This is the Dona car that i got the motor from, i was given it an i drove it home,it was at alltech on the shore as a job for a customer and was to dear for them to fix, had a broken turbo shalf, i had to put a ball point pen into the airflow meter flap to hold it open alittle to trick the comuter for some reason it new the turbo wasnt working and wouldnt go above idle, got it home out west and started pulling it apart, the car drove really nice,seemed quite a solid car......
look at all the shit under the bonnet........
Zep is right motor will go straight in a chevette using the Gemini mounts, i used the gem 5 speed as its smaller than the piazza, you need a isuzu Mu top gearbox Quadrant to bring the stick out the same hole,small mod to get it to fit to box but its easy as, made up a cross member as couldnt get what i wanted from the stock one, standard gem drive shalf,and gem diff from a wagon so the shocks bolt up the same, i used the chevette trailing arms( i thk) and the gemini front stabiliser bar fit's the chevette,
top diff is the little baby chevette one and the bottom is the Gemini
station Wagon ready to get put in at the time i did it.....
any question id be glad to try and help......
Brett
