Not-a-number Posted November 15, 2023 Share Posted November 15, 2023 4 hours ago, tortron said: How's that for project creep Yeah its gotta get a lot more out of hand if I want to have a chance of finishing it! Quote Link to comment Share on other sites More sharing options...
shrike Posted November 16, 2023 Share Posted November 16, 2023 Did the original chassis have the speed holes (dimples) in it? are you using similar materials or updated to modern specs? Quote Link to comment Share on other sites More sharing options...
Not-a-number Posted November 16, 2023 Share Posted November 16, 2023 1 hour ago, shrike said: Did the original chassis have the speed holes (dimples) in it? are you using similar materials or updated to modern specs? Yeah they do have speed holes. Backed with an ali sheet. Can see them here. Original material was a mild steel. Probably low grade (in todays standards and variable. ‘Low background’ pre war stuff so you can’t really buy that. So they’re done from G250 mild steel (I think, maybe it was G300). Either way, in theory significantly more consistent and stiffer than the original.  9 Quote Link to comment Share on other sites More sharing options...
shrike Posted November 16, 2023 Share Posted November 16, 2023 3 hours ago, Not-a-number said: Yeah they do have speed holes. Backed with an ali sheet. Can see them here. Original material was a mild steel. Probably low grade (in todays standards and variable. ‘Low background’ pre war stuff so you can’t really buy that. So they’re done from G250 mild steel (I think, maybe it was G300). Either way, in theory significantly more consistent and stiffer than the original.  Awesome, is there any logic to the placement of the speed holes? are they actually dimpled or just hole sawed out? Guessing the backing was for weight saving/aerodynamics? Quote Link to comment Share on other sites More sharing options...
VitesseEFI Posted November 16, 2023 Share Posted November 16, 2023 Somehow I’ve not previously seen this thread… so I’ve just had the jaw-dropping experience of reading it from end to end Bloody hell…… no messing!  Thought the block casting was epic… but that sump!! So he goes and makes several This does actually deserve the word AWESOME! 8 Quote Link to comment Share on other sites More sharing options...
dabuzz Posted November 16, 2023 Share Posted November 16, 2023 Just jaw dropping stuff, love this build Probably wasn't the done thing back then, but engineering some negative camber into it while you're there wouldn't be such a bad thing imo Quote Link to comment Share on other sites More sharing options...
Not-a-number Posted November 17, 2023 Share Posted November 17, 2023 20 hours ago, shrike said: Awesome, is there any logic to the placement of the speed holes? are they actually dimpled or just hole sawed out? Guessing the backing was for weight saving/aerodynamics? Seems like they put them everywhere they could except for main mounting points. Like engine, gearbox, bulkhead and braces. Left about ~30-40mm material from the edges and to each hole. Not dimpled just straight through. The holes save 7kg total. Which is a bit when the whole car had a max weight limit of 750kg. The Ali backing to the holes keeps everything closed off. Since thats the cockpit. Aero/keeping junk out 5 hours ago, dabuzz said: Just jaw dropping stuff, love this build Probably wasn't the done thing back then, but engineering some negative camber into it while you're there wouldn't be such a bad thing imo  Not that Ive ever driven anything with positive camber but the prewar cars usually had it so that there was no scrub radius. Puts the contact patch right through the king pin to give light steering.  3 1 Quote Link to comment Share on other sites More sharing options...
Not-a-number Posted November 17, 2023 Share Posted November 17, 2023 7 hours ago, VitesseEFI said: Somehow I’ve not previously seen this thread… so I’ve just had the jaw-dropping experience of reading it from end to end Bloody hell…… no messing!  Thought the block casting was epic… but that sump!! So he goes and makes several This does actually deserve the word AWESOME! Thanks appreciate it. Quote Link to comment Share on other sites More sharing options...
