Vintage Grumble Posted May 5, 2010 Share Posted May 5, 2010 AE70/AE85's come with 3AU motors, is the gear box behind them a K series with a A series bell housing? Or is this a load of crap? Quote Link to comment Share on other sites More sharing options...
xsspeed Posted May 5, 2010 Share Posted May 5, 2010 Truth afaik, tis a K50 Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted May 5, 2010 Author Share Posted May 5, 2010 Is everything about them the same apart from the bell housing? As in, would the guts from a 3K K50 fit in a 3AU K50? Quote Link to comment Share on other sites More sharing options...
kyteler Posted May 5, 2010 Share Posted May 5, 2010 Are they really K50's? I would have thought T50's The AA63 Carina I had was 3AU - T50. I would have thought the Carina and AE85 would have been similar in gubbins. Quote Link to comment Share on other sites More sharing options...
thegreatestben Posted May 5, 2010 Share Posted May 5, 2010 Nah not in the rolla's should definitely be a K50 Quote Link to comment Share on other sites More sharing options...
4AG_Addict Posted May 5, 2010 Share Posted May 5, 2010 AE85 or AE70 is A series K50, all the internals are interchangable with K series K50. When i destroyed 2nd in one of my AE85s, i scored a freebie K40 from KP60 & swapped the damaged bits over Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted May 5, 2010 Author Share Posted May 5, 2010 Sweeeeeet, may end up with a AE70 with a silver top in it, thinking may be hard on the box, have a few K40/50's about, just wanted to know if I could use parts from them. Cheers ppl. Quote Link to comment Share on other sites More sharing options...
shizzl Posted May 5, 2010 Share Posted May 5, 2010 i was told years ago the k50 is the cable operated version of the t50.. but possibly different input spline?? maybe weaker?? but shit loads cheaper to buy..and the 4age bolted up to it,ke70 dx driveshaft was used.. good deal,good bye Quote Link to comment Share on other sites More sharing options...
Mike-e Posted May 5, 2010 Share Posted May 5, 2010 K50s and T50s share no same internal parts. K50 is much weaker. Design is completely different apart from power goes in one end and out the other Quote Link to comment Share on other sites More sharing options...
xsspeed Posted May 5, 2010 Share Posted May 5, 2010 IIRC there is a difference between (some) k50's from kp's and ke's though this may just be shifter location. Obviously these won't have the "A" engine bellhousings though. Quote Link to comment Share on other sites More sharing options...
ryanfels Posted May 5, 2010 Share Posted May 5, 2010 The K50s arnt as weak as people male them out 2 be, i had 1 behind my bluetop for a few years and not once did it cause any problems but i surpose it depends on what type of life its had. The internals of the K series K50 should fit in the A series K50 but i have heard of small differences that required odd size bearings etc Quote Link to comment Share on other sites More sharing options...
rob Posted May 6, 2010 Share Posted May 6, 2010 AE85 or AE70 is A series K50, all the internals are interchangable with K series K50. When i destroyed 2nd in one of my AE85s, i scored a freebie K40 from KP60 & swapped the damaged bits over So did this transform your K50 into a 4 speed or were you able to retain 5th? I've heard elsewhere you could rebuild A-series K40/50's with parts from K-series ones, it's nice to have this confirmed I think they built 3A-U Carinas with T50's due to the increased weight of the car, afaik the only difference between them and the 4A-GE T50 is the the clutch fork on the opposite side.... although now that I think about it the input splines might be different? Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted May 6, 2010 Author Share Posted May 6, 2010 Yeh, K50 and T50 are completely different. The next question I have is, whats the best way to set up the clutch? At the moment it has the 20V flywheel and pressure plate, with the K50 clutch plate, it was done like this because the 20V has 2 more bolt holes on crank (6 vs 8?) for flywheel then the 3AU, and because 20V cluth plate wont fit on K50 input spline, the problem is the clutch plate is much smaller then the 20V one, so it kinda only has half of its area contacting, the inner part of the plate is over the recess in the 20V flywheel, and I dont think it will last to well? Is there an easy way to do this better? Had planned to machine 20V flywheel and put the original K50 pressure plate on it, by way of redrilling the correct PCD into it, so would end up with 20V flywheel, and K50 clutch and pressure plate. Quote Link to comment Share on other sites More sharing options...
