Willdat? Posted July 19, 2018 Posted July 19, 2018 22 hours ago, chris r said: More surprises These look like NC30 wheels - I wish I was 5ft7 so I could fit one without looking comical 3 Quote
chris r Posted July 19, 2018 Author Posted July 19, 2018 1 hour ago, Willdat? said: These look like NC30 wheels - I wish I was 5ft7 so I could fit one without looking comical That they do! I thought i was being greedy getting 10 inches Quote
chris r Posted July 22, 2018 Author Posted July 22, 2018 Another nifty/melody popped up on facebook complete with a black plate. One cheeky low-ball and some negotiation later Last reg in 86 I'll fire a email off to the relevant person so I can hopefully run it 3 Quote
chris r Posted July 22, 2018 Author Posted July 22, 2018 While motorvation was actually present I had a look at the mount I got from the states. The stabilizer bracket didn't line up at all so I chopped it off. Success. It now fits. Now is the wheel even slightly centered. Double success Center stand will need to be removed but I was expecting that. Prior to removal from the dio the motor felt a bit down on power and was missing intermittently. The miss turned out to be a burnt/loose coil terminal. I ordered some more bits from @Raizer and this arrived Can't complain at the thoroughness of the packaging. He ensured nothing could move in the box and be damaged I pulled the plastics off the motor Head gasket is chooched and was leaking Whipped the barrel off and popped the piston out. Nice new piston and barrel Refer back to a photo of it being assembled here. I replaced the clutch springs and clutch bell along with the final drive oil I went to replace the variator with something that wasn't $20 from aliexpress and the sleeve it slides on is slightly thicker than the Honda one. Does anyone have a bush reamer I can borrow? The pins are too hard to try cut or butcher with my tools. I swapped the leaking forks off the zx dip for some that don't and test fitted the brakes. Another success (mostly). I just need a tiny spacer and possibly some filing of the fork I have to decide which frame I want to cut up now as the disc stem is shorter than the melody and wont fit. I've got a dio frame that it works with which I plan to weld on. I'm hoping it'll clear the melody plastics and I can use the mudguard but haven't had a look at that yet 2 Quote
chris r Posted July 31, 2018 Author Posted July 31, 2018 Picked up the wheels today. New set of Michelin s1 and a wheelbarrow spec front for eastcape Satdee im planning to dummy up the dio stem onto the melody frame and seagull it together 6 Quote
chris r Posted August 1, 2018 Author Posted August 1, 2018 Yeah the wheel could do with a tidy up but that requires time and effort 2 Quote
chris r Posted September 15, 2018 Author Posted September 15, 2018 I needed to somehow get the Dio stem to fit onto the melody frame. The melody tube is longer and thicker than the dio. Since IT was thicker I gambled that the thinner dio stem tube would fit the melody. Both frames had a date with the grinder and it mostly worked Melody vs dio I'll save those bits for mounting the plastics later Some A+ Grinding skills Couple of tacks and a test fit, Its a bit high so I raised the tube as much as I could. GTFO stand, I can't mount my engine properly In my wisdom I threw out the dio handle bars and of course the melody ones don't fit the Dio stem. I think one of the other nifty bars fitted the dio stem so I'll check my hoard 4 Quote
flyingbrick Posted September 15, 2018 Posted September 15, 2018 Dude, i really like the way you did the stem swap.. smart way of keeping everything straight!!!! 2 Quote
chris r Posted September 15, 2018 Author Posted September 15, 2018 9 minutes ago, flyingbrick said: Dude, i really like the way you did the stem swap.. smart way of keeping everything straight!!!! I didn't trust myself to get it straight any other way really. I eyeballed the angles and they looked to be the same. I guess I'll find out how it behaves once I get it running Quote
Raizer Posted September 15, 2018 Posted September 15, 2018 Pretty sure I've got some AF35 bars kicking about if Nifty don't fit Quote
chris r Posted September 19, 2018 Author Posted September 19, 2018 Thr melody i got for parts is in better condition than the 'good' one. Looks like it got warm and ate some rings. I measured and @Raizer ordered me a set of rings. I choose the least scored piston and gave the barrel a quick hone to knock off the rough edges. I'll fit the other gudgeon pin circlip and make a good old cereal box gasket and see if it'll run 2 Quote
chris r Posted September 23, 2018 Author Posted September 23, 2018 Reassembled and made one carb out of the two I had. Wound it over and nothing happened, gave it a dose of crc and a couple of coughs but that's it. Im guessing the barrel is too scored or a tad oversize and tge rings aren't sealing properly. The barrel seemed to slide over the rings too easily when assembling it. I went to measure up for a new rear shock and realised that the starter was hitting the mount. The mount will clear the starter, but once its flipped its not centered anymore. Back to the drawing board for that one. I dummied uo the plastics to feel like I've done something today. The dio triple tree is a interfere fit with the plastics so out with the hole saw . 4 Quote
chris r Posted October 1, 2018 Author Posted October 1, 2018 I had a nice surprise turn up to work tiday thanks to @Get it done. Progress should be a bit quicker now I can Barry away after work. Made a list to clear my head a bit and help prioritize things and work out some sort of plan. I've got a shopping list of exhaust stuff which ill order tomorrow 7 Quote
