All Activity
- Today
After clearing out the fuel system and sealing the lift pump leak the same trip took 36 mins this afternoon It's still hellishly noisy, but too wet and cold to pull the rocker cover off today
Donald Fleming changed their profile photo
Daves new school holden shambles. (And finally a Turbo)
jakesae101 replied to Muncie's topic in Other Projects
Part number is 92183920 i paid 57$ +gst from holden and it was here in a week.- 404 replies
- not as good as a barra
- ecoboost
(and 1 more)
Tagged with:
FWIW, my experience has been that on current fuels once a plug is fouled you can't bring it back. Solvent, abrasive blast or heat, none work. Not like the old days where solvent worked 99% of the time.
Its been a total pleasure being present for parts of this build.
100% agree with Nominal. Talk to Terry Price up front before you get the welder out. It would also be worth talking to whoever your LVV certifier is going to be as well about what he wants to see and when for the V8 conversion. Cool project!
- Yesterday
There is a dedicated X1/9 forum that has been going for a long time, there is a lot of discussion of the problem and no one has mentioned such a possibility. Modding the hubs would be a cert issue, and I would wrap it up along with a whole lot of other mods if I went that way. If that is the case then some bolt on adapters is probably a better bet, 20mm thick gets me into FWD offset territory.
Yeah not much meat to work with, you could always mark out where 4x100 would locate and see if its doable Adding more material would be tricky and potentially obvious Whats the spline count inner and outer bearing diameter With the Ae111 I could swap to Rav4 as the bearing inner diameter was the same and the rear Im using bolt on bearings with the drive flange from a highlander (FWD was Camry from memory) Just wondering if there is another car that might work
It's 20+ years old and now has had positive pressure up it, won't be surprised if it's called it quits.- 404 replies
- ecoboost
(and 1 more)
Tagged with:
@mahaway Installing the V8 should be a fairly easy cert if you are sensible and follow the rules. You should be careful with the rust repairs though since the car is dereg. It would be best to talk to a repair certifier before you start so you don't have issues getting it legal later. These are different to the LVVTA modifications certifiers. There is only one up your way at present
Accommodation booked with @Kelvin and leave accepted. ill have a 2xl please and thanks @Bistro
Had a bit of a squeak after the ride where I broke the dash cluster. Had a feeling the front wheel was a bit of center and rubbing on one of the rotors so wanted to visit kim and see if we could work it out. Made a trip out to @Kimjons and fixed that. While i was there we got busy cutting up my 2nd cluster bracket and welding a different set up on it. Pulled the top triple clamp apart to do the job right, make my life easier. Looks a bit like this from front now. Got home and glued a little broken part back onto the cluster and chucked the rear cover on the back. Lubed the chain and hit up @flyingbrick to go for a ride Marnix came along and we ended up going over to Bethlehem via waihi and back over the kai mais and through scottsmans velly. Bike went flawlessly. Only problem I found it been a little stiff in the rear so time to try adjust the rear shock. Off course I had to pull it apart to reach the screw to adjust it. It's here at the tip of my finger And since the bike was going so good I thought I'd take it for a ride by myself. I shot to vtnz and handed in my white plates and got my black original plates re registered back on the bike so that's official and was a pretty easy process over all. Carried on for a ride out to Raglan. And on my way home it started running like a bag of balls. Infact stopped and wasn't able to start it again. So called @flyingbrick to pick me up and before he got to my house I had another mate offer and was already on the way. Got ot home and thought I better go through these carbs, they are obviously the reason for it not wanting to start. Out to @flyingbricks house to take advantage of his ultrasonic cleaner. There was definitely some crap in them that's for sure. Also got the boss on board giving the carbs a blow down after a good hot water wash. And back together Time to clean up some fouled plugs as well. Smashed it back together and had no luck starting it or getting fuel down to the carbs. And that's cause it had no fucken fuel in it. The fuel guage said ¼ of a tank and it was fucken bone dry. No wonder why it didn't want to start and was running like a bag of balls. Chucked some gas in it and fired up straight away. Until the carbs were leaking like a siv. So off they come and stripped down again. Had a feeling it was the o rings on these little guys which had to do with the float. Spoke to a mate and he confirmed my thoughts of the o ring. So later today I'll head out and buy some viton o rings that are suitable and chuck it all back together again. Follow for more stupid mistakes later.
- 42 replies
- 10
Thats the rear, the front has a spindle rather than a splined hole but the flange detail is identical. Those holes are tapped M12x1.5, I wonder if they were converted to a press in stud if the bigger hole 1mm outboard would clean up all the threads. Looks like a bigger hole further out might get a bit close to the edge of the flange tho...
Depends how you do it and if anyone would notice I guess My Ae111 5x114.3 conversation uses all factory toyota parts that bolt on so looks factory (well it would if it didn't have massive brakes etc) What do the factory drive flanges/ wheel flanges look like?
Yea the options should be way better, bit so much dicking around to get to the point where 4x100's would bolt on. I am guessing that certing it would be on the cards... Altho if I was going that path there would be a few other things to get signed off a well....
@Mr.Mk1's better half has a pretty sweet late model (sorry josh don't know my MK's past 3) with a v8 in it. Josh will hopefully point you to some pics / build.
No actual updates other than today’s flex session. although I did notice that I had the “diagnostic” switch turned on, so it’s basically had its timing set to 10 degrees for his knows how long rather than 17degrees. Dick. it has now got an expired wof so need to sort that.
Guilty of rotten valiant ownership too! Your new ride is a killer shape! Mine uses an instrument cluster voltage regulator that has a few prongs on the back and pushes into the printed circuit board. I tried two and no change. Its odd cause i thought the temp and fuel were both controlled by this. I have seen online a link to making your own using jaycar parts that supplies a real stable voltage. The fuel gauge seems to work fairly accurately. Temp, i never nutted that out.. Gauge sweeps when earthed, bypassed the wiring, tried a couple of senders in boiling water and no joy. The needle moved a smidge on a HOT day in 5pm traffic but thats the most ive seen out of it.. wasn't enough travel to get on the scale.
Donald Fleming joined the community
Ok so if you went 4x100 few options that would work in that range depends what style you like
I have rung the police and NZTA about the 2 cars that were registered to me with out me knowing and me get 3 fines and a a whole lot of other crap, no one knows what is going on, the 2 registration numbers do not exist both those plates have not been issued yet. How is this even possible? The nzta has a record of it being put into my name at vtnz henderson and i rang them but they have no record of the transaction or the platess. Just as I was typing i got a call for the cops and they say they are working on it and its a strange one.
Ours came with Punto rims fitted - with the biggest pile of badly made spacers i've ever seen. There was also a set of OE Campagnolos - with one bent and most kerbed a little. Got the bent one straightened and the others cleaned up and painted. Sold it with them on. Handled much better without all the spacers. Campags do come up now and again - and there's at least one outfit here who can cut/weld widen them.
Current rims are 13x5 with a 25mm offset, things can move outboard 10 or 15mm without too many dramas, plus they have a 4mm spacer from factory that can be removed. With 175-70 13's they just rub on full lock, but the OEM spec is a 185-60 13.
You could slot some 100mm rims and machine up centrebore locator rings to suit. Open up a bigger range of wheels.
