bubblegoose Posted February 18, 2012 Share Posted February 18, 2012 look out for specials on supercheap satin black fixes all sorts of paint fuck ups Quote Link to comment Share on other sites More sharing options...
Gaz Posted February 18, 2012 Share Posted February 18, 2012 lol polish wont help. it would be liek trying to polish 240grit sandpaper Do what KK said then if it evens it out whack some clear over it. Just want to find out what the guy used to paint it with originally. I think youll find that when rubbing that roof down you will go through to the old colour. The rest of the car will prob rub down and clear ok by the looks tho. Gaz Quote Link to comment Share on other sites More sharing options...
Beaver Posted February 18, 2012 Share Posted February 18, 2012 i have the paint tin that he used, will ahve a read Quote Link to comment Share on other sites More sharing options...
Llama Posted April 10, 2012 Share Posted April 10, 2012 Quick question: I have some engine paint to spray my heater box with. It says "after drying, must be baked at 92 degrees etc" does it mean drying like 1 day dry or proper curing? Curing time is one week apparently. Quote Link to comment Share on other sites More sharing options...
Spencer Posted April 11, 2012 Share Posted April 11, 2012 Other temp paint I have basically says once its touch dry, I would wait a day then bang that shit in the oven Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted November 20, 2012 Share Posted November 20, 2012 Holy crap so much to read! So a few questions, sorry if they have been answered I'm looking a resraying my ke70 corolla I started giving it a sherrife cop car paint job like 7 years ago, stopped, and no I totally hate the idea so so much So the shell is painted in the same paint I am going to use, which is the resense 2k the bolt on panels etc have been in primer since then Clearly i need to sand the body back down and Re prime, but what about my goards etc that are still in primer? Just sand them down and paint from there?? Also, i was looking at painting the bolt on parts, doors, gaurds etc, seperate to the rest of the car, I know this isnt the best option, but how likely am I going to run into miss match colour bewteen them and the shell? All paint will be from the same batch. Also need to buy a gun for the top coat, was going to buy a gravity feed, any recommendations? was thinking about 200-300 dolloras on a gun. Colour is going to be factory ke70 corolla cream / white. Cheers guys, any suggestions would be great. Also, I aplan on using some pratices gaurds etc to set up my gun, tho to be honest i have no idea what I will be doing haha Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 20, 2012 Share Posted November 20, 2012 come onto the magical facebook mr alan, you can sweet talk to me about paint if you like Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted November 20, 2012 Share Posted November 20, 2012 na, sorry man, i would rather fuck it up than be one face book haha but thanks Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 20, 2012 Share Posted November 20, 2012 oki doki with straight 2k colour providing you mix each batch precisely and lay enough paint to fully cover the panel then you wont get any colour variance painting panels seperatly (unless its along time between painting days). if your car has been outside or damp alot since you primed the guards then id sand most of it off and slap one more coat on just to help stop any moisture blisters later on as for gun look for a second hand sata or devilbiss even a well used one sprays better than a random Chinese brand, infact i could probably prise one from a painter at work, i use my gti pro for base clear and 2k and have 2 aircaps for extra wank factor between 1k and 2k paints but its not necessary Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 20, 2012 Share Posted November 20, 2012 ps dont be affraid to leave plenty of time between coats, it helps get a flatter finish Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted November 20, 2012 Share Posted November 20, 2012 What do you call plenty of time? And yeah totally keen on a reasonable gun. thanks for the info dude, car has been in dry storage for the whole time Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 20, 2012 Share Posted November 20, 2012 depends on the temperature, im assuming this is a garage job so ill say 15 degrees, id say leave it 15-30 minutes between coats just give the primed panels a bit of time in the sun before working on them to bake out the moisture and you should be good to go Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted November 20, 2012 Share Posted November 20, 2012 magic, the shed here can get opretty warm in summer, so should be good time to paint, Just need to get the compressor up and running again Quote Link to comment Share on other sites More sharing options...
bubblegoose Posted November 20, 2012 Share Posted November 20, 2012 be warned, warm is good for painting but can also increase your change of runs as the paint thins when it heats up, so be sure to practice in the same conditions you will be painting and id advise getting shit set up/masked the night before and getting and early start when its cooler for painting and gets hot later one for budget bake cycle cool shed=more time to get around the car hot shed=dry spray around the start/finish points Quote Link to comment Share on other sites More sharing options...
danger Posted November 20, 2012 Share Posted November 20, 2012 ps dont be affraid to leave plenty of time between coats, it helps get a flatter finish What do you call plenty of time? And yeah totally keen on a reasonable gun. thanks for the info dude, car has been in dry storage for the whole time I judge the time between coats by touching a bit of paint on some of the masking, if it comes off stringy on your finger- too soon. If its just tacky- time for sailing. Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 20, 2012 Share Posted November 20, 2012 I sprayed my Alfa in base coat clear coat, and would highly recommend, do you have the paint already? Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted November 21, 2012 Share Posted November 21, 2012 No I H ahvnt bought the paint yet. No so keen on spending heaps on clear tho....... Quote Link to comment Share on other sites More sharing options...
Rookie Posted November 21, 2012 Share Posted November 21, 2012 I think I got all of my paint for about $250, I imagine that would go skyward pretty quick if you started adding metal flake and pearls and shit, but the solid colours are about $100/ L, and the clear is cheaper than that. Quote Link to comment Share on other sites More sharing options...
Seedy Al Posted November 22, 2012 Share Posted November 22, 2012 that isnt to bad, what brand you use? Quote Link to comment Share on other sites More sharing options...
danger Posted November 22, 2012 Share Posted November 22, 2012 I think I got all of my paint for about $250, I imagine that would go skyward pretty quick if you started adding metal flake and pearls and shit, but the solid colours are about $100/ L, and the clear is cheaper than that. Are you painting a mini? How much paint did you use? Quote Link to comment Share on other sites More sharing options...
