yoeddynz
  • Replies 840
3 minutes ago, RUNAMUCK said:
I wonder if it would fit a 1985 Johnno?
There's quite a few bucks in the new lower unit gears and rebuilt tilt ram.
Pretty sure yours will be a cross flow, you would probably need the adapter for the midsection from a looper and the pan and cowling a different as well. Is yours a 20" or 25"?
I've checked and a corvair engine won't fit.
Neither will a Rover V8 (maybe if mid mounted and the seats move forward or front mounted and you have chinese concubine feet)
A daimler V8 engine will fit mid or rear mounted.
  • 4 weeks later...
I've just come to realise that Postimage has changed its domain name over from .org to .cc which has resulted in all my previous photo links not working anymore. This has affected this thread and all my others (most likely many other threads out there too )
 Its like photobucket all over again!  I'd use this board to host the photos but I also post my threads up on two other forums so easiest to use a hosting site.
Bummer!
Off to bed.
  • Sad 1
  • 4 weeks later...
The yellow ones? Yeah. A bit better but not twice the price better.
Is seems to be the crimping that fails. One a few wire strands have gone they get loose and come out easier in a progressively (?) shorter time. I reckon a cup wheel where the stands are held together by weld/bronze/solder so they just wear down rather than fly out.
