Prof Schnorz
Everything posted by Prof Schnorz
Yes, I've done all that but limited to only reserving 8. For some strange reason it isn't working for me anyway, they're being assigned new Ips no matter what reservation I'm setting for them. so far, the whole system has been working flawlessly and the only thing I have done is set the lease times to max (I think it was one week)
Dude, this is what I need. I thought it could be completely done from the router side. Thanks mate
Sounds like I'm lucky as is. 10 lights, 2 Chromecasts (older 2.4only models) Ac controller, 2 switches, dehumidifier and air purifier on the 2.4ghz band, so 17 devices The other 5 are cabled computers or 5ghz casting devices. What I want to know is: If I plug another router into the current one, can I put say 8 of those devices listed above on the new router, halfing the load on the original router? or is there some sort of bottleneck. I had an inkling at it being down to how devices are assigned Ip's I set static IPs for the things I didnt want to drop off, but for some reason I can only set a max number of those at 8. I've never had network performance issues, its always there, works solid and never drops out, just a whole device will disappear and it takes a router reset to jumble ip's up again and its assigned a new one Pretty much what I'm trying to avoid But if everyone agrees its necessary Ill bite the bullet
Huawei HG659, standard issue skinny/voda is my main router connected to the fibrebox. I have use of some old netgear or a belkin n600 router as a secondary
Hi, sick of trawling google not getting straight answers and many of you clever chaps will know! I have started with some basic home automation stuff, google home hubs, wifi lights, chromecasts, heatpump controllers, wifi outlets etc etc, everything works fine and dandy. Anything that supports 5ghz network or lan cable is done so, freeing up the space on the 2.4ghz network which many things (all the lights) are on. It seems i've hit the max number of devices connected before one gets randomly booted off to replace another at about 22 The Lan cable and 5ghz are never booted, so i'm assuming its a maximum just on 2.4ghz band Can i plug another router into my current router expanding my max number of connected devices? or does that second router use up device slots in the primary router? by slots do i mean IP addresses? I have no idea. I have no issues with signal or strength anywhere> If anyone lurking in the shadows has any idea how to help Id appreciate a cheeky PM, thanks team
Stolen : 1990 Honda Integra XS I WGTN
Prof Schnorz replied to JoKer's topic in Lower North Island Region
was driving down Broderick road Johnsonville about 30mins ago and swear I saw this go through lights heading up Morefield road towards Onslow College. Noticed the bare intake pipe, but numberplate has been taken off the front. I mean how many more are there that look EXACTLY like that, If id seen the thread earlier I would have chased it Chances are its still whole and still in wellington region -
Behold.....loooooongbike - and now shit gets fat
Prof Schnorz replied to ThePog's topic in Two Wheels
did you paint chrome mirrors yellow?
Recently had a cunt of a time with a rb. Check aac valve plunger is not stuck open/carbonated to fuckery, also I couldn't get a reading through a brand new lead, broken out of the box. Definitely turn car on and jiggle all wiring for subtle changes in revs lol, found the revs dropped 500 with afm plug in a certain postion.
Dave's not so 4WD spec Miata from the future
Prof Schnorz replied to karmagedon's topic in Other Projects
Wow, angle bracing. Don't try saying its because its a scrape hazard either, I've browsed the 35 pages. I was swearing most of the time This should just become an Mx5 inspiration thread/ spam, It's seriously not going anywhere -
Stoaked it's not going to waste... Cant wait to see the final product! Also: You'll be ripping the quads up everywhere, especially mud pits
I dont know what hunters have, but is the lines, master and slave all external and 100% can be seen? If your loosing fluid it will be seen coming out somewhere.. take your slave off and have a geeze at the piston
Mossay? look around the carpet beneath you're clutch pedal and see if its wet/greasy. Same thing happened to me, and i knew there was a leak but couldn't find it anywhere, Turns out it was soaking into the underside of my carpet slowly and was invisible until the whole master emptied itself. The smell gives it away...
lol. what can i say, you all know what im thinking too right now.... dude just attach it to ya intake pipe and ull be set....
"hey bro?!, i kno wea i cud get chu wuna doze" you know it aint happening man.
The cress is certed at 40mm to chassis rail, still an ok daily but not recommended unless your good with angles I have had a cop try to ram his notebook under, sayin below 100mm is illegal regardless of cert , followed up with "but im no engineer" Generally most dont actually know how the cert is measured. Usually i tell them what the numbers mean just to sound like a good cunt so they let me off quicker... Never had a fine but been pulled up by every cop in town
lol did you just look at them? with past experiences i now look at these carefully
is it a DET radiator or a de/e? my first r32 had det (thick one) and 2nd r32 always got hot up big hills/on the beach, cos it had the standard 20e radator with 25det behind it
Undetecibles '85 Toyota Cressida
Prof Schnorz replied to Prof Schnorz's topic in Projects and Build Ups
latest pics after mirrors went on, cheers Dell'orto. Cant really notice its ment to have wing mirrors.... -
i used a r32 spolier for my lip, looks alright, also i converted myn to guard mirrors instead
