M.H. Posted December 7, 2019 Share Posted December 7, 2019 18 hours ago, tortron said: I like this (for a GN) https://atelier-medusa.fr/en/suzuki-gn-125-en/ The fuel gauge especially Thats pretty cool Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted December 7, 2019 Share Posted December 7, 2019 I always feel the front has to come down about 3" 3 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 7, 2019 Author Share Posted December 7, 2019 3 minutes ago, flyingbrick said: I always feel the front has to come down about 3" I think that's what they do. The frame looks pretty naff and couple with the tank makes the front look even higher. Not a great cafe base. I want maximum clearance and cush riding tho Quote Link to comment Share on other sites More sharing options...
flyingbrick Posted December 7, 2019 Share Posted December 7, 2019 Or lift the rear up? Quote Link to comment Share on other sites More sharing options...
tortron Posted December 13, 2019 Author Share Posted December 13, 2019 New tyre acquired Shinko golden boy. 3.00-18 Thinking I should have gone the 3.50 if even just for looks. Will try it out and see how it handles. Minimal change in rolling diameter on the rear wheel. Just very narrow and doesnt fill the space nicely. Going to get a dr200 camshaft and install for a small increase in performance. Cheap and cheerful, and have a rev counter cog on them unlike the more performance minded aftermarket stuff. Because performance is limited I'm going to add some lightness. Battery is the first to go. A 2.9kg lead acid brick. Have now got a much smaller (clearance for high exhaust in mind) lithium ion battery weighing in at about 0.5kg. a big improvement Plus they don't mind laying on their sides..... Don't "need" it but the lead acid once can power my cat proof chicken enclosure 2 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 17, 2019 Author Share Posted December 17, 2019 So cute 7 1 Quote Link to comment Share on other sites More sharing options...
chris r Posted December 17, 2019 Share Posted December 17, 2019 Do you need to do anything to the charging system for them? Quote Link to comment Share on other sites More sharing options...
Raizer Posted December 17, 2019 Share Posted December 17, 2019 41 minutes ago, chris r said: Do you need to do anything to the charging system for them? No, they (should) have a battery management system chip in them that controls charging and balances the cells. So should just be plug and play. 2 1 Quote Link to comment Share on other sites More sharing options...
johnnyfive Posted December 17, 2019 Share Posted December 17, 2019 What a time to be alive! 3 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 17, 2019 Author Share Posted December 17, 2019 6 hours ago, chris r said: Do you need to do anything to the charging system for them? Nup as above it's all in the battery. Some even have a setting so if you leave your lights on it will keep enough in charge for a couple of starts 3 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 19, 2019 Author Share Posted December 19, 2019 Long range fuel tank Gn400 tank. Kinda rare I guess, they only made them for 2 years on the 80s. Pretty sure it's Gona be lumpy under the paint, there's a funny ripple bend/dent in the underside spine of it. But anyway. It holds over 12L compared to the gn125 10L. Looks like it holds 3L in reserve, gn125 is 2L. So I should happily crank another 50k with this and should be able to get to work without filling up twice a week. Probably paint it black I guess 7 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 19, 2019 Author Share Posted December 19, 2019 Actually note to self. Check gn125 fuel tank from bone dry. I wonder how much fuel gets trapped on the wrong side of the tank. Could gain a bit with a balance tube Quote Link to comment Share on other sites More sharing options...
Willdat? Posted December 20, 2019 Share Posted December 20, 2019 On 18/12/2019 at 05:59, tortron said: Nup as above it's all in the battery. Some even have a setting so if you leave your lights on it will keep enough in charge for a couple of starts What brand is that? I'm running a total loss system on my CL50 for the indicators. So something that avoids 'bricking' the battery would be sweet. Quote Link to comment Share on other sites More sharing options...
tortron Posted December 20, 2019 Author Share Posted December 20, 2019 16 minutes ago, Willdat? said: What brand is that? I'm running a total loss system on my CL50 for the indicators. So something that avoids 'bricking' the battery would be sweet. Mine is a “poweroad” I see they also make 6v ones. not sure at what point these ones turn off, but will be at a level to save the battery Quote Link to comment Share on other sites More sharing options...
tortron Posted December 26, 2019 Author Share Posted December 26, 2019 Apparently you can find a cbr250 stator in these by tapping the M5 bolts out to M6 Apparently it has more output Also the winning combo of every gn125 scrambler/cafe racer seems to be 340mm rear shocks and raise the rear of the fuel tank 25mm to have it line up with the frame. 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 26, 2019 Author Share Posted December 26, 2019 Here's another neat one 4 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 29, 2019 Author Share Posted December 29, 2019 Removed lead acid battery, overflow, battery tray, and tool box Made new tray. Drilled some holes in it for lightness. Used original battery strap, installed with lithium battery. Forgot to take a pic of it while out. Didn't think about it too much as I will probably update it after running new exhaust. I want to make the seat removable and have a storage under it too, so will probably move all the loom and stuff too. Will probably have to chop up the rear guard etc. 6 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 29, 2019 Author Share Posted December 29, 2019 Like this, I curled some tabs over for the battery strap. If I keep it here I think I will use the original rubber isolators too 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 29, 2019 Author Share Posted December 29, 2019 Did some Gtech runs today. The readings are always not right, I don't think I'm now producing 19kw. So looking at the footage 0-100 was 27 seconds on the 125 cylinder over a couple runs And is now 23 seconds over a couple runs on the 150 2 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 29, 2019 Author Share Posted December 29, 2019 ADVGN TV is on the air 4 Quote Link to comment Share on other sites More sharing options...
