Lump
  • Content count
    460
Everything posted by Lump
  1. Tumeke's Wolseley 6/110 discussion
    This is quite a fleet you've got going here! I'm very jealous
  2. Adoom's 1976 Triumph 2500 TC
    Like you I usually use the Kyteler/Hemi method which works 95% of the time - when something being a bit of a cunt (usually the jag where the rear pipes has lots of ups and down or if a systems been completely drained) and still has a small amount of air somewhere in the system bleed as per above and then go around each corner again this time get someone to pump the brake pedal a few times and then hold it down while you crack open your bleed nipple and then tighten it before they release then pedal you should only need to do this once or twice at each corner. This pressurizes the brake fluid and makes the air into larger bubbles rather than lots of tiny ones which sometimes can't be seen you should get a few bubbles at the affected corners (no way of knowing which ones they are so do them all).
  3. Adoom's 1976 Triumph 2500 TC
    PI dash is the same size - you can get the center panel as well which is where the clock moves to on the PI models
  4. Adoom's 1976 Triumph 2500 TC
    Yeah I don't recall mine ever working either - might be able to clean out the rheostat to see if it helps. If its anything like the Jag it'll be pretty dim at full power anyhow
  5. Adoom's 1976 Triumph 2500 TC
    The knob you're asking about is for dimming the instrument lights
  6. GreenTC's 1978 Triumph 2500TC.
    Looking sharp! You got a good score with that crack free dash and interior parts
  7. Rookie Dave's Jag S-Type
    Uggh not fun. Did mine last year - I won't offer any advice because I obviously muffed it - hand brake pads came off the backing caused all sorts of weird issues (brakes sticking in reverse etc) Half way through fixing it now (I've taken the handbrake system off while waiting for the parts to arrive)
  8. Sam's 8th Triumph 2500 "S"
    Nice score on the spare parts, those side repeater lamp are impossible to find for one side (can't remember which one though)
  9. SP450andLE's Dad's Daimler SP450
    'Occasional' rear seats
  10. SP450andLE's Dad's Daimler SP450
    Nice car Apparently the Majestic Majors were pretty quick for a large four door, it must be crazy fast in a small fibreglass 2 seater
  11. prozac's 1275 gt
    If you're still after wheel bearings Wilson Bro's in Annex road seem to be pretty cheap. I got bearings and seals for both front wheels of the Jag for less than $80, the best quote I'd had before this was $80 for one side.