JustHarry Posted November 18, 2023 Share Posted November 18, 2023 23 hours ago, Not-a-number said:  Not that Ive ever driven anything with positive camber but the prewar cars usually had it so that there was no scrub radius. Puts the contact patch right through the king pin to give light steering.   On 17/11/2023 at 11:19, dabuzz said: Just jaw dropping stuff, love this build Probably wasn't the done thing back then, but engineering some negative camber into it while you're there wouldn't be such a bad thing imo Like @Not-a-number says for light steering is a big thing but its a major handling stability reason for having positive camber on beam axle vehicles. Negative camber creates positive scrub radius which makes them handle poorly. Surprisingly enough Bugatti had the front end alignment pretty well sorted for the wheel/tyre combos of the time 4 1 Quote Link to comment Share on other sites More sharing options...
anglia4 Posted February 9 Share Posted February 9 Looking good! I love a nice detailed 3D model. 1 Quote Link to comment Share on other sites More sharing options...
Not-a-number Posted February 11 Share Posted February 11 On 08/02/2024 at 20:41, anglia4 said: Looking good! I love a nice detailed 3D model. Thanks. Doing a proper 'functional' detailed CAD takes a lot of time. I think what I have now will keep me going for a while once I can start making things again! 3 Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted February 11 Share Posted February 11 On 17/11/2023 at 17:00, Not-a-number said: Seems like they put them everywhere they could except for main mounting points. Like engine, gearbox, bulkhead and braces. Left about ~30-40mm material from the edges and to each hole. Not dimpled just straight through. The holes save 7kg total. Which is a bit when the whole car had a max weight limit of 750kg. The Ali backing to the holes keeps everything closed off. Since thats the cockpit. Aero/keeping junk out  Not that Ive ever driven anything with positive camber but the prewar cars usually had it so that there was no scrub radius. Puts the contact patch right through the king pin to give light steering.  came here to ask why they had positive camber- reason makes sense! Might look weird if you reduce it (I know you wont anyway because you want this thing to be as close to origional as possible) 1 Quote Link to comment Share on other sites More sharing options...
yetchh Posted April 4 Share Posted April 4 Your dad has some skills.. Nice work. 3 Quote Link to comment Share on other sites More sharing options...
GregT Posted April 4 Share Posted April 4 On 18/11/2023 at 16:49, JustHarry said:   Surprisingly enough Bugatti had the front end alignment pretty well sorted for the wheel/tyre combos of the time Ettore knew what he was doing. Even if most of his stuff is fiendishly difficult to reproduce. The chassis forgings where tube meets rail are state of the art for the period. Welding at the time wasn't trusted - with good reason. Looking forward to seeing the clutch parts done. The Bugatti clutch is a clever semi-centrifugal device. Keep up the good work. 1 Quote Link to comment Share on other sites More sharing options...
skidmark Posted Thursday at 14:46 Share Posted Thursday at 14:46 Hi Peter; You mention that you plan to nickel-plate the lovely radiator-shrouding that your Dad has fabricated. My information suggests that Bugatti radiators were customarily finished in an alloy called "German Silver". This may not necessarily apply to the T59, but it may be worth checking out before you get any plating done. The other thing that might be important to understand is that modern nickel-plating is NOT the same as what was used in pre-War Europe (the modern version was invented in the USA, and was only used sparingly there until after WWII). The 'old school' nickel-plating used on Bugattis used a process nowadays known as "electro-less nickel-plating". You should be able to find a workshop in NZ that will still do it. The result is soft and has a satin finish that will buff up quite well, but it is much more durable than the thin, shiny and brittle modern equivalent. You need to specify a minimum coating of 12 microns. The original GP Bugattis didn't have plating on many of their steering and suspension parts, instead leaving the steel in polished form. Die-hard authentic Bugattistes will still opt for this, but you need to devote regular sessions for careful application of moisture resistant coatings to the polished parts, and keep the car in a low-humidity environment. Old school nickel-plating may be a practical option, but - whatever else you may decide - please don't plate your front axle! That would constitute a cardinal sin!!! Your CAD drawing of your proposed steering box appears to differ visually from the T57 steering boxes that I am familiar with - maybe that's the case for T59 steering boxes, but I wouldn't know. The T57 steering box has radial strengthening ribs between the main gear-housing and the attached boss around the drop-arm actuator. I only know this because the steering box in my T49 project is actually off a T57, and it looks quite different to the usual touring Bugatti steering boxes that were fitted to T40, 44, 49 etc., which also look more like your CAD drawing. I'll attach a pic of a T44 and a T57 steering box to show you what I mean. Very excited to see the progress that you're making! Cheers, Michael Anderson 7 Quote Link to comment Share on other sites More sharing options...
