Have plenty of people popping up and asking what stud pattern their cars are so why not make a decent thread and sticky it.
Alfa Romeo
Sud/Sprint/33/145/146/115 Series Alfetta - 4*98
75/156/new GTV/spider - 5*98
105 Series Guilia/GTV etc - 4*108
BMW
Older 3 series - 4*100
2002's - 4*100
Other bmws - 5*120
(late 90s 5*120 wheels need a hubcentric ring to fit the other 5*120 patterns)
Datsun
All small early rwd's - 4*114.3
Bigger datsuns - 5*114.3
Ford
Anglia - 4*108
Capri - 4*108
Cortina Mk1 to Mk5 - 4*108
Escort Mk1 & Mk2 - 4*108
Falcon - 5*114.3
Focus - 4*108
Mondeo - 4*108
Hillman
Avenger - 4*108
Hunter - 4*108
Imp - 4*101.6
Isuzu
Geminis - 4*100
Piazza - 4*100
Mazda
All pre-78 Mazdas back to the R100 - 4*110
With the exception of:
RX-5s, 121s, LA4-series 929s (ie post RX-4 style and pre-HB) and the 1500/1800 - 4*120.
84/85 RX-7s (series 3s) - 4*114.3
HB 929s, Cosmos and Luces - 4*114.3
S4/5 RX-7s are 5x114.3
S6/7/8 RX-7s are 5x114.3 but the offset on the rear is weird so you can't be guaranteed that "normal" 5x114.3 wheels will interchange without checking.
Mini
4*101.6
Mitsubishi
All 4 stud RWD - 4*114.3
All FWD 4 stud - 4*114.3 up til around 1991
All 5 studs - 5*114.3
Nissan
Turbo Silvia - 5*114.3
Turbo Skyline - 5*114.3
Peugeot
404/405 - 4*140
Subaru
Older subarus - 5*140
Toyota
Corolla:
E1 - 4*110
E2 - 4*110
E3 - 4*114.3
E7 - 4*114.3
E85/86 - 4*114.3
Crown - 5*114.3
Hiace - 5*114.3
Hilux - 5*114.3
Soarer - 5*114.3
Supra - 5*114.3
Starlet:
KP30 - 4*110
KP60/61/62 - 4*114.3
Triumph
2000TC - 4*114.3
Vauxhall
Chevette - 4*100
VOLVO
340, 360, 440, 460, 480 - 4*100
850 >93 - 4*108
T4, S40, V40 - 4*114.3
240, 740, 760, 780, 940, 960 >94 - 5*108
850 93>, 960 94>, C70, S70, V70, S90, V90, T5, T5-R - 5*108
Also here is a wheel fitment guide that may help: http://www.bgworldwheels.co.nz/fitment.html
This also has a few bolt patterns http://www.mrt-wheels.com/boltpatternref.html - zep
This also has bore size http://www.carlsalter.com/wheel_fitments.html - Ned
Offset
If the rim was 100mm wide an 0 offset you would have 50mm inside and 50mm outside of the hub mounting face of the wheel.
The same rim with a -10mm offset would have 40mm inside and 60mm outside of the hub mounting face.
Big thanks to all the contributions to this list :)
  • Replies 43
Toyota
Corolla
E1 - 4x110
E2 - 4x110
E3 - 4x114.3
E7 - 4x114.3
E85/86 - 4x114.3
Starlet:
KP30 - 4x110
KP60/61/62 - 4x114.3
Alfa Romeo
Sud/Sprint/33/145/146/115 Series Alfetta - 4x98
105 Series Guilia/GTV etc - 4x108
Laser/telstar (323/626) is 4X100.
Ford Focus are also 4x108
old subaru 4x140
Volvos use a 5 x 108
most 4x4s use 6x139.7
Vw "wide 5" 5x205
Audi 4x108
mazda rx2,3,4,5,7. 929 808 616 626 121. 4x110
corolla ke20 25 26 4x110
corolla ke30 35 36 ke70 ae70 te71 ae8s 4x114.3
datsun 1600, 1200 4x114.3
BMWs = 5x120 usually except for older 3s and 02s which are 4x100, around et20 offset
late 90s 5x120 wheels need a hubcentric ring to fit the other 5x120 patterns, the 90s 3 series have a nearly front wheel drive offset
pretty sure all the old rwd datsuns were 114.3
Datsun 1200's were 4x114.3 as were many others.
Toyota Hilux
Toyota Hiace
Ford Falcon
Late Model Rx7 ( 5 Stud )
Turbo Skyline's
Turbo Silvia's
Toyota Supra
Toyota Soarer
Toyota Aristo
All the above take a 5 x 114.3
Datsun 1600's used 4x114.3, I'm also sure the rwd dattos were all 114.3 (datsun bluebirds etc right the way through)
Big datsuns were 5x114.3
Toyota Corolla fwds are 4x100 (ae82 etc)
Same with fwd sprinters, levins, Nissan pulsars from '90 on (+ civics and integras :oops: )
Chevettes are 4x100 aswell.
Ok people, two questions:
1, Should we add new cars to the list? Generally I would say no, but certain cars may be useful for example putting turbo skyline hubs onto your old datsun, but where do we draw the line?
2, Completely forgotten what I was going to ask, il post later when I remember it :?
VOLVO
340, 360, 440, 460, 480 = 4 x 100
850 >93 = 4 x 108
T4, S40, V40 = 4 x 114.3
240, 740, 760, 780, 940, 960 >94 = 5 x 108
850 93>, 960 94>, C70, S70, V70, S90, V90, T5, T5-R = 5 x 108
Mitsubishi
All 4 stud RWD Mitsubishis are 4x114.3mm
All FWD 4 stud Mitsubishis are 4x114.3mm up til around 1991.
All 5 stud Mitsubishis are 5x114.3mm.
