shit that's going to be a large motor!
i had in my head that those parts were the profile of the crankcase and that part housed the crank gear like a standard engine would have a timing gear case on the front of the block
  • Replies 250
Yeah its pretty big.
Banana for scale.
Also mm for scale. Its about 1020mm long.
About 700mm tall
  • Thanks 2
The mandrel is spaced apart like that so that if we cant form it by hand and need to make hydraulic tooling theres some room to put it behind the rail.
Ideally it would only be 100mm apart. Save some weight!
32 minutes ago, anglia4 said:
what thickness is the chassis that you have to form over it?
4mm mild steel.
Though they did them out of G350 by accident. So that may or may not suck. Hopefully they can replace them with mildsteel.
58 minutes ago, Not-a-number said:
4mm mild steel.
Whats wrong with using 350 as opposed to 250?
Its higher tensile material. Nominally 350MPa yield strength as opposed to 250MPa.
To form it over the mandrel you need to be able to "yield" it, so the higher tensile would need more force to bend to yield.
@Not-a-number will you be heating it to form?
Nothing, just that it will be harder to do by hand.
Hopefully not but probably. Ive heard if it was G350 that would  probably crack and distort it. Since it would be locally annealing.
On 14/10/2020 at 22:36, IvyMike said:
What resin do you use for your castings and at what ratios? The quality looks great.
Techniset 6435 with catalyst 712. Its a 3 Part system.
Part 1 + 2 = 1.8% of sand mass
P3 = 3% of Part 1.
Sand is #90 so quite fine.
3 part system works way better than the 2 part I used in NZ. Mixes really evenly with hardly any effort.
P3 = 3% of Part 1.
Super cool! Can you reuse the sand after is has been used with the resin in it? can you give an example of the sand recycling process? #thumbsup
