Toucan Posted July 17, 2006 Share Posted July 17, 2006 Have plenty of people popping up and asking what stud pattern their cars are so why not make a decent thread and sticky it. Alfa Romeo Sud/Sprint/33/145/146/115 Series Alfetta - 4*98 75/156/new GTV/spider - 5*98 105 Series Guilia/GTV etc - 4*108 BMW Older 3 series - 4*100 2002's - 4*100 Other bmws - 5*120 (late 90s 5*120 wheels need a hubcentric ring to fit the other 5*120 patterns) Datsun All small early rwd's - 4*114.3 Bigger datsuns - 5*114.3 Ford Anglia - 4*108 Capri - 4*108 Cortina Mk1 to Mk5 - 4*108 Escort Mk1 & Mk2 - 4*108 Falcon - 5*114.3 Focus - 4*108 Mondeo - 4*108 Hillman Avenger - 4*108 Hunter - 4*108 Imp - 4*101.6 Isuzu Geminis - 4*100 Piazza - 4*100 Mazda All pre-78 Mazdas back to the R100 - 4*110 With the exception of: RX-5s, 121s, LA4-series 929s (ie post RX-4 style and pre-HB) and the 1500/1800 - 4*120. 84/85 RX-7s (series 3s) - 4*114.3 HB 929s, Cosmos and Luces - 4*114.3 S4/5 RX-7s are 5x114.3 S6/7/8 RX-7s are 5x114.3 but the offset on the rear is weird so you can't be guaranteed that "normal" 5x114.3 wheels will interchange without checking. Mini 4*101.6 Mitsubishi All 4 stud RWD - 4*114.3 All FWD 4 stud - 4*114.3 up til around 1991 All 5 studs - 5*114.3 Nissan Turbo Silvia - 5*114.3 Turbo Skyline - 5*114.3 Peugeot 404/405 - 4*140 Subaru Older subarus - 5*140 Toyota Corolla: E1 - 4*110 E2 - 4*110 E3 - 4*114.3 E7 - 4*114.3 E85/86 - 4*114.3 Crown - 5*114.3 Hiace - 5*114.3 Hilux - 5*114.3 Soarer - 5*114.3 Supra - 5*114.3 Starlet: KP30 - 4*110 KP60/61/62 - 4*114.3 Triumph 2000TC - 4*114.3 Vauxhall Chevette - 4*100 VOLVO 340, 360, 440, 460, 480 - 4*100 850 >93 - 4*108 T4, S40, V40 - 4*114.3 240, 740, 760, 780, 940, 960 >94 - 5*108 850 93>, 960 94>, C70, S70, V70, S90, V90, T5, T5-R - 5*108 Also here is a wheel fitment guide that may help: http://www.bgworldwheels.co.nz/fitment.html This also has a few bolt patterns http://www.mrt-wheels.com/boltpatternref.html - zep This also has bore size http://www.carlsalter.com/wheel_fitments.html - Ned Offset If the rim was 100mm wide an 0 offset you would have 50mm inside and 50mm outside of the hub mounting face of the wheel. The same rim with a -10mm offset would have 40mm inside and 60mm outside of the hub mounting face. Big thanks to all the contributions to this list 1 Link to comment Share on other sites More sharing options...
Snoozin Posted July 17, 2006 Share Posted July 17, 2006 Toyota Corolla E1 - 4x110 E2 - 4x110 E3 - 4x114.3 E7 - 4x114.3 E85/86 - 4x114.3 Starlet: KP30 - 4x110 KP60/61/62 - 4x114.3 Alfa Romeo Sud/Sprint/33/145/146/115 Series Alfetta - 4x98 105 Series Guilia/GTV etc - 4x108 Link to comment Share on other sites More sharing options...
Raizer Posted July 17, 2006 Share Posted July 17, 2006 Add cortina MK3/4/5 and anglia etc to your ford list theyve got they same stud. Link to comment Share on other sites More sharing options...
Raizer Posted July 17, 2006 Share Posted July 17, 2006 Laser/telstar (323/626) is 4X100. Ford Focus are also 4x108 old subaru 4x140 Volvos use a 5 x 108 most 4x4s use 6x139.7 Vw "wide 5" 5x205 Audi 4x108 Link to comment Share on other sites More sharing options...
