Requiemk Posted July 28, 2008 Share Posted July 28, 2008 have talked to a few people including certifier and seems a big no go to redrill mags, are they just being cunts. If there is plenty of meat i honestly don't see what the problem would be. Going from 5x120 to 5x114. Redrill 5 new hole or oval out old ones? Quote Link to comment Share on other sites More sharing options...
Testament Posted July 28, 2008 Share Posted July 28, 2008 that is going to be quite close if you redrill between the existing holes with the 5 stud and the pcd's being quite close. making oval holes isn't that great an idea in my mind either. But I have to say, going FROM 5x120 TO 5x114.3? 5x114.3 is pretty common, surely you can sell these on and get some wheels in the correct stud pattern? also wtf uses 5x120? Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted July 28, 2008 Share Posted July 28, 2008 holden and bmw Quote Link to comment Share on other sites More sharing options...
WDE_BDY Posted July 28, 2008 Share Posted July 28, 2008 DELETED Quote Link to comment Share on other sites More sharing options...
Requiemk Posted July 28, 2008 Author Share Posted July 28, 2008 yet to receive rims hopefully get them this weekend. Red indicates new holes green ovaled. id say deception of the picture but looks to be alot of meat there for new holes. Quote Link to comment Share on other sites More sharing options...
thminiman Posted July 28, 2008 Share Posted July 28, 2008 IMO if the cert guy says it cant be done, it shouldnt be done, i know you're a dodgey cunt etc so you prolly wont be aiming for a cert, but if you where, then it would be right up there on the top of the list of shit you'd have to fix after the check, therefore fucking a set of wheels Quote Link to comment Share on other sites More sharing options...
Ke36 Posted July 28, 2008 Share Posted July 28, 2008 give elite a call theyl know the deal but as he said ^^^ what cert man says is usually what youve gotta do Quote Link to comment Share on other sites More sharing options...
Brock-Lee Posted July 28, 2008 Share Posted July 28, 2008 dude they are steels, You will have to get a taper pressed into them once they have been re-drilled. Hit up arrow wheels or elite wheels and have an ask of them. They will suss you out if it can be done EDIT: beat by heaps Quote Link to comment Share on other sites More sharing options...
Requiemk Posted July 28, 2008 Author Share Posted July 28, 2008 pretty much sorta what cert man said. When i asked first thing he said was it alloy or steel. was unkeen on drilling steel but with alot of things came done to how it was done. Will give rimrite in palmy a call tomorrow and possible elite. churs brock new taper pressed into is only logical explanation so far as to why not Quote Link to comment Share on other sites More sharing options...
Ke36 Posted July 28, 2008 Share Posted July 28, 2008 what about boreing out the centre hole of steels i got some that are like 50 something mm i need to take out to 67mm t fit over my gay mitsi sized centres cant just check em in a lathe? Quote Link to comment Share on other sites More sharing options...
Requiemk Posted July 28, 2008 Author Share Posted July 28, 2008 tbh i probably will get steels as theses were cheap buy will happily drill these holes out and bog old ones over for time being thats how much i give a fuck Quote Link to comment Share on other sites More sharing options...
eke_zetec_RWD Posted July 28, 2008 Share Posted July 28, 2008 got access to a lathe? if so make some plugs or what eva ud call them to press the taper out. then counter sink with the rite taper. shud be sweet as if you do it mint. but yea how wide is that band? Quote Link to comment Share on other sites More sharing options...
treggo Posted July 28, 2008 Share Posted July 28, 2008 fucking yuck. Get some centres of the right pcd and get em swapped. Quote Link to comment Share on other sites More sharing options...
Prof Schnorz Posted July 28, 2008 Share Posted July 28, 2008 seriously, get a pattern on carbord or sumthn shit, drill it out, and bog the old holes if u can be fukd/hav tym. ride 'em no cert... you know you want to but your not being honset to yourself i gota big drill bit Quote Link to comment Share on other sites More sharing options...
CUL8R Posted July 28, 2008 Share Posted July 28, 2008 Put a Hub Cap over it ow! , What redrill??? Quote Link to comment Share on other sites More sharing options...
kyteler Posted July 28, 2008 Share Posted July 28, 2008 Bog the old holes? WTF? Seriously. Get the fuck out! *points* 1 Quote Link to comment Share on other sites More sharing options...
drftnmaz Posted July 28, 2008 Share Posted July 28, 2008 by bog surley he means weld up then bog? i'd weld them up then drill on mill and make sure there hubcentric aswell Quote Link to comment Share on other sites More sharing options...
Steelies Posted July 28, 2008 Share Posted July 28, 2008 tapered wheel nuts in slotted holes its good fun laughing at the odd person you see driving round on their sweet new rims waggling all over the show Quote Link to comment Share on other sites More sharing options...
Requiemk Posted July 29, 2008 Author Share Posted July 29, 2008 was just fucked off in general will not be bogging old holes over lol. Access to lathe. Going to take old hubs into work tomorrow and pop out studs for possible re studding the hubs. Quote Link to comment Share on other sites More sharing options...
