cletus Posted July 10, 2012 Share Posted July 10, 2012 Is it ok to have a surge tank mounted in the engine bay? theres nothing saying you cant in the rule book. Not a good idea though, best to put it under the car at the back to keep away from heat etc Quote Link to comment Share on other sites More sharing options...
be4ver Posted July 10, 2012 Share Posted July 10, 2012 Quick question. Drive shaft hoops should have M8 or M10 bolts? Quote Link to comment Share on other sites More sharing options...
cletus Posted July 10, 2012 Share Posted July 10, 2012 question regarding cages for clint,been advised a 6 point cage is neccesary to keep my gemini straight due to the v8 etc, planning on drags as well as cert for roaduse, was going to get carlos to build it but what are the specifics i should look at, size tube? plated in at A and B pillar? subframe to tie in at the B pillar was the plan, also will i still be able to carry rear seat passengers? tip forward fixed back seats for entry? some extra strength would be a good idea. You need a motorsport authority card to run a full cage in a unibody road car. if it was me id decide what sort of motorsport you are going to do and get hold of the regs for that and build the cage to suit. TBH im not that clued up on cage specs, as far as a cert goes we are more concerned with the interior impact side of things rather than the cage construction, the authority card covers that. unfortunately rear passengers are a no go with a cage, ive looked into that for someone else who wanted to take kids for skids in a race car and it couldnt be done...... Quote Link to comment Share on other sites More sharing options...
cletus Posted July 10, 2012 Share Posted July 10, 2012 Porsche offers a bolt in full roll cage (with harnesses) as an option on GT2 and GT3 model 911's, I believe being these are factory parts they don't require an msnz authority card to be road legal?If the cage was bought from Porsche and installed at a later date (say to a 2009 car) would it still be legal without an authority card? On a semi related note: Do TRD (Toyota Racing Development) parts sold/fitted to a new car by a toyota dealer count as factory option parts? ie: if you optioned your new GT86 with TRD height adjustable coilovers would it need certification? trd stuffs= would need cert even if fitted at the dealer. ive done heaps of estimas/boring cars with electric swing out seats, these are fitted by a toyota company (TECS) and are sold new from toyota dealers like that, but because they werent actually made by toyota they need certing. same with some nissans, those rb26 powered stageas, some pulsar 4x4s fitted with sr20s, all done by a company called Autech porsche rollcages= if you fitted a factory cage to one, it would need auth card. a new one factory optioned i believe would be ok without because its oe equipment. would have to find out to be 100% on that though..... Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 10, 2012 Share Posted July 10, 2012 What? You have to cert an Autech Stagea even though it has exactly what it is on the data plate and is built like that by Autech? Quote Link to comment Share on other sites More sharing options...
cletus Posted July 10, 2012 Share Posted July 10, 2012 Quick question. Drive shaft hoops should have M8 or M10 bolts? 4x M10 or 3/8. if you are bolting thru a panel steel floor then you will need big washers on the topside of the floor. Quote Link to comment Share on other sites More sharing options...
cletus Posted July 10, 2012 Share Posted July 10, 2012 What? You have to cert an Autech Stagea even though it has exactly what it is on the data plate and is built like that by Autech? the ones ive seen ( not that many, probably 2 or 3) have had rb25 on the data plate. same with the autech pulsars ive done, they get picked up at compliance because the data plate doesnt match the engines in them. i havnt seen any with the correct engine number on the data plate, thats not to say they dont exist, because then it wouldnt need a cert/i wouldnt get to see it. have you seen one with rb26 on the data plate? Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 10, 2012 Share Posted July 10, 2012 Crazy, I did some looking just now and apparently not. Fuck that's weird. That's a silly thing for Autech/Nissan to do. RB25DET on the dataplate. I did find this though; Quote Link to comment Share on other sites More sharing options...
glen Posted July 10, 2012 Share Posted July 10, 2012 Now if i remember correctly, the autech stageas rolled down the line as normal RS4's and then autech got them and fitted the gtr bit's. So they all carry the original RS4 build plate Quote Link to comment Share on other sites More sharing options...
Raizer Posted July 10, 2012 Share Posted July 10, 2012 Now if i remember correctly, the autech stageas rolled down the line as normal RS4's and then autech got them and fitted the gtr bit's. So they all carry the original RS4 build plate This. Was a way of getting the RB26/more power in there without breaking the 206kw agreement. Quote Link to comment Share on other sites More sharing options...
77magnum13hundy Posted July 10, 2012 Share Posted July 10, 2012 Quick question. Drive shaft hoops should have M8 or M10 bolts? 4x M10 or 3/8. if you are bolting thru a panel steel floor then you will need big washers on the topside of the floor. also what mm steel is acceptable for drive shaft hoop? thanks Quote Link to comment Share on other sites More sharing options...
cletus Posted July 11, 2012 Share Posted July 11, 2012 50x5mm is minimum size. lol at diy data plate. have seen a few skylines/cefiros etc with a "T" scratched into the tag after the engine number "nah bro its a factory det bro doesnt need certz" Quote Link to comment Share on other sites More sharing options...
H05TYL Posted July 11, 2012 Share Posted July 11, 2012 Porsche offers a bolt in full roll cage (with harnesses) as an option on GT2 and GT3 model 911's, I believe being these are factory parts they don't require an msnz authority card to be road legal?If the cage was bought from Porsche and installed at a later date (say to a 2009 car) would it still be legal without an authority card? porsche rollcages= if you fitted a factory cage to one, it would need auth card. a new one factory optioned i believe would be ok without because its oe equipment. would have to find out to be 100% on that though..... Thanks for the answers. Though how would a wof inspector (or anyone else) know when the cage was installed? Quote Link to comment Share on other sites More sharing options...
madmitsi Posted July 15, 2012 Share Posted July 15, 2012 got a quick question, can i weld on brackets to my front struts heres a pic on what i plan to do Quote Link to comment Share on other sites More sharing options...
cletus Posted July 15, 2012 Share Posted July 15, 2012 No, cant weld to a casting or a forging. Is it for a brake caliper bracket? Could you bolt it to the spindle? Quote Link to comment Share on other sites More sharing options...
madmitsi Posted July 15, 2012 Share Posted July 15, 2012 yeah brake calliper bracket, that sux was hoping on doing it this week back to the drawing board i think, i can bolt to spindle where the original bracket was just need to get another set of rotors redrilled to go on the front face of the hub so i can have the room to do it that way, thanks for the quick response Quote Link to comment Share on other sites More sharing options...
be4ver Posted July 16, 2012 Share Posted July 16, 2012 Lol back to drive shaft hoops agen, do the bolts have to have nyloc nuts? Or is spring washers all g? Quote Link to comment Share on other sites More sharing options...
cletus Posted July 16, 2012 Share Posted July 16, 2012 spring washers or nylocs are fine, the rules dont actually mention a lockwasher or anything on the driveshaft loop bolts Quote Link to comment Share on other sites More sharing options...
danger Posted July 16, 2012 Share Posted July 16, 2012 Oi Clint. You're awesome by the way. Ta. Quote Link to comment Share on other sites More sharing options...
andy Posted July 16, 2012 Share Posted July 16, 2012 You're on a roll Clint! One for my coupe. The previous owner made a mod to a fixed chassis cross member with a gas axe. There is still a lot of meat in it but is this Likely to be a major? Does this fall under your cert or the repair cert? Cheers. Andy Quote Link to comment Share on other sites More sharing options...
