Fiberglass filler vs bog
Mk2EscortSport!
It depends what you are using it for.
If you are filling huge rust holes where you should be welding plates into them - use the glass filler.
If you are fixing body kits, use the glass filler.
If you are fixing minor dents or any repairs on flat panels use the normal bog.
Usually you will have to go over the glass filler with a layer of standard bog anyway.
I think the glass stuff is designed for bonding two things or filling large holes rather than filling dents.
I have used large quantities of both and they are very good for the jobs they were designed for.
fibreglass is good but you will never get a clean finish with it
and will have to use bog anyway.
for rust i just cut it out and plate it then bog it.
a good bog i use is Z grip very easy sanding and fuck all
air bubbles so you dont get pin holes.
the last lot i bought was $40 for 4lts from a panel and paint
shop.
dan
just dont get that 1 part shit from repco, its gay as
the cellulouse shit??
never used it
work has fibre , normal and finishing bog
both do their jobs very well used in the right applications
finishing bog is a pain in the arse cos i keep managing to not put the cap on proper;y and it sets itself off
Ah cheers for that bro ... make me think, and after that thinking i concluded i shal use it for my flares
Cheap and high CFM don't go together, theres another thread around as someone asked the same question. Some people manage with cheap ones. I'd find the thread but too lazy, so have a look, something along the lines of what size compressor.
