Tidy old 40 youve got there don't see many good digi dash cars these days. I've got the same deadly disease I've got a 93 xj6 sport.
Not currently near my car although from memory it sits around 14.5volts. Haynes manual specs say 13.5 to 15 then load it up with lights heater blower etc and it should drop then come back up. All your earth's and connectors ok?
Link to post
Link to post
Cheers for the comments, yeah she seems to be losing charge and the battery is going flat (battery is around a year old). I'll see if I can measure the discharge with the car off to see if it's within the acceptable range or not, and go over the various electrical connections and see if they're all clean and tight etc.
Link to post
On 25/07/2018 at 20:14, Carsnz123 said:
Waddaya mean by charging issue? Those number seem ok.
No they're not.
The battery should sit above twelve on its own and with the alternator running should be between thirteen and a half and fourteen and a half volts. If it's dropping to battery voltage with the alternator running then the alternator is not taking the load.
The alternator not doing its job is the likely cause of the battery going flat and if its been doing it a while then it could have fucked the battery early.
Check the basics though. Belt tension and connectors first.
Link to post
Well it is reading around 13.5v with the engine running, so there is charge, but it drops down to around 12.9v once you hit the lights on, but as I understand, it should dip down, but then rise again to same voltage before (i.e. 13.5v in this case).
Link to post
Its been a while since i was last diagnosing charging issues but 13.5 feels on the low side for running but no other load
My last issue on ae82 was the alternator itself but they are a pretty easy and plentiful swap so just grabbed a spare
Link to post
Hey mate, I don't believe that it does. I think it's still connected, as I can feel some sort of pipe going to the rear shocks, but need to get the wheel off and confirm.
Does yours have it still in place? as apparently a lot of cars have had it removed over the years, simply to save the hassle of maintaining them. You can buy kits to remove the system, which seems to be the recommendation, but I believe that you can still get parts for the SLS system if you're keen to keep it.
Assuming mine is still installed, I'm not sure what I'd do with it, part of me leans to removing it, for simplicity's sake, the foamer side of me would be keen to keep it lol.
Let us know how you get on with yours.
And agreed, they are lovely cars _b
Link to post
  • 1 year later...
Been a while, work and house etc getting in the way.
Having issues with the brakes, VCM is saying low pressure and the pedal is sinking to the floor. I've bled the system and I'm fairly confident there's no air in it. I think the fluid is going down after using the brakes, but can't see any obvious signs of leaks under the M/C or from the pedal box (but will double check).
Is this a Master Cylinder failure? or perhaps a failure in pressure switch where the brake booster/accumulator meets the brake lines? New accumulator sphere needed?
Thought I'd post this here, to see if anyone else had any ideas, cheers!
Link to post
