Dell'orto Posted September 10, 2013 Share Posted September 10, 2013 5200rpm is laggier than I would have expected, I assume your exhaust ports would have been opened up to match? Still, 300rwkw is nothing sneeze at, skid vids ASAP. Also lol at your mate on FB getting fired up at rotary hate 1 Link to comment Share on other sites More sharing options...
Testament Posted September 10, 2013 Share Posted September 10, 2013 pretty sure it was the other way around, he got all fired up hating on things that werent tangallinglonglang/couldnt handle the sight of any other motor in an rx7 1 Link to comment Share on other sites More sharing options...
J-Calico Posted September 10, 2013 Share Posted September 10, 2013 Still, 300rwkw is nothing sneeze at, skid vids ASAP. Link to comment Share on other sites More sharing options...
SHGWAG Posted September 10, 2013 Author Share Posted September 10, 2013 Yeah, he was hating on all things non rotary, which is funny, coz he owns a rice S15 faced S13 'drift car'....... Anyways, didn't touch the thing this week, but I've set aside Saturday morning to find the fluid leak (suspect power steering) and give the engine bay a degrease. I'll also get the boost issue sorted. I may then do a skid (on a 'closed road' of course). Link to comment Share on other sites More sharing options...
Vintage Grumble Posted September 10, 2013 Share Posted September 10, 2013 Under controlled circumstances. Whatever, you're a rota owner, just roll down main street of hams at lunch time and let rip. Link to comment Share on other sites More sharing options...
SHGWAG Posted September 10, 2013 Author Share Posted September 10, 2013 Under controlled circumstances. Whatever, you're a rota owner, just roll down main street of hams at lunch time and let rip. Ah, did this in my Brother's FD one Christmas day, speed cut down Victoria street (Pre speed bumps). Fuck we were idiots. Link to comment Share on other sites More sharing options...
SHGWAG Posted September 11, 2013 Author Share Posted September 11, 2013 So, I upped the boost to 15PSI today, and changed the duty cycle of the boost control solenoid. However, checking if this is working properly requires a 4th gear pull so I can keep traction and keep the engine under full load - not an easy feat on public roads. I'll test this on the weekend, this will confirm if it's indeed a boost issue, and if so, will up the boost cut to see if that cures things. I've just set it up as limited at roughly 15psi across the board atm, once back on the dyno, I can fine tune the controller to give me definitive boost control. Link to comment Share on other sites More sharing options...
SHGWAG Posted September 15, 2013 Author Share Posted September 15, 2013 So, Friday afternoon I discovered that not only did I have a PS fluid leak, but the block was also loosing water - UH OH. After fearing the worst, I let the car idle up to temp, them had a look through the engine bay, found water at the front of the block, but no sign of leakage. Step back 4 years to when the block was built, I took delivery of the block sans water pump & housing as I already had these. For some un known reason I skimped on buying a $7 gasket for the point where the WP housing bolts onto the block. This had now come back to bite me in the backside. After returning from Matamata near on 11pm, Rob & I pulled the front end apart, low & behold, the gasket goo used had failed. We cleaned the surfaces and all was set for the morning. Saturday morning after a stop in at the the local Mazda, new gaskets were in hand and the car was back together by 11am. Started her up and no leaks. Left the car in the garage and VTEC'd up to Meremere to watch some drifting. (Forum member Furai? was getting some sweet angle going in his MX5) Got back and took the car out only to find that when we disconnected the battery on Friday night, it had cleared all of the settings in the boost controller. DRAT. It was too wet to set it up again, with wheel spin occurring in every gear as soon as boost came on I decided to park it up for the day in lieu of putting it into a stationary object. I've re entered the boost settings and will test this, this afternoon if time & weather permit. Link to comment Share on other sites More sharing options...
Yowzer Posted September 15, 2013 Share Posted September 15, 2013 Take it for a dooort along O'regans road. It's long flat and empty. And I'll be able to hear it from here. Link to comment Share on other sites More sharing options...
japawagons Posted September 15, 2013 Share Posted September 15, 2013 And full of cops... Link to comment Share on other sites More sharing options...
Yowzer Posted September 15, 2013 Share Posted September 15, 2013 Nah man, just tractors Link to comment Share on other sites More sharing options...
SHGWAG Posted September 15, 2013 Author Share Posted September 15, 2013 Resolution Drive is the place, 3 straights to do decent pulls down. Link to comment Share on other sites More sharing options...
J-Calico Posted September 15, 2013 Share Posted September 15, 2013 /\ and the coolest name for a road haha. What boost controller are you using? Link to comment Share on other sites More sharing options...
SHGWAG Posted September 15, 2013 Author Share Posted September 15, 2013 Apex-i AVC-R. Just need to balance out the duty cycle of the solenoid so it doesn't spike or fluctuate. Unfortunately I haven't hooked up the speedo to it, so boost by gear control is out for the time being. Ideally I'd like a dyno where I can study the boost curve and adjust the settings to suit. Link to comment Share on other sites More sharing options...
SHGWAG Posted October 1, 2013 Author Share Posted October 1, 2013 So this thing is happily running 14psi and will now rev to redline. Still have to see what's causing the boost cut at 16psi, but will get to that in due course. One thing I have noticed is that it doesn't like sitting in traffic for long periods, as while the engine temp stays a consistent 82-84 degrees, the intake air temp skyrockets. I need to get this sorted & I have a few options for this. Link to comment Share on other sites More sharing options...
wannabe Posted October 1, 2013 Share Posted October 1, 2013 Heat coat the mani? We put a bunch of heat shields and reflective gold foil on a mates car that helps with heatsoak. I'll be doing this to the MR2 as well. Link to comment Share on other sites More sharing options...
Rookie Posted October 1, 2013 Share Posted October 1, 2013 It will be heat soaking the intercooler, there isn't much you can do about it really. Link to comment Share on other sites More sharing options...
Dell'orto Posted October 2, 2013 Share Posted October 2, 2013 IAT is in the upper intake manifold (assuming microguess uses it?), it'll be heat from the block causing it to climb. Vented bonnet is the easiest way to fix it, but they can look pretty naff Link to comment Share on other sites More sharing options...
danger Posted October 2, 2013 Share Posted October 2, 2013 Needs more Edaboc stickers obviously 2 Link to comment Share on other sites More sharing options...
SHGWAG Posted October 15, 2013 Author Share Posted October 15, 2013 It had two edaboc stickers on it at one stage that read "edacoc". Clutch has done itself a mischief, so pulling it apart on Saturday to investigate. I suspect it's the release bearing. As I'm currently only running a single clutch plate with uprated pressure plate, I'm tossing up whether this is the time to go to a twin plate clutch now to avoid any issues if I decide to squeeze any more power out of it later on. Link to comment Share on other sites More sharing options...
