane by its nature has this plastic look to it so flattening it out it can still look funny but I have seen a few that look good (they probably use flat clear).
21 hours ago, Kerry-TGI said:
Where can I get a decent 2k matte black? Highly likely my ignorance but I feel like a matte black should be flat as fuck and almost a dark grey, where as the 2 I've tried have both been quite rich and dark, appearing to be more of a satin black. I want something that has a more faded look but don't know what colour I should be looking for, or whether my application is affecting the finish
Glasurit do a matte black 2k. Out if the tin spec
Not sure where you are so not sure who the dealer would be.
In chch ultra paints are the glasi reps
It stops being paint if you add to much matting paste in.
Glasi fo example is 40% max matting paste in the gloss 2k or It just doesn't dry.
Not recommended to use any more then what the paint co recommends
  • 4 weeks later...
  • 4 weeks later...
