holdenman 102 Posted October 14, 2020 Report Share Posted October 14, 2020 I am trying to decide on the future induction of my 3.3 Holden engine that runs about 11.5:1 compression with big Ports, Valves and camshaft to match will willingly rev past 7000rpm I tried a 2-barrel then a 500cfm Edelbrock but felt it was a bit down on power so I threw on a 750cfm Holley and it showed huge power gains and that the engine needed more CFM This is where some of you are brilliant in helping the likes of me that only knows about 3.5PSI injection not 60PSI. I can get 45mm ITB's and using velocity stacks but if I understand correctly then I need a basic ECU to run partly off a balance tube, TPS and o2 sensor then a guru to tune it Spark can be run separately or integrated as I run HEI dizzy and Who what how are the questions Quote Link to post Share on other sites
vk327 346 Posted October 14, 2020 Report Share Posted October 14, 2020 efi works well on the old 202, mines turboed running a link atom have a look at my vk build thread, iv used a 36-1 crank trigger on the balancer, deleted the dizzy and using an AU falcon coil pack wasted spark setup, pair firing the injectors, injectors and fuel rail is easy if the throttles have injector bosses, just need an efi pump and fuel reg to feed it. would need sensors for coolant temp air temp and TPS, can use a MAP sensor if you can plumb all the throttles to a small manifold, usually ends up using the TPS as the load value rather than map due to cylinder fluctuation and lack of a plenum 2 1 Quote Link to post Share on other sites
Thphantum 7,148 Posted October 15, 2020 Report Share Posted October 15, 2020 These used to go pretty good for an ole 3.3. Quote Link to post Share on other sites
MACKAZ 2,921 Posted October 16, 2020 Report Share Posted October 16, 2020 My brother in law has a VK with a fairly warm 3.3 12 port with a cut n shut GTR Torana manifold on it. He has been assembling parts for a 235 stroker running efi turbo. But an LS has taken care of that. Cheaper, more power. Quote Link to post Share on other sites
Roman 13,462 Posted October 16, 2020 Report Share Posted October 16, 2020 So you'll need to buy an ECU and a wideband oxygen sensor, I'd reccomend getting a Link Fury ECU as it's designed for 6 cyl engine and has a wideband controller built in. So it makes wiring easier and cheaper. The tricky bits about an older engine for EFI are that you need a crank and cam angle sensor retrofitted. As well as injectors of course. If you want to do things cheaply you could buy an ECU that only has 4 injector and ignition drives, and put them in pairs. But if you've got inlet reversion issues with big cams and high comp, its nice to be able to adjust the injector timing so that each cylinder is the same. So you can avoid spraying when it's spitting it back out. Having individual coilpacks is super awesome. This way you can have knock control working per cylinder, or have a traction control setup that shuts of cylinders until your wheel slip stops beyond a certain point. Which is helpful if you have a car that's boggy off the line but then wheelspins badly too if you launch too high in rev range. Depends how far down the rabbit hole you want to go! But I reckon once you have a decent EFI setup you'll be amazed at how it's able to squeeze the most out of your engines powerband and also have great economy and drivability, cold starts etc. I'd not reccomend buying an obscure ECU that not many people know about, as sometimes it can be hard to get people to tune it. Link and Haltech are popular options, but Haltech is more expensive and leaves a few things missing which are big annoyances. 2 Quote Link to post Share on other sites
holdenman 102 Posted October 17, 2020 Author Report Share Posted October 17, 2020 Thanks for the good stuff Roman, you have given me more to think about The old Jetronic injection on the black motors gave a squirt per revolution and used a crank pickup but then the std EFI manifold is too restricted to get maximum performance as the terrible casting caused restriction and was totally uneven. Falcon injectors used to be the go for them. I ran VK Injection on my LC and got about the maximum I could from that setup but then went to DCOEs and picked up another 60+HP and way more torque. Until I source everything I am going to run triple webers and maybe progress to EFI later which I may combine it with a turbo. I also need to do some other bits to the car like a LSD and better brakes before I take it to the track. 2 Quote Link to post Share on other sites
Roman 13,462 Posted October 17, 2020 Report Share Posted October 17, 2020 Also if you are ever buying injectors, make sure they come with a CC rating and deadtime information. Some injector companies even decent ones are shocking for not supplying data, and then they run like shit. Quote Link to post Share on other sites
piazzanoob 1,893 Posted October 17, 2020 Report Share Posted October 17, 2020 efi hardware in Australia have the bits you are wanting. not cheap by any means but good quality https://www.efihardware.com/ then run a link computer and individual coils and a crank trigger Quote Link to post Share on other sites
holdenman 102 Posted October 19, 2020 Author Report Share Posted October 19, 2020 I reckon I could get all the bits needed apart from an ecu and it would include a wideband 02, TPS and Ignition system for around NZ$2700. The fuel system can be fairly simple, I have a couple pumps and 1 adjustable regulator so mainly hose and fittings. I decided to park this for now as I will get the new triple webers up and running first and I also need to build a new exhaust system Quote Link to post Share on other sites
Truenotch 8,904 Posted October 19, 2020 Report Share Posted October 19, 2020 If you decide to go the ITB route, talk to @BobbyBreeze at Whitleytune. He casts inlets and throttle bodies and can help with getting the right lengths for harmonic wave tuning. 3 Quote Link to post Share on other sites
holdenman 102 Posted October 20, 2020 Author Report Share Posted October 20, 2020 Thanks Truenotch, Harmonics can be very powerful alright but never though of it in the induction system. The Holden 6 doesn't like hanging around 6000rpm because of this reason and I either change just under or quickly go past it, the current engine I would estimate would rev similar to my old one at around 7500rpm but I pucker more as the revs climb and so far only revved to around 6600. The DCOEs will help more than the current 4-barrel. Quote Link to post Share on other sites
Muncie 10,197 Posted October 30, 2020 Report Share Posted October 30, 2020 If you want gross but effective triumph 2500pi mechanical injection works on the old 202 use efi throttle bodies as the trumpy ones neck down to about 32mm and are worth big bucks but the mechanical injection just mounts off the dizzy so pretty user friendly to modify. Old tech as fuck once you get your head around the gear its not bad and will make good power. Pair it with clever ignition would be a very good thing. I ran lucas mechanical injection off a 2.5 on a 2 litre triumph race engine i scored that was running triple webbers i couldn't afford them so was worth a punt, it was a punchy weapon! Once it was setup it just worked. 1 Quote Link to post Share on other sites
d.p.n.s 2,439 Posted November 29, 2020 Report Share Posted November 29, 2020 the BMW me throttle bodies are around 50mm and have the injectors in the aswell as idle air tube and tps .. can find them cheap aswell...just need to make a manifold to bolt them to. Quote Link to post Share on other sites
d.p.n.s 2,439 Posted November 29, 2020 Report Share Posted November 29, 2020 I got mine from America of all places....landed for $400. i also have a copy of the flange i had cut from auto bend and a die a mate made to form the tubes in a press...if the helps. 2 Quote Link to post Share on other sites
holdenman 102 Posted December 3, 2020 Author Report Share Posted December 3, 2020 These are the ones I was looking at, a bit over $300 each with velocity stack but as I got the 45 DCOE's I will tune them in after the new stacks arrive probably after New Year, they fit my manifold so easy as. 1 Quote Link to post Share on other sites
