Crossed two things off the list. Engine mount and measure/order the shock. I've made a template for one side of the shock reinforcement buy I'll need to get some steel for that
Barryd up the engine mount with a piece of the cut off stem
IMG_20181006_195606615
Painted and done
IMG_20181007_170832815
  • Replies 172
I did lots of fabricobbling today. My inner Barry was strong. Cad (cardboard aided design) thanks to shapes and krispy kreme
I made a plate for each side for the shock relocation (and fucked up measuring the new holes)
IMG_20181014_103707258IMG_20181014_112220112IMG_20181014_112244294
Weldy weldy
IMG_20181014_124949550
The other side
IMG_20181014_122748671
Coil mounting holes
IMG_20181014_130015639
weldy weldy
IMG_20181014_131419798
The tecnigas flange is smaller than the port in the barrel which wont be helping the nangs. I ordered some tube and a couple of flanges but wrote down the wrong part number and ended up with 38mm flanges instead of the 28mm I needed.
CAD again, careful tapping around the outside to get the flange outline and hole centers
IMG_20181014_133629841
Trace horribly onto some plate, Mark the holes in the wrong place
IMG_20181014_133641428
The closest size Holesaw I had was a 32mm so I'll have to double up on the pipe or just run the 32mm pipe for the header to the expansion chamber.
A bit of Double sided holesaw action and a turn on the belt sander.
2018-10-14_09-17-43
Not perfect but nothing a bit of attention from the die grinder can't fix.
IMG_20181014_145820726
About this time I for fucked off with propping this up with bits of wood and it falling over all the time so made a start on the side stand. I had chopped off the center stand to clear the engine mount
2018-10-14_09-26-45
That's not going to fit. I chopped off the bracketry and tacked it onto the mounting bracket for the plastics
2018-10-14_09-27-07
It clears the motor now. The floor brackets were flexing a bit so I barried up a brace to the engine mount
IMG_20181014_193207188IMG_20181014_202502778
IMG_20181014_204618670
I got tired at this point and my welding got worse than usual. I'll give it a tidy up later but for now everything lines up and it'll bolt on and off relatively easily.
I messed up the spacing a bit for the nut, you have to put the nut in first before sticking the engine mount bolt through. Its a bit fiddly but not a major as its not something thats going to get taken out a whole lot.
So the list of things to do (in no particular order)
Make a mount for the front plastics
Make a headlight mount and mounts for the melody plastics
Trim melody plastics to suit Master cylinder
Drill plastics to suit Dio ignition switch
clean and paint frame and brackets
Make a tail light bracket
Wire up tail lights
Make up the header tube to expansion chamber that wont melt/touch the plastics
Finish off Rear shock mount (weld washers/bolt in place and make a spacer)
Machine Variator bush so I can actually bolt it up
Fit new belt
Tune and do some whoolies
What do you do when you have a big list of things to do and a deadline? Buy another project of course.
IMG_20181015_194605473
I filled it with fresh fuel and noticed the oil tank also filled itself with fuel so duped some 2 stroke oil in the tank.
Bit of crc down the carb and it started.
The throttle cable was seized so off to the hoard and I found one that was less seized and fitted it, It only sticks on half throttle now. The exhaust was missing and the motor looked similar to the one in the melody, surprisingly it actually fitted.
Went for a test ride and goes pretty good, my feet only just fit on the foot rest
IMG_20181015_165253674
I gave the garage a quick tidy and lined them up for a family photo
IMG_20181015_203221014
  • Like 8
I finished off the exhaust mount and chucked some high temp paint on it. I will be wrapping it so I figured I'd give it every chance I could. I was hoping for a white or yellow but supercheap had no stock of the higher temp stuff in those colours so I decided on silver
IMG_20181022_112321033
Barried up a coil mount.
IMG_20181022_122152382
I'd been putting off doing the fork seals for ages as I thought they would be a pain, they took less time than the coil bracket. They were well due to be done. The forks stick out above the clamps a bit and hit the plastics so before I reassemble them I'll borrow a lathe and shorten them. I gave one fork a bit of flap wheel loving so it should clear the new rotor bolts.
Too easy, just undo the bolts at the bottom and release the schmoo
IMG_20181022_124147814
Out with the old
IMG_20181022_124501881
New seals in
IMG_20181022_125839981
Any reason you're wrapping it? I assume it's just to avoid burnt legs as there's no performance advantage.
Make sure you leave the first 50mm (at least) of the header unwrapped, otherwise it'll have a detrimental effect on your spanny's ringadingability.
Great work by the way!
Its to avoid melting the plastics even more than they are more than anything.
Changing the length of the primary pipe also will change/move the ring a dings so I've got that against me too. The barry in me hopes they will cancel each other out but it'll probably make it worse. If the wrap makes it super shit I can always take it off. I need to get it running and see how it goes.
I had no atf or fork oil so shoved some power Steer fluid in the forks. It might be a tad light but it'll do for now.
IMG_20181022_173421574
I went to test fit the plastics and realised the oil tank outlet is exactly where the shock is. Guess I'll have to learn how to plastic weld.
IMG_20181022_200331958
I fitted the new handgrips to make myself feel better.
IMG_20181022_214614958
Finally found the China death spec pad that was supplied with the 4pot calipers. It was in a random tin with some coins in a pile of crap. Fitted them up after spending some time trying to work out how to get the bleed Nipple to the top. Turns out the calipers are meant to be upside down. Took ages bleeding them up but i got there in the end.
After some homework I've found some quality pads that will work on these calipers. Only problem is they don't exist in nz. I've found a wholesaler here who can get some but I'll have to order 10 sets.
IMG_20181025_221958552
Crossed a few things off the list
IMG_20181025_224154297
@Raizer overnighted a jet set and exhaust gasket as I've lost the last three he has sent me so once I barry up the oil tank I can try tune it.
I took it for a quick roll down the drive and the power steering fluid is a bit on the light side so I'll try find some atf
One day you'll pull something out of the back of the fridge or somewhere and find enough jets to tune 50 scooters!
Looking good though man!
Few small things ticked too tonight
Coil earth sorted
IMG_20181026_200730189
I let my inner barry run free and re did the oil tank outlet. Nothing but the finest hoardings
IMG_20181026_204331317
Mixed up some epoxy on a nice clean surface and slapped it on
IMG_20181026_205500106
It even fits now and doesn't leak, just to be doubly sure of it not leaking I'll give it a quick sand and another layer of epoxy tomorrow
2018-10-26_10-50-42
While I waited for the epoxy to set I gave the squash carb a brakeclean rebuild and a quick adjustment. It actually stayed running this time and didn't flood. I took it for a quick pest down the road to the park. The squash has a semi recent white plate so I/ hoping I can go to vtnz and just fill in relevant paperwork and re register it without too much fuss
2018-10-26_10-45-32
21 minutes ago, 64valiant said:
Making some good progress man.
Can't wait to see this thing hoon.
Thanks.
I'm itching to get it out for a shakedown
Today is going fantastic. Squash is now registered which is great. Inspector just had a look at it/found chassis number and we had van sharns.
IMG_20181027_090944875
I threw together the wiring on the melody and chucked the biggest jets in the carb and it fired up. Took it for a squirt up the drive and it goes well mega rich but that's easy to fix.
IMG_20181027_113953155
Time for a nap and some lunch and I can smash everything else out.
