Indiana_Jones Posted July 24, 2018 Posted July 24, 2018 https://oldschool.co.nz/index.php?/topic/59315-indiana_jones-1987-jaguar-sovereign-xj40/ (Shameless ripoff of Thousand Dollar Supercar's thread) Quote
Toyo Posted July 25, 2018 Posted July 25, 2018 Tidy old 40 youve got there don't see many good digi dash cars these days. I've got the same deadly disease I've got a 93 xj6 sport. Not currently near my car although from memory it sits around 14.5volts. Haynes manual specs say 13.5 to 15 then load it up with lights heater blower etc and it should drop then come back up. All your earth's and connectors ok? Quote
Lord Gruntfuttock Posted July 25, 2018 Posted July 25, 2018 Good advice that, bad return paths cause lots of problems. Anything I build has earths solidly connected to bare metal each end, and a heavy duty braided strap between engine block and chassis... Quote
Carsnz123 Posted July 25, 2018 Posted July 25, 2018 Waddaya mean by charging issue? Battery going flat? Those number seem ok. A little on the soft side with the lights on. Quote
Indiana_Jones Posted July 26, 2018 Author Posted July 26, 2018 Cheers for the comments, yeah she seems to be losing charge and the battery is going flat (battery is around a year old). I'll see if I can measure the discharge with the car off to see if it's within the acceptable range or not, and go over the various electrical connections and see if they're all clean and tight etc. Quote
Thousand Dollar Supercar Posted July 26, 2018 Posted July 26, 2018 Jaaaaaaaaaaaaaaaaaaaaaaaaaaaaaag. Tell 'er indoors that you've bought at the right time - could be a nice little earner. Quote
kyteler Posted July 27, 2018 Posted July 27, 2018 On 25/07/2018 at 20:14, Carsnz123 said: Waddaya mean by charging issue? Those number seem ok. No they're not. The battery should sit above twelve on its own and with the alternator running should be between thirteen and a half and fourteen and a half volts. If it's dropping to battery voltage with the alternator running then the alternator is not taking the load. The alternator not doing its job is the likely cause of the battery going flat and if its been doing it a while then it could have fucked the battery early. Check the basics though. Belt tension and connectors first. Quote
Indiana_Jones Posted July 27, 2018 Author Posted July 27, 2018 Well it is reading around 13.5v with the engine running, so there is charge, but it drops down to around 12.9v once you hit the lights on, but as I understand, it should dip down, but then rise again to same voltage before (i.e. 13.5v in this case). Quote
xsspeed Posted July 27, 2018 Posted July 27, 2018 Its been a while since i was last diagnosing charging issues but 13.5 feels on the low side for running but no other load My last issue on ae82 was the alternator itself but they are a pretty easy and plentiful swap so just grabbed a spare Quote
dr.wylde Posted July 29, 2018 Posted July 29, 2018 Hey Indy My wife has an XJ40 on our driveway awaiting repairs. Does your self leveling suspension in the rear work? Fantastic cars, go well too (when they do go) Quote
Indiana_Jones Posted July 30, 2018 Author Posted July 30, 2018 Hey mate, I don't believe that it does. I think it's still connected, as I can feel some sort of pipe going to the rear shocks, but need to get the wheel off and confirm. Does yours have it still in place? as apparently a lot of cars have had it removed over the years, simply to save the hassle of maintaining them. You can buy kits to remove the system, which seems to be the recommendation, but I believe that you can still get parts for the SLS system if you're keen to keep it. Assuming mine is still installed, I'm not sure what I'd do with it, part of me leans to removing it, for simplicity's sake, the foamer side of me would be keen to keep it lol. Let us know how you get on with yours. And agreed, they are lovely cars _b Quote
Indiana_Jones Posted November 25, 2019 Author Posted November 25, 2019 Been a while, work and house etc getting in the way. Having issues with the brakes, VCM is saying low pressure and the pedal is sinking to the floor. I've bled the system and I'm fairly confident there's no air in it. I think the fluid is going down after using the brakes, but can't see any obvious signs of leaks under the M/C or from the pedal box (but will double check). Is this a Master Cylinder failure? or perhaps a failure in pressure switch where the brake booster/accumulator meets the brake lines? New accumulator sphere needed? Thought I'd post this here, to see if anyone else had any ideas, cheers! Quote
fuel Posted January 18, 2023 Posted January 18, 2023 is that a blend on the same panel? can't quite tell in the pic. Are you saying the left portion is the new paint and the right portion is the existing paint? to me yes the paint colours aren't a match but also it seems the blend is quite abrupt. Quote
Indiana_Jones Posted January 18, 2023 Author Posted January 18, 2023 51 minutes ago, fuel said: is that a blend on the same panel? can't quite tell in the pic. Are you saying the left portion is the new paint and the right portion is the existing paint? to me yes the paint colours aren't a match but also it seems the blend is quite abrupt. Correct, left is new and right is old. Yes the blend is abrupt, that's just down to my shoddy painting and couldn't quite see it look that bad during the process. Quote
fuel Posted January 18, 2023 Posted January 18, 2023 The width of the panel is too small to blend that, you would want to paint the whole panel and then blend the surrounding panels. Quote
tortron Posted January 18, 2023 Posted January 18, 2023 I'm no painter but 3 minutes ago, fuel said: The width of the panel is too small to blend that, you would want to paint the whole panel and then blend the surrounding panels. I do about 2 paint fan lengths from the repair and then a 3rd for the clear Quote
Indiana_Jones Posted January 18, 2023 Author Posted January 18, 2023 9 minutes ago, fuel said: The width of the panel is too small to blend that, you would want to paint the whole panel and then blend the surrounding panels. Thanks for the tip, when you say the width of the panel, do you mean heading towards the right in the photo? (which is the boot lid). I can make a MS paint special later, but what I have done is painted the panel that is at the base of the rear screen and then have gone around 3 inches onto the boot lid to try and blend from there. Here's another photo for reference Quote
