WhangareiKE70 502 Posted September 13, 2018 Report Share Posted September 13, 2018 Discuss away. Let me know any advice, comments, suggestions you may have. I have many ideas but more ideas never hurt.. Stance for days. -Hayden Quote Link to post Share on other sites
johnnyfive 9,637 Posted September 14, 2018 Report Share Posted September 14, 2018 Giant widebody box guards? Who was it that used a bunch of Isuzu Mu guards to get the shape a while back? Quote Link to post Share on other sites
tortron 61,765 Posted September 14, 2018 Report Share Posted September 14, 2018 ?? Quote Link to post Share on other sites
WhangareiKE70 502 Posted September 15, 2018 Author Report Share Posted September 15, 2018 On 14/09/2018 at 17:41, tortron said: ?? On one hand, hell no. But on the other hand, it will probably need something like that haha. Had a quick squiz at the Car Construction manual and it said something about minimum of 30(?)% of the overall circumference of the wheel needs to be covered, so that means I can hopefully I can get away with having the front essentially uncovered, and just covering the top and back side of the tread. Was thinking something similar to the Smittybilt Jeep fenders, which are essentially a tube and plate construction, and join that to the front tube bumper I plan to build, I just need to allow for flex between the flare and guard, as the flare will be mounted to the chassis and the guard obviously to the body. Quote Link to post Share on other sites
Raizer 17,754 Posted September 15, 2018 Report Share Posted September 15, 2018 On 14/09/2018 at 16:26, johnnyfive said: Giant widebody box guards? Who was it that used a bunch of Isuzu Mu guards to get the shape a while back? That was the Subaru powered Starlet wasn't it? Edit: 1 1 Quote Link to post Share on other sites
WhangareiKE70 502 Posted August 2, 2019 Author Report Share Posted August 2, 2019 Can anyone give me good advice as to how to tell if your welds are up to cert standard? Just weld some things together and take them to your local certifier to be inspected? I would like to do it myself as it will save time/money, but while I think my welds are ok, I don't know they are, if that makes sense. Can I tack things together then just get someone to finish weld it, or will the tacks ruin the weld bead and make it look shoddy? Quote Link to post Share on other sites
Nominal 54,921 Posted August 2, 2019 Report Share Posted August 2, 2019 15 minutes ago, WhangareiKE70 said: Can anyone give me good advice as to how to tell if your welds are up to cert standard? Just weld some things together and take them to your local certifier to be inspected? I would like to do it myself as it will save time/money, but while I think my welds are ok, I don't know they are, if that makes sense. Can I tack things together then just get someone to finish weld it, or will the tacks ruin the weld bead and make it look shoddy? I built my own rear trailing links and such with a MIG. No particular inspection or weld testing was needed. If its a critical weld (e.g. front suspension) then NDT is required. Otherwise just reasonable quality welds seem to be OK. You can check with the local C-man if you like. 1 Quote Link to post Share on other sites
WhangareiKE70 502 Posted August 2, 2019 Author Report Share Posted August 2, 2019 I will likely make the body mounts up, tack them in, then get him to come inspect, and at the same time show him some welds I've done on some scrap of a similar thickness. Then I can get a yes/no/some improvement needed, and then at least I know where to go from there. Quote Link to post Share on other sites
cletus 38,244 Posted August 2, 2019 Report Share Posted August 2, 2019 Shiiiit that crash sucks. I've also been hit by a pissed idiot when I was in a van, not as bad as you though. Didn't want another van without engine in front after that Good to hear you're coming right Quote Link to post Share on other sites
MACKAZ 2,903 Posted August 2, 2019 Report Share Posted August 2, 2019 Shit son. Where was your smash? Quote Link to post Share on other sites
WhangareiKE70 502 Posted August 2, 2019 Author Report Share Posted August 2, 2019 14 hours ago, cletus said: Shiiiit that crash sucks. I've also been hit by a pissed idiot when I was in a van, not as bad as you though. Didn't want another van without engine in front after that Good to hear you're coming right Cheers mate. Yeah, the only saving grace was that it was a 4wd van, so when we hit we essentially went over the bonnet of his little Corolla and then rolled. In a normal height Hiace, where he hit first (straight into the drivers A-pillar with about half a cars overlap, I was already well off the road trying to avoid him) would have been my legs gone. As it was I have a couple of gnarly scars on the shin of my right leg, but no damage to them other than that. Damage to the van was intense, front RH suspension was ripped out, wheel was in about 30pcs. 12 hours ago, MACKAZ said: Shit son. Where was your smash? On Mangakahia Rd, about 3kms from the Maungatapere turnoff (there is a little bridge just past Tattons Rd if you know the area). Only about 2 kms from home, we had driven from Pukekohe that day without incident, then get hit by this idiot just before getting home. On a fine day you can still see the marks on the road from where he locked up and skidded, and then where his engine leaked oil all over the road once he hit us. This is almost 5 months later now. 1 Quote Link to post Share on other sites
