Cutting out rust in awkward places
xsspeed
Hey boes
In the corolla I have some rust on the rear tailgate section - around lights and the 'car-side' where the boot latches.
Now I would usually just attack with Mr A Grinder, but some of what I want to cut out is rather awkwardly positioned, or so small that in order to cut it out I will get a lot of over cut/cut into good metal which I would like to avoid.
Just wondering what sort of tools others have used for similar jobs?
I imagine some sort of nibbler or small recipro-saw would be the go?
Cheers in advance - Steve
reminds me I have a dremel kit now that I grabbed out of storage - will take a look and see - pretty sure its electric and not air (no compressor atm)
That'll do the job. It should have the little mandrel for cut off wheels already (Just a mandrel with a screw in the top) and you want the reinforced cut off wheels - Dremel 426 like this:
The other thing I have found really good in the past for this sort of stuff is the little air powered hacksaw. It does a nice clean job and can get into even the tightest spots - usually the spots that the grinder can't because of the different cutting orientation. The other good thing is the lower blade/cutting speed meaning no sparks - ideal for around glass or fuel tanks, although you would have to remove those to weld anyway.
Heres a pic of a pair of identical tools to those I used (minus DA).
That middle tool is the one I was (trying to) describe. I was well impressed by how user friendly it was to operate.
I once made a mandrill to use a wheel from that tool in a reqular air die grider. But I found with no shroud is was a bit dangerous to use.
yea they are off the chain when they catch spit out of the piece and take out the tip of your finger ..
also those airsaws are mean , awesomly loud but they make jobs just so much easier , especially with sheet metal
You can cut anything with oxy aceylene. Just use a small welding tip and turn the gas up a bit, too much for welding but enough to blow a hole in and cut it. That way the melted stuff that doesn't drop out ends up thickening at the edges and is easier to join onto. A small tip can get into places that no other cutting tool can.
Steve
