cletus Posted August 17, 2012 Share Posted August 17, 2012 I was just talking to a local engineer about the crack testing, does it have to be x rayed or is a std spray on crack test ok? dye penetrant is ok, has to be done by a qualified person, i cant remember off the top of my head what the qualification is Quote Link to comment Share on other sites More sharing options...
cletus Posted August 17, 2012 Share Posted August 17, 2012 mini stuffsome of those mini adjustable cones need shorter shocks as well, they come loose at full droop sometimes Quote Link to comment Share on other sites More sharing options...
cletus Posted August 17, 2012 Share Posted August 17, 2012 I can install a small bar using 8-10mm rod under the seat so it has something to clasp onto and be 1,000x more robust, but then that would consitute a modification? Would anyone even notice? i guess it would legally be a modification, but i doubt anyone would care/notice if done well Quote Link to comment Share on other sites More sharing options...
Backer101 Posted August 20, 2012 Share Posted August 20, 2012 Is it ok for cert and shit to have a rubber fabric braid fuel line going underneath the car? Hope so.... Quote Link to comment Share on other sites More sharing options...
KKtrips Posted August 20, 2012 Share Posted August 20, 2012 I think there is a maximum length of non "hard" line when under the car.. Will check and get back to you. Quote Link to comment Share on other sites More sharing options...
Backer101 Posted August 20, 2012 Share Posted August 20, 2012 Ok cheers Quote Link to comment Share on other sites More sharing options...
escortwags Posted August 20, 2012 Share Posted August 20, 2012 hmmmmm, soooo 'Ive just bought 14ft of that expensive as shit XRP black braid line, does this mean I cant run it all under the car? If no then I'm guessing it cant run in the car either? and the third question.. will any of that matter if my cars going to have a Motorsport NZ Authority Card? Quote Link to comment Share on other sites More sharing options...
yetchh Posted August 20, 2012 Share Posted August 20, 2012 exhaust must exit perimeter of passenger compartment. so as long as it comes out the side thats fine. sorry to bring up an oldie, can you clarify must exit perimeter of passenger compartment?. I might not be able to fit a 3" pipe over my diff so would want to do a side exit (is a coupe) or maybe just dump it before the exhaust, tho apparently that can cause cancer.. Quote Link to comment Share on other sites More sharing options...
SP450andLE Posted August 25, 2012 Share Posted August 25, 2012 What's the dealio with rear mounted lights? Can I have a rear mounted spottie that is operated by a switch? Or would it have to be operated by a reverse gear sensor thing? Pic to help my ramblings make sense: Quote Link to comment Share on other sites More sharing options...
Indiana_Jones Posted August 25, 2012 Share Posted August 25, 2012 lol is that my old spottie? Not entirely sure here in NZ but if i recall correctly you could use them in the UK if you had a glow switch (i.e. a switch that glows when on) fitted. Quote Link to comment Share on other sites More sharing options...
SP450andLE Posted August 25, 2012 Share Posted August 25, 2012 It most definitely is. Looks better with no black plastic And oh yeah, hopefully NZ has the same sort of rule... Quote Link to comment Share on other sites More sharing options...
Nominal Posted August 25, 2012 Share Posted August 25, 2012 Looks like it has to be reverse-switched, or only operate when the headlights are off. See here: http://vehicleinspection.nzta.govt.nz/v ... sing-lamps Quote Link to comment Share on other sites More sharing options...
brad Posted September 6, 2012 Share Posted September 6, 2012 I just got pink stickered for lack of springs in the front of my EX, would cut springs in shortened struts to make them captive be OK to pass thru VTNZ? cheers. Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 6, 2012 Share Posted September 6, 2012 Cut springs are illegal and seeing as you got pinged for lack of springs I would say that they will be checking that area specifically.. Do you actually mean LACK OF SPRINGS?? As in - there are none at all??? I don't even... whaaaaaa???????? facepalm Quote Link to comment Share on other sites More sharing options...
ryanfels Posted September 6, 2012 Share Posted September 6, 2012 I was under the understanding that cut springs are ok as long as the spring seat is angled and shaped to seat it properly. My grande got certed like this Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 6, 2012 Share Posted September 6, 2012 Cert and WOF are different. Quote Link to comment Share on other sites More sharing options...
brad Posted September 6, 2012 Share Posted September 6, 2012 Arn't they pretty anal when it comes to stickered wofs? Quote Link to comment Share on other sites More sharing options...
KKtrips Posted September 6, 2012 Share Posted September 6, 2012 Who is they? What is a stickered WOF? Quote Link to comment Share on other sites More sharing options...
morkster Posted September 6, 2012 Share Posted September 6, 2012 Pink Stickered WOF and I was under the understanding that cut springs are ok as long as the spring seat is angled and shaped to seat it properly.My grande got certed like this Quote Link to comment Share on other sites More sharing options...
brad Posted September 6, 2012 Share Posted September 6, 2012 cuts & shortened struts = ok if done correctly then? Quote Link to comment Share on other sites More sharing options...