yoeddynz 21,290 Posted August 4, 2019 Report Share Posted August 4, 2019 Faaaaaark @ that crash. Seeing that only goes to put another nail in the coffin for our van. Ours is a 4wd hiace too. It puts the willies up me when we find a tourist coming round a corner on our side so I tend to drive it in super slow cautious mode. But not much one can do when a drink idiot crosses a centre line etc. We've been planning a replacement for many years now, similar to what you're doing but with an old Bedford truck cab. Anything that ends up higher and with an engine in the front eh. I hope your back recovers awap and it all comes right. Really interested to see your tiny house build. It's certainly something we'll see more of as house prices get ever more ridiculous eh! 1 1 Quote Link to post Share on other sites
WhangareiKE70 502 Posted August 4, 2019 Author Report Share Posted August 4, 2019 12 minutes ago, yoeddynz said: Faaaaaark @ that crash. Seeing that only goes to put another nail in the coffin for our van. Ours is a 4wd hiace too. It puts the willies up me when we find a tourist coming round a corner on our side so I tend to drive it in super slow cautious mode. But not much one can do when a drink idiot crosses a centre line etc. We've been planning a replacement for many years now, similar to what you're doing but with an old Bedford truck cab. Anything that ends up higher and with an engine in the front eh. I hope your back recovers awap and it all comes right. Really interested to see your tiny house build. It's certainly something we'll see more of as house prices get ever more ridiculous eh! You can never 100% plan for idiots unfortunately. Back should be good, I am going to be easing back into the gym this month, at the recommendation of my physio, so gives an idea of how far it's come already. I have a little Suzuki Vitara offroader, a Lexus LS430 UL daily, and the tiny house, so the plan is to do a "Hayden's other projects" thread where I exhibit how fuckin' good I am at spending all of my time and money on stuff and things (this doesn't include my Suzuki GSF250, the trailer project I bought and haven't done anything with yet or the other 1,000,000 things on my to-do list). 2 Quote Link to post Share on other sites
tortron 61,765 Posted August 4, 2019 Report Share Posted August 4, 2019 Could have been worse if it was a Datsun/mitsi and the front was made of nutech though eh Quote Link to post Share on other sites
MACKAZ 2,903 Posted November 16, 2019 Report Share Posted November 16, 2019 Hooting. Nice work my man. Top notch. 1 Quote Link to post Share on other sites
Willdat? 4,151 Posted January 20, 2020 Report Share Posted January 20, 2020 Love your work BTW, this is one of my favourite OS projects. The 4x4/720/Kingcab combo makes me swoon even in stock form. 1 Quote Link to post Share on other sites
WhangareiKE70 502 Posted January 20, 2020 Author Report Share Posted January 20, 2020 Cheers @Willdat?, yeah it's pretty cool, I'm not sure if it's a good thing or what that it's at the stage it is now, but had I not pulled it to pieces when I was younger with no real way of fixing things I likely would never have dived this far in and it almost would be stock. But such is life/projects, it gets away on ya. One thing I would really like to do in the future once this is done is to get a 2wd version and do the opposite of this, slammed, maybe an SR20DET, Silvia suspension all around. Then put it on a trailer behind this to tow it to the track haha. But like I keep having to tell myself, no new projects until I finish this one (/then buy a house probably). Quote Link to post Share on other sites
Roman 13,455 Posted July 1, 2020 Report Share Posted July 1, 2020 I just caught up on this thread - holy shit about that crash! Glad you were okay from that. This is looking friggen awesome, A++ 1 Quote Link to post Share on other sites
WhangareiKE70 502 Posted July 1, 2020 Author Report Share Posted July 1, 2020 Thanks @Roman, yeah about 16 months on now the old back is about as healed as it will ever be, but mostly good. It's all starting to take some sort of shape, which is good, still hoping to get it done this year, but so much has come up financially/in general that it might be a bit of a mission. Definitely ready for Nats 2021 though. 1 Quote Link to post Share on other sites
