lowlancer Posted January 10, 2013 Share Posted January 10, 2013 Your downpipe looks way out of scale in that last pic, was trying to figure out wtf was going on That is all Quote Link to comment Share on other sites More sharing options...
mjrstar Posted January 10, 2013 Share Posted January 10, 2013 Cooler mounting looks nice and solid.. Keen on some specific details for the ECU conversion, specifically the trigger for the cas, as this is on my to do list for the mazda.. maybe i can mod either the mazda cas or the later model evo one i have... Quote Link to comment Share on other sites More sharing options...
ProZac Posted January 10, 2013 Share Posted January 10, 2013 From what I can figure out, all the EVO ecu's (up to an VIII anyway) are looking for the same pattern, this one: The early stuff gets everything from the CAS, its got two optical circuits in it. For the later stuff like the motor the head you're using is from, they switched to a separate crank trigger, and a different (apparently better) cam sensor setup, but the combination of the signals will be the same as the early stuff. The Mazda CAS should output the same signals as the mitsy one's I'm pretty sure, I seem to remember something about MX5's using the same pattern... But if I were you, I'd put on a separate crank trigger, and use the mitsy cam trigger on the back of the head (if you have room) Crank triggering from the crank itself is better, as you eliminate timing belt whipping and flex issues that become apparent when getting a crank position signal from a cam mounted sensor. I really should have put a proper crank trigger on mine, but its just a SOHC poo box, so should be okay, heh . Quote Link to comment Share on other sites More sharing options...
0R10N Posted January 10, 2013 Share Posted January 10, 2013 Oddly enough, a Stazza is one car where I wouldn't mind a maroon, tan or otherwise non-black/non-grey interior Quote Link to comment Share on other sites More sharing options...
ProZac Posted January 10, 2013 Share Posted January 10, 2013 The Tan is pretty terrible, or maybe its just that all the ones I've seen have been in pretty average condition... But agree that the maroon is pretty pimpin . Black on Black is where its at, though .. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted January 11, 2013 Share Posted January 11, 2013 Once you go black you can't go back.. Quote Link to comment Share on other sites More sharing options...
snapper Posted February 6, 2013 Share Posted February 6, 2013 uber-flock! you'll blend in nicely with the dash, now. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted February 6, 2013 Share Posted February 6, 2013 ha ha- that's flocking funny that.. Can you flock things in other colours? like red?.. Quote Link to comment Share on other sites More sharing options...
ProZac Posted February 6, 2013 Share Posted February 6, 2013 Yeah, you can get it in pretty much any colour. I might see about buying one of the machines, but theyre really expensive. Quote Link to comment Share on other sites More sharing options...
sheepers Posted February 6, 2013 Share Posted February 6, 2013 fuck you look funny with the fluff al over you! car is looking good though. are you and car going to be at the nats??? Quote Link to comment Share on other sites More sharing options...
ProZac Posted February 6, 2013 Share Posted February 6, 2013 No alas, It won't be ready in time I'm thinking... Next year though! Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted February 7, 2013 Share Posted February 7, 2013 Ahhhh but you could travel up with others- take your pick from the various rides. I think you should come along That is all. Quote Link to comment Share on other sites More sharing options...
kyteler Posted February 21, 2013 Share Posted February 21, 2013 Multi forum post? "Friend of mine" = DJZ? Quote Link to comment Share on other sites More sharing options...
OSM Garage Posted February 21, 2013 Share Posted February 21, 2013 Badass Quote Link to comment Share on other sites More sharing options...
ProZac Posted February 21, 2013 Share Posted February 21, 2013 Multi forum post? "Friend of mine" = DJZ? Yup, and Yup. Quote Link to comment Share on other sites More sharing options...
kyteler Posted February 21, 2013 Share Posted February 21, 2013 Hey, my brain figured something out. Well done, me. So, this red one is de-reg or not vinned yet, or what's the go? Quote Link to comment Share on other sites More sharing options...
ProZac Posted February 21, 2013 Share Posted February 21, 2013 Reg on hold, just needs putting back together really. It had a paint job around 5 years ago and has sat in a garage since then. Its been on trademe for aaaaaaaaages, I finally relented . Quote Link to comment Share on other sites More sharing options...
kyteler Posted February 21, 2013 Share Posted February 21, 2013 Oh mean, that should be a relatively quick little sort out. Good shit. Quote Link to comment Share on other sites More sharing options...
ProZac Posted February 21, 2013 Share Posted February 21, 2013 I'll pop an MPI injection setup on it straight away though, with an EVO V ecu, as the factory loom has been hacked about a little and sorting it out would be harder than just replacing it with newer stuff. Loving your r30 thread btw Quote Link to comment Share on other sites More sharing options...
fuel Posted February 21, 2013 Share Posted February 21, 2013 Reg on hold, just needs putting back together really. It had a paint job around 5 years ago and has sat in a garage since then. Its been on trademe for aaaaaaaaages, I finally relented . I'm glad you did because I was quite keen for a while haha, but I shouldn't be spending monies. Quote Link to comment Share on other sites More sharing options...
