yetchh Posted April 13, 2020 Posted April 13, 2020 Hi fellas, which branded power files do you guys use? and elec over air, any advantages? Sick of grinding welds with a grinder.. Cheers. 1 Quote
tortron Posted April 13, 2020 Posted April 13, 2020 I have a black and decker electric finger sander This is my 2nd one as the front wheel wears out. I'd make a new one on a lathe once a year if I had one as the rest works fibe Probably get a Makita one when this one wears out 3 Quote
tortron Posted April 13, 2020 Posted April 13, 2020 Also get the green zirconia belts, they don't fly to bits as often 2 Quote
Transom Posted April 13, 2020 Posted April 13, 2020 Tool shed electric cheap as goes hard for what it is and their belts are cheap as - I only buy the 40 grit as they don’t last long anyway comes with a straight 13mm finger a bent 13mm finger and a narrower 5mm? Finger have not found zirconia belts for it yet and local tool shed had a good look thru listing for me in 13x455 once you have one you will wonder how you did without it ryobi +1 do one of you have that gear already 3 Quote
JustHarry Posted April 13, 2020 Posted April 13, 2020 Air tools ftw....if you have a compressor to run them. For work I've got a 3m 10mm belt Sander and a 20mm jobby from r a Johnson. Think its car tool or some brand like that. Both get used almost daily. Both are decent tools. Important to oil everyday and they last really well. Air tools are always less bulky. Edit. I have the big one. We also have the 10mm one as a workshop tool. They get abused pretty hard and they last a couple years http://www.raj.co.nz/product-group/1110-belt-sander-10-x-328mm/category/308-sanders http://www.raj.co.nz/product-group/1111-belt-sander-20-x-520mm/category/308-sanders 1 Quote
JustHarry Posted April 13, 2020 Posted April 13, 2020 I know they're spendy but 3m belts last like 10000000 times longer than the cheapies so are worth it 3 Quote
NickJ Posted April 13, 2020 Posted April 13, 2020 +1 for air, mush easier to move around in tight places Quote
Bling Posted April 13, 2020 Posted April 13, 2020 I have a black and decker one, does the trick. Toolshed belts are pretty shit, mine tend to break before running out of grit. Will invest in better belts next time. The Toolshed ones are dirt cheap though, so can't complain too much. Will check that front wheel on mine though in case that is causing issues. Air would be better, but fuck that racket lol. 2 Quote
JustHarry Posted April 13, 2020 Posted April 13, 2020 The flex-o-vite belts from bunnings are also pretty bad. They tend to break at the seam long before thyre worn out of grit 1 Quote
Bling Posted April 13, 2020 Posted April 13, 2020 Looks like SprayStore sells 3M ones, i'll give them ago when they start shipping again and report back. Quote
yetchh Posted April 13, 2020 Author Posted April 13, 2020 I like the idea of air but not sure if I cbf with air houses lying around and the compressor on all the time.. They are nice and small tho.. 1 Quote
Bling Posted April 13, 2020 Posted April 13, 2020 I only use mine in tight spots. Lennox cut off wheel on grinder a lot of the time with flap disc mixed in. Quote
JustHarry Posted April 13, 2020 Posted April 13, 2020 I find Roloc Sanders are also a lot better for finishing and getting that sweet "ground" finish the pros leave....... 2 Quote
flyingbrick Posted April 13, 2020 Posted April 13, 2020 Just now, JustHarry said: I find Roloc Sanders are also a lot better for finishing and getting that sweet "ground" finish the pros leave....... And they let you remove a weld down flush with the surrounding material far easier than any traditional grinding disk or belt sander. Only bitch is when you get a disk caught and it rips off the adaptor leaving behind its plastic nubbin to dig out lol 1 Quote
ajg193 Posted April 13, 2020 Posted April 13, 2020 The expensive belts at mitre 10 last like 45 mins each, compared to 8 seconds for the cheap ones. 1 1 Quote
yetchh Posted April 13, 2020 Author Posted April 13, 2020 What's a good mid range air file? I see a shinano on the tard for around 4 hundy. Quote
JustHarry Posted April 13, 2020 Posted April 13, 2020 Think my 20 mm air one was 250 and the 10mm was 180 Quote
Esky_addict Posted April 20, 2020 Posted April 20, 2020 Got the savebarn one aswell, brought bulk belts off Aliexpress awesome tools Quote
piazzanoob Posted April 27, 2020 Posted April 27, 2020 On 13/04/2020 at 21:26, JustHarry said: The flex-o-vite belts from bunnings are also pretty bad. They tend to break at the seam long before thyre worn out of grit yeah have found that. have you used the bosch belts yet? was thinking on ali for some belts and maybe an air power file too as cheap Quote
tortron Posted April 27, 2020 Posted April 27, 2020 I use the green mytools ones from trademe. Couple of bucks each, come in packs of 10. Last well, can cut them on sharp edges, but that's the way it goes Also the tip roller on my 2nd one is starting to get loose. Looks like you will go through 2 per rusty mitsi Quote