HUNTD Posted July 17, 2006 Share Posted July 17, 2006 hunter - 4*108 Link to comment Share on other sites More sharing options...
mutiny Posted July 17, 2006 Share Posted July 17, 2006 mazda rx2,3,4,5,7. 929 808 616 626 121. 4x110 corolla ke20 25 26 4x110 corolla ke30 35 36 ke70 ae70 te71 ae8s 4x114.3 datsun 1600, 1200 4x114.3 Link to comment Share on other sites More sharing options...
crazy_rich Posted July 17, 2006 Share Posted July 17, 2006 falcons are 5x 114.3 (just had to contribute something. Link to comment Share on other sites More sharing options...
Josh Posted July 17, 2006 Share Posted July 17, 2006 Also add to the ford list - Capris, 4*108 Link to comment Share on other sites More sharing options...
Sparkle Posted July 17, 2006 Share Posted July 17, 2006 BMWs = 5x120 usually except for older 3s and 02s which are 4x100, around et20 offset late 90s 5x120 wheels need a hubcentric ring to fit the other 5x120 patterns, the 90s 3 series have a nearly front wheel drive offset Link to comment Share on other sites More sharing options...
cute wee gem Posted July 17, 2006 Share Posted July 17, 2006 pretty sure all the old rwd datsuns were 114.3 Link to comment Share on other sites More sharing options...
Flick Posted July 17, 2006 Share Posted July 17, 2006 pretty sure all the old rwd datsuns were 114.3 Datsun 1200's were 4x114.3 as were many others. Toyota Hilux Toyota Hiace Ford Falcon Late Model Rx7 ( 5 Stud ) Turbo Skyline's Turbo Silvia's Toyota Supra Toyota Soarer Toyota Aristo All the above take a 5 x 114.3 Link to comment Share on other sites More sharing options...
zep Posted July 17, 2006 Share Posted July 17, 2006 Geminis = 4x100 Link to comment Share on other sites More sharing options...
mikuni Posted July 17, 2006 Share Posted July 17, 2006 Datsun 1600's used 4x114.3, I'm also sure the rwd dattos were all 114.3 (datsun bluebirds etc right the way through) Big datsuns were 5x114.3 Toyota Corolla fwds are 4x100 (ae82 etc) Same with fwd sprinters, levins, Nissan pulsars from '90 on (+ civics and integras ) Chevettes are 4x100 aswell. Link to comment Share on other sites More sharing options...
peteretep Posted July 17, 2006 Share Posted July 17, 2006 hmmm didnt I suggest this a while ago? Link to comment Share on other sites More sharing options...
Toucan Posted July 17, 2006 Author Share Posted July 17, 2006 Ok people, two questions: 1, Should we add new cars to the list? Generally I would say no, but certain cars may be useful for example putting turbo skyline hubs onto your old datsun, but where do we draw the line? 2, Completely forgotten what I was going to ask, il post later when I remember it Link to comment Share on other sites More sharing options...
CaMpylobacter Posted July 17, 2006 Share Posted July 17, 2006 use this for late model shiz as a guide. http://www.bgworldwheels.co.nz/fitment.html other than that, jump on google, 'tisnt hard (that one = first one to come to mind without using a search engine) Link to comment Share on other sites More sharing options...
crazy_rich Posted July 17, 2006 Share Posted July 17, 2006 yeh, my u12 bluebird poobox is 4 x 114.3. fully stoked you mentioned me in the thanks column. i'll drink to that. Link to comment Share on other sites More sharing options...
durty Posted July 17, 2006 Share Posted July 17, 2006 VOLVO 340, 360, 440, 460, 480 = 4 x 100 850 >93 = 4 x 108 T4, S40, V40 = 4 x 114.3 240, 740, 760, 780, 940, 960 >94 = 5 x 108 850 93>, 960 94>, C70, S70, V70, S90, V90, T5, T5-R = 5 x 108 Link to comment Share on other sites More sharing options...
fuel Posted July 17, 2006 Share Posted July 17, 2006 Mitsubishi All 4 stud RWD Mitsubishis are 4x114.3mm All FWD 4 stud Mitsubishis are 4x114.3mm up til around 1991. All 5 stud Mitsubishis are 5x114.3mm. Link to comment Share on other sites More sharing options...
FLAWLES Posted July 18, 2006 Share Posted July 18, 2006 toyota crowns 5 x 114.3 Link to comment Share on other sites More sharing options...