fuel Posted May 6, 2010 Share Posted May 6, 2010 Are they really K50's? I would have thought T50's The AA63 Carina I had was 3AU - T50. I would have thought the Carina and AE85 would have been similar in gubbins. I think it's cause the Carinas are classed as a heavier car ie they're on the 'A' Celica/Celica Camry/Supra/Carina platform rather than the lighter 'E' Corolla/Sprinter/Levin/Trueno platform. Quote Link to comment Share on other sites More sharing options...
smokin' joe Posted May 6, 2010 Share Posted May 6, 2010 Yeh, K50 and T50 are completely different.The next question I have is, whats the best way to set up the clutch? At the moment it has the 20V flywheel and pressure plate, with the K50 clutch plate, it was done like this because the 20V has 2 more bolt holes on crank (6 vs 8?) for flywheel then the 3AU, and because 20V cluth plate wont fit on K50 input spline, the problem is the clutch plate is much smaller then the 20V one, so it kinda only has half of its area contacting, the inner part of the plate is over the recess in the 20V flywheel, and I dont think it will last to well? Is there an easy way to do this better? Had planned to machine 20V flywheel and put the original K50 pressure plate on it, by way of redrilling the correct PCD into it, so would end up with 20V flywheel, and K50 clutch and pressure plate. the 20v flywheel is too big for the bell, so it needs to be relieve with a diegrinder. the 3AU clutch should be fine from memory, you may have a 4K clutch?? Quote Link to comment Share on other sites More sharing options...
rob Posted May 6, 2010 Share Posted May 6, 2010 I used a 3A-U Clutch plate and the stock Clutch Cover to put a smallport into my kp. The K50 bellhousing needed a bit of massaging even with the 16v flywheel. Quote Link to comment Share on other sites More sharing options...
Toucan Posted May 6, 2010 Share Posted May 6, 2010 How heavy is the AE70? I think the small clutch will be okay. I had bluetop and T50 in a light kp60 with smaller than stock clutch plate for some reason. Was fine for lots of daily thrashing and a few trackdays but I went to the bigger/normal size clutch when I redid it. Quote Link to comment Share on other sites More sharing options...
4AG_Addict Posted May 7, 2010 Share Posted May 7, 2010 AE85 or AE70 is A series K50, all the internals are interchangable with K series K50. When i destroyed 2nd in one of my AE85s, i scored a freebie K40 from KP60 & swapped the damaged bits over So did this transform your K50 into a 4 speed or were you able to retain 5th? I've heard elsewhere you could rebuild A-series K40/50's with parts from K-series ones, it's nice to have this confirmed No K50 was still a K50, I just removed the damaged 2nd gear off the mainshaft the K50 & replaced with the gear from the K40. Was pretty simple really Quote Link to comment Share on other sites More sharing options...
Vintage Grumble Posted May 7, 2010 Author Share Posted May 7, 2010 At the mo, its got the 3au clutch plate inbetween the 20v fly wheel and pressure plate, maybe it wont be as shit as I thought? From memory we did grind out the bell to get the 20v clutch and fly in there. Oh well, will run it as is and see what happens! Quote Link to comment Share on other sites More sharing options...
4age steve-o Posted May 10, 2010 Share Posted May 10, 2010 so i can buy a k50 of the back of a 4k, swop the gear set over into my k50 and bolt it back upto my bluetop 4age? the spline will fit back into the engine sweet az? and i see some talk about a pdf file on how to do it but cant seem to find one. does no a link or anything. cheers Quote Link to comment Share on other sites More sharing options...
