Steelies Posted March 18, 2012 Author Share Posted March 18, 2012 elec. ignition $20 at elmers mowers - byebye points. one wire and one screw to install. new plug thanks repco NGK AB6 was informed i have a mkII villiers engine which needs attention to timing marks on assembly. Quote Link to comment Share on other sites More sharing options...
kicker Posted March 18, 2012 Share Posted March 18, 2012 Choice, interested in seeing how it runs with it Setting timing can be a bit fiddly but not hard, my current timing mark is a line drawn in vivid which I copied from another flywheel Quote Link to comment Share on other sites More sharing options...
Steelies Posted March 18, 2012 Author Share Posted March 18, 2012 sweet! managed to locate the arrows on magneto casing and the flywheel. well i now have a spare points assembly in pretty good nick if you ever need parts kicker also the little slots cut in the ends of the crank indicate postion, ie marks pointing straight down at TDC. we may have a bit of a victa vs villiers thing on our hands here.. shame you wont be at nats. Quote Link to comment Share on other sites More sharing options...
kicker Posted March 19, 2012 Share Posted March 19, 2012 Villiers rep'n hard I'm gutted, sounds like it's going to be off the interlinked metal rings Quote Link to comment Share on other sites More sharing options...
EURON8 Posted March 19, 2012 Share Posted March 19, 2012 got me a wee villers in the garage for a rainy day Quote Link to comment Share on other sites More sharing options...
Steelies Posted March 19, 2012 Author Share Posted March 19, 2012 bars levers throttle pegs seat brakes fender viewmaster. (no viewmaster dammit) Quote Link to comment Share on other sites More sharing options...
xsspeed Posted March 19, 2012 Share Posted March 19, 2012 bmx stems for bars? oh my Quote Link to comment Share on other sites More sharing options...
Steelies Posted March 19, 2012 Author Share Posted March 19, 2012 if only.. home made clamp ons. mtb bars for pegs tho! complete misuse of parts mobile Quote Link to comment Share on other sites More sharing options...
Truenotch Posted March 20, 2012 Share Posted March 20, 2012 Forks donated for the front of the frame too? Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted March 20, 2012 Share Posted March 20, 2012 please dont trim back those lower bars/cradle, look so sweet sticking out forward. Quote Link to comment Share on other sites More sharing options...
Steelies Posted March 20, 2012 Author Share Posted March 20, 2012 ^ was gona ask opinions, yeah better leave em full length. yep 2xforks in the frame. scratched my head for ages about bringing the twin tubes together at the head tube, then saw another set of forks. bango got the brake working last night, even found some vans shoe brake pads and re-covered the seat with a shirt i tore on saturday while falling backwards off a deck into trees. Quote Link to comment Share on other sites More sharing options...
Steelies Posted March 29, 2012 Author Share Posted March 29, 2012 still workin on shit. Quote Link to comment Share on other sites More sharing options...
rot808 Posted April 1, 2012 Share Posted April 1, 2012 ohmy, things are getting serious indeed Quote Link to comment Share on other sites More sharing options...
Steelies Posted April 1, 2012 Author Share Posted April 1, 2012 i've got a dead horse, time to flog it Quote Link to comment Share on other sites More sharing options...
My name is Russell Posted April 2, 2012 Share Posted April 2, 2012 Stink is engine not working out for ya? Quote Link to comment Share on other sites More sharing options...
Steelies Posted April 3, 2012 Author Share Posted April 3, 2012 nah it's goin ok, was just mocking it. finished crab manifold, bearings with terribly hory oil ways dremeled in (ashamed spec), fixy rear wheel, gear selector and 1st and 2nd gear on reduction box input shaft, rings are on their way bla bla probably finish building/test/run in at nats haha. oh even has a manky old unifilter too heh Quote Link to comment Share on other sites More sharing options...
sentra Posted April 3, 2012 Share Posted April 3, 2012 encouragement 1 Quote Link to comment Share on other sites More sharing options...
Ned Posted April 3, 2012 Share Posted April 3, 2012 expectations Quote Link to comment Share on other sites More sharing options...
Steelies Posted April 3, 2012 Author Share Posted April 3, 2012 accepted. Question: will a bike speedo sensor pick up magnets in magneto flywheel? then adjust settings for use as tachometer? Quote Link to comment Share on other sites More sharing options...
Ned Posted April 3, 2012 Share Posted April 3, 2012 could/should do but may go too fast. they will probably not be able to be adjusted to a 'wheel' that small. you could make something else up though without any problems.... or just put it on the wheel Quote Link to comment Share on other sites More sharing options...
