The Bronze Posted May 29, 2020 Posted May 29, 2020 Looked very similar but it had the cowls off so couldn't 100% confirm. In a way the radiator looked smaller, and the wheels were dished differently, quite true to the originals. He'd done an amazing job of hiding the discs in fake drums and I think he'd sourced original headlights and whatnot. He also had the distributor set up in the dash as per original and could manual advance or retard it with the adjacent lever. He has a couple of Morgans, one with an S&S engine, another with a hot rodded CX500 engine, a TR3 a couple of other things under tarps. Supreme Barry of the Finestkind. 1 Quote
The Bronze Posted May 29, 2020 Posted May 29, 2020 Yeah, where that linked one has acorn plate, his has a set of spark plugs in the fire wall. He's gone pretty hard on the accuracy. Quote
Not-a-number Posted June 7, 2020 Posted June 7, 2020 On 28/05/2020 at 15:07, nzstato said: I'm not sure if I've posted this previously... Its a T35 'replica', one of 3? Acorn Schroeder here in NZ, is actually a monocoque body an has alfa running gear. There are 'cappings' on the boat tail which you can remove to bolt in a roll cage https://www.allcarindex.com/production/new-zealand/acorn/schroeder/ A writeup on one of the other chassis https://drivetribe.com/p/kiwi-built-bugatti-is-art-on-wheels-ZU4S4mJsR8GBAFx-wDniiA?iid=FdBMFnhvT0KY6pfZnwkOQw Owned by a friend of mine, its an absolute blast to drive... Yeah its quite far off the original. Everyone has different standards though I guess. Still probably fun to drive. Quote
Not-a-number Posted June 27, 2020 Posted June 27, 2020 Got a plate to remind me of what I should really be focusing on every day! Disclaimer: I wouldnt normally buy a personalised plate. But in CA they are only $50 so why not. 5 2 Quote
flyingbrick Posted June 27, 2020 Posted June 27, 2020 Damn you have an evora, none of us were going to judge you on cost of a p plate lolol 1 1 Quote
Not-a-number Posted June 27, 2020 Posted June 27, 2020 Quote Just now, flyingbrick said: Damn you have an evora, none of us were going to judge you on cost of a p plate lolol More the vanity than the cost (but the cost in NZ makes me judge a lot more!) 1 Quote
Not-a-number Posted July 21, 2020 Posted July 21, 2020 The King Leopold Type59 is up for auction. Estimated £10 million https://www.goodingco.com/vehicle/1934-bugatti-type-59-sports/ Ill start a crowed funding page for everyone to donate. Ill let you have a turn! 6 1 Quote
Bananaman Posted July 22, 2020 Posted July 22, 2020 Sweet baby Jesus this is some commitment. Following 1 Quote
Matt G Posted August 24, 2020 Posted August 24, 2020 Apologies if youve been already asked but, is it not economic to just 3D print the metal parts? so much time making those molds i bet. Quote
Not-a-number Posted August 24, 2020 Posted August 24, 2020 13 hours ago, Matt G said: Apologies if youve been already asked but, is it not economic to just 3D print the metal parts? so much time making those molds i bet. Possibly on some smaller parts like the supercharger or waterpump. Maaaaybe! I dont know the cost of Aluminium printing now but when I was doing SS printing it was about $1000/kg. The sump/crankcase are around 20-30kg and would have to be done in multiple pieces and welded together. This camtree part is 5kg and cost $100 to pour. Means once its right they are super cheap. A rough estimate on the cost to do this part: Modeling and pattern design - 250hrs Pattern Printing - $50 material Pattern /corebox prep - 50hrs & $100 material Sand Mould making - 15hrs Sand Mould cost - $20 Pour part - $100 So total its taken about 300hrs and $200 to make 1. 4 2 Quote
Matt G Posted August 24, 2020 Posted August 24, 2020 Fascinating brilliant to know! Keep up your excellent work. How much does a complete engine weigh? Quote
Popular Post Not-a-number Posted August 24, 2020 Popular Post Posted August 24, 2020 Basically I find it pretty hard to justify spending $thousands on one off parts. I might as well spend that money on a tool I can use for lots of parts. Example. To pay someone to make regular patterns for just the crankcase (MDF cnc) was going to be $13K. To pay someone to print just the crankcase patterns was $10K. So instead I bought a massive printer for $10K and printed every pattern for the engine for about $1000 material. 10 Quote
Not-a-number Posted August 24, 2020 Posted August 24, 2020 3 minutes ago, Matt G said: Fascinating brilliant to know! Keep up your excellent work. How much does a complete engine weigh? Not sure to be honest. Atleast 250-300kg. Quote
sheepers Posted August 24, 2020 Posted August 24, 2020 excellent news on the good casting result. have made many patterns and tried to get castings to work in various sizes and levels of complexity before and i know how hard/frustrating it can be so great work man. the foundry you're using look like they know their shit too which always helps. 3 Quote
Not-a-number Posted August 24, 2020 Posted August 24, 2020 29 minutes ago, sheepers said: excellent news on the good casting result. have made many patterns and tried to get castings to work in various sizes and levels of complexity before and i know how hard/frustrating it can be so great work man. the foundry you're using look like they know their shit too which always helps. They know what theyre doing so that does help. Usually the answer is "you could change X Y and Z and that might help, or it might make it worse you just gotta try it." One of the awesome things with the foundries over here is they are pouring 24/7. I just drive up and take the mould right to the furnace and fill it up straight away! NZ wasnt quite like that! 2 Quote
sheepers Posted August 24, 2020 Posted August 24, 2020 Yea the old "suck it and see" method of production improvement, 60% of the time it works every time. And yes you'd be hard pressed to find a foundry they you could just walk up to the door and get your mould poured straight away. Quote
Not-a-number Posted August 25, 2020 Posted August 25, 2020 1 hour ago, sheepers said: Yea the old "suck it and see" method of production improvement, 60% of the time it works every time. And yes you'd be hard pressed to find a foundry they you could just walk up to the door and get your mould poured straight away. Definitely open to some advice on the big stuff if you want to help? Im getting a better understanding of the runner system but on the big stuff like the crankcase theres so much going on (and its so big I dont want to mess it up too many times) Quote
sheepers Posted August 25, 2020 Posted August 25, 2020 All I can tell you is feed it. Put in way more risers then you think and make the Ingate how the foundry tell you, apart from that it really is a case of just trying it and seeing what happens. Maybe use bigger filters thn you think too? Each foundryman is going to have their own way of doing things and most of the time, if they're any good, they'll know what they're on about. 3 Quote
Not-a-number Posted September 14, 2020 Posted September 14, 2020 Well is sold for a bit under $20m NZD. I forgot to bid! 5 Quote
tortron Posted September 14, 2020 Posted September 14, 2020 maybe you can offer the new owner double his money? 1 Quote
