Truenotch Posted October 31, 2009 Share Posted October 31, 2009 How does that description relate to "when stopping" ? Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted October 31, 2009 Share Posted October 31, 2009 How does that description relate to "when stopping" ? Generally you'd put your foot on the clutch when you come to a stop so that the car doesn't stall, which means the throw out bearing has load on it, making the noise? Quote Link to comment Share on other sites More sharing options...
Simon Posted October 31, 2009 Share Posted October 31, 2009 Yeah but "the noise" should also occur every other time when the clutch is disengaged not just while stopping. Anyone that knows what a thrust bearing is should be able to provide a more in depth diagnosis. We should probably just help him lol. If the cars in neutral with the motor running and you press the clutch does it make the same noise? Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted October 31, 2009 Share Posted October 31, 2009 remember when sprak had 'dtm style' tips on his e28. used to be able to get 4 or 5 litres of water down each one when he was inside the bp payig for his gas so lol. Quote Link to comment Share on other sites More sharing options...
karmagedon Posted October 31, 2009 Author Share Posted October 31, 2009 It's allright Simon, I know its the thrust / pinion bearing. But thanks for offering to help. I havn't really noticed it when changing gears while moving, hence I stated while stopping. Although today I think I might have heard it once. It's also not playing up all the time while the clutch is engaged. It started happening yesterday, so could still only be mild wear?? Although when bearing dry out I don't see how they can be more dried out one day than the next?? Anyway. Quote Link to comment Share on other sites More sharing options...
mikuni Posted October 31, 2009 Share Posted October 31, 2009 I think a sure way to tell if its thrust bearing is to depress the clutch while stationary and see if it makes an audible change to the engine note. Quote Link to comment Share on other sites More sharing options...
karmagedon Posted November 5, 2009 Author Share Posted November 5, 2009 So I found out today that you can get 16" brakes for these. What would you possibly need that for short of a 2000hp jet engine?? Also went to change the thrust bearing, couldn't get the gearbox nuts up the top loose, so decided screw it for now, I havn't heard the noise in about a week, Quote Link to comment Share on other sites More sharing options...
karmagedon Posted November 9, 2009 Author Share Posted November 9, 2009 Finally sorted out my exhaust, used the factory front piece and then welded that onto my pipe. Now I can atleast tighten the nuts onto the flange Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted November 10, 2009 Share Posted November 10, 2009 Saw this sunday afternoon when i was half cut - needs more low IMO Quote Link to comment Share on other sites More sharing options...
karmagedon Posted November 10, 2009 Author Share Posted November 10, 2009 Saw this sunday afternoon when i was half cut - needs more low IMO agreeed, but don't know how to with these struts without changing spring pressure Quote Link to comment Share on other sites More sharing options...
lowlancer Posted November 10, 2009 Share Posted November 10, 2009 ??? If you're going lower, your spring rate will change by necessity. Do a bit of research on adjustable coilover struts. Even King Springs will have a different spring rate to stock. Quote Link to comment Share on other sites More sharing options...
UTERUS Posted November 10, 2009 Share Posted November 10, 2009 If my memory is right, it has adjustable teins in it. It should be able to go a bit lower with them wound down, then again it might still be jacked because of the 17's Quote Link to comment Share on other sites More sharing options...
karmagedon Posted November 10, 2009 Author Share Posted November 10, 2009 True elliot, I haven't done much research on the theory behind coilovers. Suppose you don't know what you need to learn until you find out you need to learn it. Will do some reading. Yea it has Gaz adjustable suspenion in it. And true again about it being jacked up because of the 17's. ( Hence why I changed the thread tittle to 4WD spec when I put them on ). Quote Link to comment Share on other sites More sharing options...
Truenotch Posted November 11, 2009 Share Posted November 11, 2009 Just jack it up and take the perch's down by 30mm to start with - see how low it makes it and how captive your springs are afterwards then go from there. 30mm won't add too much droop to your shocks. If you want to go super low you'll probably need keeper springs. Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted November 12, 2009 Share Posted November 12, 2009 Just take the springs out & roll like a playaa Got anything in mind engine wise for this thing? BPT conversion? Quote Link to comment Share on other sites More sharing options...
karmagedon Posted November 12, 2009 Author Share Posted November 12, 2009 No engine conversion planned. Was thinking CA for a while but don't think the work involved will be worth it. Could get more go fast bits for same price. Quote Link to comment Share on other sites More sharing options...
nothingsfree Posted November 12, 2009 Share Posted November 12, 2009 Add 13bt + more low = Funnnn! Quote Link to comment Share on other sites More sharing options...
karmagedon Posted November 19, 2009 Author Share Posted November 19, 2009 Best news I've had in a while : Ewan has found a van and already at the docks!!!! SOOO STOKED. Should arrive by 18th DEC. Can't wait. Quote Link to comment Share on other sites More sharing options...
SHGWAG Posted November 19, 2009 Share Posted November 19, 2009 A van? Have I missed something??? Quote Link to comment Share on other sites More sharing options...
fuel Posted November 19, 2009 Share Posted November 19, 2009 my guess is that he's picked up some ultra sweet wheels in japan, and just waiting for ewan to get a van to load up to bring over. Quote Link to comment Share on other sites More sharing options...
