HighLUX Posted May 8, 2014 Share Posted May 8, 2014 No diff lock button on this one but doesnt mean the wiring isnt hidden behind one of the blanking plugs which is what im hoping for 1 Quote Link to comment Share on other sites More sharing options...
chees- Posted May 8, 2014 Share Posted May 8, 2014 just weld it? 4wd lyfe Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted May 8, 2014 Author Share Posted May 8, 2014 Â that's on the size tyre I want to use,and the guy had to lift it 100+mm to clear guards :/ 5 Quote Link to comment Share on other sites More sharing options...
Truenotch Posted May 8, 2014 Share Posted May 8, 2014 Weird transmissions in these things eh?  I reckon it would go fine in RWD form, but looks like you'd either need to lower the engine or cut the tunnel. Quote Link to comment Share on other sites More sharing options...
xsspeed Posted May 8, 2014 Share Posted May 8, 2014 Hihhlux what spec is your caldina. (Un)fortunately I know all about them Quote Link to comment Share on other sites More sharing options...
AllTorque Posted May 8, 2014 Share Posted May 8, 2014 I approve of this project. I uses to know an old dude that used a early 4WD Mitsi Chariot as a beach buggy and he said it'd go anywhere. So when you space down the subframes to jack this bitch up are you going to get some longer shocks or put spacers above the struts as well? Quote Link to comment Share on other sites More sharing options...
tortron Posted May 8, 2014 Share Posted May 8, 2014 if you can put a 4age in these, why wernt they all scrapped to rob the transmission for quad spinner AE86's and starlets  this thing also needs a rear wraparound airdeflector Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted May 8, 2014 Author Share Posted May 8, 2014 The american guys slap spacers on top of the front struts, and then just use longer springs all round, but most only lift them about 2". I'ma ask uncle Clint about the legalities of home made lift kits. Â From what i've read, the best set up is 1990 pathfinder springs in the rear, with longer shocks, gives around 2-3" of lift, with 83-86 camry coils and hats on the std tercel struts in the front, also giving between 2-3" of lift. Then you just do a slight space frame drop to stop the CV's exploding. Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted May 8, 2014 Author Share Posted May 8, 2014 Woo, just found a set of these: Â http://www.blackrubber.com.au/products/Commercial/MAXXIS-MT753-Bravo-185R14-8PRR Â Second hand in Whakatane, only done 800km's (Electrician had them fitted to his van, and his bosses went nuts) for a very sharp price, and they are 1/2" smaller OD than the 27" (really 26"OD) ones, so will help with clearance. Will snaffle them up me thinks. Quote Link to comment Share on other sites More sharing options...
Dirty_Safari Posted May 9, 2014 Share Posted May 9, 2014 GET THIS PRINTED ON VINYL AND STICK ON BACK WINDOW 8 Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted May 9, 2014 Author Share Posted May 9, 2014 I'm not going to lie, I have only ever watched one episode of breaking bad, so I have no idea whats going on tbh. Quote Link to comment Share on other sites More sharing options...
Dirty_Safari Posted May 9, 2014 Share Posted May 9, 2014 BEST YOU WATCH THE WHOLE LOT THEN BITCH Â OR IMA HAVE TO REPO THIS PIECE OF SHIT OFF OF YOU Â AND THENÂ REP THEÂ FUCK OUT OF IT AROUND KAWERAU/EDGECUMBE/AWATAPU Â /METH LIFE 2 Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted May 9, 2014 Share Posted May 9, 2014 I'm not going to lie, I have only ever watched one episode of breaking bad, so I have no idea whats going on tbh. You seriously have to lift your game, BITCH Quote Link to comment Share on other sites More sharing options...
HighLUX Posted May 9, 2014 Share Posted May 9, 2014 Hihhlux what spec is your caldina. (Un)fortunately I know all about them  Ummmm its a caldina and its 3s-fe manwel. Doesnt have any been destickered/debadged so duno what spec it is/thought it was a front tug POS. Its got an open rear diff tho which I would like to remedy Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted May 9, 2014 Author Share Posted May 9, 2014 I'VE NEVER WATCHED INITIAL D EITHER, AND I OWN AN AE86, SO FUCK THE LOT OF YA!!!!!!! 3 Quote Link to comment Share on other sites More sharing options...
xsspeed Posted May 9, 2014 Share Posted May 9, 2014 Ummmm its a caldina and its 3s-fe manwel. Doesnt have any been destickered/debadged so duno what spec it is/thought it was a front tug POS. Its got an open rear diff tho which I would like to remedy What year/model? Ie st195 or st215? Quote Link to comment Share on other sites More sharing options...
HighLUX Posted May 9, 2014 Share Posted May 9, 2014 '94 ST195 Â Do they roll a T series rear? Quote Link to comment Share on other sites More sharing options...
xsspeed Posted May 9, 2014 Share Posted May 9, 2014 Nah pretty sure he st195s are live axle like st215. Ill check my stz again. You will want to try find some stz from a tzg which was the 3sge 4wd manwell they should have lsd rear diffs. Will check on the centres. No caldinas that I recall have a lock diff button though. Quote Link to comment Share on other sites More sharing options...
HighLUX Posted May 9, 2014 Share Posted May 9, 2014 Its got a IRS rear end. Do they share the same diff/subframe set up as a 215? I need a front control arm with non flogged bushes Quote Link to comment Share on other sites More sharing options...
xsspeed Posted May 9, 2014 Share Posted May 9, 2014 i think the subframe is different, I was looking at it as was considering finding a 4wd manwell box for my mrs' st215 caldina gt (beams 3sge) so this is how I found out about all the diffs etc. I was thinking I could grab a box from a st195tzg but I dont think the subframes are identical, but the diffs/boxes are the same iirc. JUst get a st195 control arm anyway, lots get wrecked on TM Quote Link to comment Share on other sites More sharing options...
