Gaz Posted May 9, 2007 Share Posted May 9, 2007 Just do a quick matt black job over the top. Will look banging and cant hurt for a bit of extra protection. Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted May 10, 2007 Share Posted May 10, 2007 Resene black, $32 bucks a liter. ^^ My first paint job on the Corolla was in that.. Wasn't all bad apart from my noobness Quote Link to comment Share on other sites More sharing options...
blakamin Posted May 10, 2007 Share Posted May 10, 2007 was it shiny? Quote Link to comment Share on other sites More sharing options...
cute wee gem Posted May 10, 2007 Share Posted May 10, 2007 Would have been if it wasn't so orange peely Quote Link to comment Share on other sites More sharing options...
mk5corty Posted May 11, 2007 Share Posted May 11, 2007 Whats the best way to go about painting a car with metalic paint. Is it best to just spray the base down and let it dry etc then do the clear, or do it straight after etc? any help appreciated. mk5corty, tell me how youd do it Shit never even saw this ohwell, i would spray the metallic onto primer sanded with 600 grit minimum, metallic paints show sanding scratches well. Let the base dry partially between metallic and clear say an hour or two, although this really depends on if your using 1k or 2k. You can sand earlier coats of metallic if it has orange peel although it's not recommended, just make sure the clear goes on unsanded colour. Quote Link to comment Share on other sites More sharing options...
mk5corty Posted May 11, 2007 Share Posted May 11, 2007 Primer contains a large quantity of talc, which is excellent at absorbing water, think talcum powder. Getting all the shit paint off will be a bitch, i would look for a uv resistant epoxy primer, then just scuf it when the time comes, many people use matt black epoxy but the sun will fade it, just scuff, recoat, spray some primer to hide the colour and then apply colour. Quote Link to comment Share on other sites More sharing options...
blakamin Posted May 11, 2007 Share Posted May 11, 2007 another trick with a mettalic basecoat (If you're gunna clear over) is to have a bit more distance between gun and panel and sort of "mist" it on in light, even strokes... avoid a "wet" coat at all costs unless you like stripes! Quote Link to comment Share on other sites More sharing options...
ratt Posted May 15, 2007 Share Posted May 15, 2007 lol see what happens if u dust on metallic. gonna have some funky lookin colors and transperant paint. metallics basecoat still needs to go on wet. as long as u dont drown the panel and its even Quote Link to comment Share on other sites More sharing options...
thminiman Posted May 15, 2007 Share Posted May 15, 2007 let the battle of car painters begin (again) Quote Link to comment Share on other sites More sharing options...
corrupt Posted May 15, 2007 Share Posted May 15, 2007 lol see what happens if u dust on metallic. gonna have some funky lookin colors and transperant paint. metallics basecoat still needs to go on wet. as long as u dont drown the panel and its even you only mist it on, on the last coat of base to even the metallic out. Quote Link to comment Share on other sites More sharing options...
peteretep Posted May 15, 2007 Share Posted May 15, 2007 how many coats of paint would you guys recommend on interior bits, and would that Plasti-Kote vinyl paint be good for other stuff like plastic interior bits? Quote Link to comment Share on other sites More sharing options...
corrupt Posted May 15, 2007 Share Posted May 15, 2007 personally id put enough coats on to get a full even coverage, then one or two more quick ones, yeh that plasikote stuff will be fine, have used it before. Quote Link to comment Share on other sites More sharing options...
peteretep Posted May 15, 2007 Share Posted May 15, 2007 yeah I've got a good coverage with only 1 coat but I'll put one or two more on there, was wondering about how that vinyl stuff holds up to mild use Quote Link to comment Share on other sites More sharing options...
corrupt Posted May 15, 2007 Share Posted May 15, 2007 in the cortina atm, ive painted the door cards and pull handle things with black vinyl paint from supercheap, septone brand or whatever, after a year or so use the drivers pull handle has worn off inside the handle, and the door cards are stil mint. Quote Link to comment Share on other sites More sharing options...
ratt Posted May 15, 2007 Share Posted May 15, 2007 lol different folks different strokes.. dusting on metallics causes the aluminium particles (what makes a metallic, metallic ) to stand up as opposed to lying flat which can cause the color to come out light, and possibly mottled (especially with coarse silvers) edit: just my opinion, everyone has they're own technique and style Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 17, 2007 Share Posted May 17, 2007 Quick question on matty B, I need to tidy up my car for nats was looking at a quick prep then matt black but I know its only going to be good for a few months then fucked when it gets wet. Any ideas saw you guys talking about it in low lancers thread and didnt want to spam it. Do I just bite the bullet and go 2k gloss on the bitch Quote Link to comment Share on other sites More sharing options...
thminiman Posted May 17, 2007 Share Posted May 17, 2007 dunno how its done, but the matty b on my mini's roof is ALLLLL good, might be satin as i dont know the difference. but yuh, was professionally done. Quote Link to comment Share on other sites More sharing options...
avenger79 Posted May 17, 2007 Share Posted May 17, 2007 Satin's got a sheen to it, also called semi-gloss. How straight is your car Spence?, and if you really want gloss on it go for it.No point doing a half arse job with matte. Still got millions of time before Nats. Quote Link to comment Share on other sites More sharing options...
Spencer Posted May 17, 2007 Share Posted May 17, 2007 shes pretty straight bar where rust has been welded up, all the big panels are mint roof doors etc. Hmmm will talk to painter mate and get some 2k prices from him. Anyone give me a rough price 2k black, primer etc etc, anyone got mad hook ups we just get trade at link up Quote Link to comment Share on other sites More sharing options...
peteretep Posted May 20, 2007 Share Posted May 20, 2007 hey, I want to spray a bunch of stuff for my escort, nothing bigger than 500x500x500, is it possible to buy a large cardboard box(dishwasher size) so that I can paint in that? I dont get the newspaper so that doesnt really work and I cant really paint inside my garage. Quote Link to comment Share on other sites More sharing options...
