Yowzer Posted July 29, 2017 Share Posted July 29, 2017 Ew no. Cressida. 1 Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted July 29, 2017 Share Posted July 29, 2017 I need to do the same for the bmw. What are you using for the channel ? Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 29, 2017 Share Posted July 29, 2017 There's some outfit doing weld-on prefab units for the BMW's, I was looking at getting it and making it fit, but I think I'll just make something from scratch. Dunno what I'm gonna use yet. Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 29, 2017 Share Posted July 29, 2017 Urgh, can't find a pic that isn't blocked by Photobucket. 1 Quote Link to comment Share on other sites More sharing options...
Yowzer Posted July 29, 2017 Share Posted July 29, 2017 Quote Link to comment Share on other sites More sharing options...
Mr Vapour Posted July 29, 2017 Share Posted July 29, 2017 There are lots of different companies. From my reading they need to be machined not folded. The folded ones flex and slip. Have a look at the Ireland engineering ones they have groves in them to lock in place. Quote Link to comment Share on other sites More sharing options...
SOHC Posted July 29, 2017 Share Posted July 29, 2017 For a Falcon ute that needs re compliance would small rust holes in the bottom of the front guards and behind the rear wheels matter? Quote Link to comment Share on other sites More sharing options...
MaxPower Posted July 30, 2017 Share Posted July 30, 2017 hi i have brought some 2" drop spindles off a guy for my 1980 L300 van, they have come with a ndt test sheet. can i get a cert with these? or do they have to be a certain brand etc? think they are from the usa. would like to know before installing them, cheers. Quote Link to comment Share on other sites More sharing options...
cletus Posted July 30, 2017 Share Posted July 30, 2017 On 7/29/2017 at 22:07, SOHC said: For a Falcon ute that needs re compliance would small rust holes in the bottom of the front guards and behind the rear wheels matter? Will depend on the inspector a bit but if it just has small holes in the exterior panels, probably not Quote Link to comment Share on other sites More sharing options...
cletus Posted July 30, 2017 Share Posted July 30, 2017 21 minutes ago, MaxPower said: hi i have brought some 2" drop spindles off a guy for my 1980 L300 van, they have come with a ndt test sheet. can i get a cert with these? or do they have to be a certain brand etc? think they are from the usa. would like to know before installing them, cheers. 2.2 (36) in here covers the requirements http://lvvta.org.nz/documents/standards/LVVTA_STD_Suspension_Systems.pdf Basically if it's a known brand with a separate press in pin, then they are usually ok 1 Quote Link to comment Share on other sites More sharing options...
MaxPower Posted August 1, 2017 Share Posted August 1, 2017 had a look and they do have pressed in pin\stub, they are from 'x2 industries' hopefully they have a good name for themselves. link; http://www.x2industries.com/dodge-1979-2006-dodge-d50-mighty-max-drop-spindles-p-3312.html#.WYABxGPwzsl thanks for the advice. Quote Link to comment Share on other sites More sharing options...
chasinthemirage Posted August 4, 2017 Share Posted August 4, 2017 Is there a minimum requirement for clearance between the inside of a wheel rim and the brake calipers? Tried the stock wheels on the VL tonight and there's only a mm or two between them. Slightly concerned the Royale wheels may be a different design internally to the Calais wheels which clear 290mm brakes Quote Link to comment Share on other sites More sharing options...
Nominal Posted August 5, 2017 Share Posted August 5, 2017 16 hours ago, chasinthemirage said: Is there a minimum requirement for clearance between the inside of a wheel rim and the brake calipers? Tried the stock wheels on the VL tonight and there's only a mm or two between them. Slightly concerned the Royale wheels may be a different design internally to the Calais wheels which clear 290mm brakes Mine are really close, same sort of clearance 1-2mm. IIRC I tickled the corner edge of the caliper with a grinder so they wouldn't rub. Quote Link to comment Share on other sites More sharing options...
chasinthemirage Posted August 5, 2017 Share Posted August 5, 2017 @Nominal sweet thank you. I'll try them with new pads and see how close they are, I think they'll move away from the wheels as the pads wear so I might be ok. Quote Link to comment Share on other sites More sharing options...
cletus Posted August 5, 2017 Share Posted August 5, 2017 There isn't a minimum amount of clearance, just can't ever touch. Surprising sometimes how much flex/ movement / growth there is under hard use on some vehicles. I did a cortina once that had enough disc- caliper clearance when cold but after a few hard stops the brake disc grew enough to rub the inside of the caliper 6 Quote Link to comment Share on other sites More sharing options...
Nominal Posted August 9, 2017 Share Posted August 9, 2017 New LVVTA newsletter out. An opportunity to play spot-the-cletus-with-a-falcon http://www.lvvta.org.nz/documents/newsletters_pub/LVVTA_Newsletter_2017_Jan-June.pdf 1 Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted August 12, 2017 Share Posted August 12, 2017 @cletus my man. I'm taking my dads MS112 for a cert for the engine swap. 5m been swapped for 7m so ~30% more power and +200cc. Other than that it's stock. It's getting driveshaft hoops and a shroud for the fan tomorrow. Anything else I should look at? Quote Link to comment Share on other sites More sharing options...
cletus Posted August 12, 2017 Share Posted August 12, 2017 If it's standard then should be pretty straight forward You could try doing the brake test and see how that goes before you take it for cert- 3x 100 to 0 stops, 4.4 sec max,- in a total of 2 minutes. I wouldn't think it needs driveshaft loops either if it's just a larger engine that isn't turbo or supercharged http://lvvta.org.nz/documents/infosheets/LVVTA_Info_07-2016_Drive-shaft_Safety-loop_Requirements.pdf 1 Quote Link to comment Share on other sites More sharing options...
Carsnz123 Posted August 12, 2017 Share Posted August 12, 2017 9 hours ago, cletus said: I wouldn't think it needs driveshaft loops either if it's just a larger engine that isn't turbo or supercharged http://lvvta.org.nz/documents/infosheets/LVVTA_Info_07-2016_Drive-shaft_Safety-loop_Requirements.pdf I was under that impression too but Steve Rhodes said it's a good idea to put them on as the new engine is straining the driveshaft more. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted August 13, 2017 Share Posted August 13, 2017 19 hours ago, cletus said: If it's standard then should be pretty straight forward You could try doing the brake test and see how that goes before you take it for cert- 3x 100 to 0 stops, 4.4 sec max,- in a total of 2 minutes. I wouldn't think it needs driveshaft loops either if it's just a larger engine that isn't turbo or supercharged http://lvvta.org.nz/documents/infosheets/LVVTA_Info_07-2016_Drive-shaft_Safety-loop_Requirements.pdf The brakes will be good for it no doubt. 2jz passed no stress. 1 Quote Link to comment Share on other sites More sharing options...
