WhangareiKE70 Posted January 31, 2020 Posted January 31, 2020 Will try that on Monday, ran out of time today, generally find them to be very expensive though, so still interested to know if anyone has seen them for sale anywhere else. Quote
M.H. Posted February 12, 2020 Posted February 12, 2020 Does anyone have any experience with matte finishes? Matte 2k vs matte clear over base coat? Quote
tortron Posted March 4, 2020 Posted March 4, 2020 Repainting Underside floor and chassis of mitsi Ute. Thinking of brushing a few kgs of zinc (CRC zinc it) on. Or should I just durepox it? Quote
tortron Posted March 4, 2020 Posted March 4, 2020 But it's zinc Looking closer it says good for 6 years if out in the weather I wouldn't mind recoating every 6 years if I never have to do rust repairs on this again. Maybe I will fill the chassis rails with it Il probably durepox it, by the time I wipe all the bitumin sealer off it will be a nice clean metal surface to start with Quote
Bling Posted March 4, 2020 Posted March 4, 2020 Two pack is king, no doubt. However one pack is still better than nothing. I've used zinc it on all sorts of shit where I CBF dealing with 2 pack. Small brackets / a gate frame. Seems to stand up fine, even when outside in the sun all year. I have a bunch of bare metal areas on car i'm collecting up to do with epoxy primer. If you already have a tin of it, go nuts I say. If you don't, then epoxy probably not that much different price wise. Unless the underseal is falling off mine, i'm not touching it. I'll patch areas that are bare and hope the factory stuff lasts another 35 years. Quote
tortron Posted March 4, 2020 Posted March 4, 2020 I've used the spray can black zinc under the tray in a few areas and it's held up well for a few years now. I have a tin of zinc it and a tinbof durepox and they both require the same prep. One day il get that metal spray done to it, but didn't win lotto Quote
Spencer Posted March 4, 2020 Posted March 4, 2020 6 years ain't shit on a car. You can get zinc 2 part epoxy if you wants the zinc. Quote
Dudley Posted March 22, 2020 Posted March 22, 2020 So I’ve bought a car that some one has just spray painted mat black over the original paint. The pressure washer can only get the loose stuff off but not the bulk. Thinners doesn’t seem to remove it ether, is there a product that will remove the spray paint but not damage the original paint to much? cheers Quote
tortron Posted March 22, 2020 Posted March 22, 2020 1 hour ago, Dudley said: So I’ve bought a car that some one has just spray painted mat black over the original paint. The pressure washer can only get the loose stuff off but not the bulk. Thinners doesn’t seem to remove it ether, is there a product that will remove the spray paint but not damage the original paint to much? cheers woops saw you tried thinners probably if you let it soak in, wet sheet, cover in plastic? Quote
Dudley Posted March 23, 2020 Posted March 23, 2020 Yea that still didn’t work. Have just started wet sanding it off and it’s working pretty good just slow Quote
tortron Posted March 23, 2020 Posted March 23, 2020 could try one of those sticker remover wheels that go on a drill. basically a claybar? Quote
kyteler Posted March 23, 2020 Posted March 23, 2020 Caramel wheel? They get rid of adhesive residue without harming the paint, unsure that they would work on shit paint atop good paint and I think they're a bit spendy and they definitely get chewed through pretty quickly. Quote
Bling Posted March 23, 2020 Posted March 23, 2020 Could you polish it off with an aggressive compound? Quote
kyteler Posted March 23, 2020 Posted March 23, 2020 Potentially but that would also eat into the paint below so if you were going to do that you may as well skip the compounds and go straight onto fine sandpapers. Quote
Dudley Posted March 23, 2020 Posted March 23, 2020 Yea cutting paste didn’t work ether. have tried thinners , crc , brakekleen etc fine sandpaper seems best so far Quote
tortron Posted March 23, 2020 Posted March 23, 2020 in my experience paint stripper removes the paint in layers, expecially the weaker stuff. my ute tray took 6 applications where it had been resprayed several times. very frustrating for me, potentially great for you Quote
