SOHC Posted December 4, 2022 Share Posted December 4, 2022 Can waka transport revoke someones WOF? I see stuff is reporting busted wof shops and peoples wofs gettig canceled Quote Link to comment Share on other sites More sharing options...
Nominal Posted December 4, 2022 Share Posted December 4, 2022 Sure can Quote Link to comment Share on other sites More sharing options...
tortron Posted December 4, 2022 Share Posted December 4, 2022 Yes. Already like 10 thousand or something outrageous between Barry's shop in Takanini and that one 1 Quote Link to comment Share on other sites More sharing options...
SOHC Posted December 4, 2022 Share Posted December 4, 2022 I thought they were just contacting the owners and recommending they get a check done somewhere elce? Quote Link to comment Share on other sites More sharing options...
Nominal Posted December 4, 2022 Share Posted December 4, 2022 5 minutes ago, SOHC said: I thought they were just contacting the owners and recommending they get a check done somewhere elce? Quote Link to comment Share on other sites More sharing options...
SOHC Posted December 4, 2022 Share Posted December 4, 2022 8 minutes ago, Nominal said: But that's what stuff sed Quote Link to comment Share on other sites More sharing options...
cletus Posted December 4, 2022 Share Posted December 4, 2022 On 25/11/2022 at 22:37, keltik said: Custom strut top mounts for a vehicle with double wishbone suspension - how hard to get that certified? What sort of car? If it's just making a top mount to bolt in a strut that's the same sort of configuration , should be straight forward Quote Link to comment Share on other sites More sharing options...
cletus Posted December 4, 2022 Share Posted December 4, 2022 20 minutes ago, SOHC said: I thought they were just contacting the owners and recommending they get a check done somewhere elce? That has happened in the past, my grandad got sent a voucher to get a new wof check done by vtnz when his local testing station got in the poop Quote Link to comment Share on other sites More sharing options...
cletus Posted December 4, 2022 Share Posted December 4, 2022 Vtnz are the gold standard in vehicle inspection! missed the rust and the fact that the shocks had lost all their damping juices 6 2 1 Quote Link to comment Share on other sites More sharing options...
keltik Posted December 4, 2022 Share Posted December 4, 2022 5 minutes ago, cletus said: What sort of car? If it's just making a top mount to bolt in a strut that's the same sort of configuration , should be straight forward If I was to swap the jag to S-Type coilover shocks. Changing from air struts to coil spring. The knuckle end of the shock is the same but pcd on the top hat is different. Quote Link to comment Share on other sites More sharing options...
cletus Posted December 4, 2022 Share Posted December 4, 2022 Yep that would be fine as long as it's made from a suitable material, has the right design etc (Things like a means of spring location if the spring sits directly on the mount, stuff like that) Quote Link to comment Share on other sites More sharing options...
Nominal Posted December 4, 2022 Share Posted December 4, 2022 38 minutes ago, SOHC said: But that's what stuff sed Invalid/revoked means cancelled, so what's your question? Quote Link to comment Share on other sites More sharing options...
Corbie Posted December 4, 2022 Share Posted December 4, 2022 Even Stuff gets it right sometimes. 1 4 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted December 4, 2022 Share Posted December 4, 2022 Haha, probably hard to stuff up reporting on a press release. Anyway, under Land Transport Rule Vehicle Standards Compliance 2002 Rule 35001/2002 As at 1 April 2022 They have the ability to do this Quote Link to comment Share on other sites More sharing options...
SOHC Posted December 4, 2022 Share Posted December 4, 2022 11 minutes ago, Nominal said: Invalid/revoked means cancelled, so what's your question? Has stuff got it correct? Quote Link to comment Share on other sites More sharing options...
Nominal Posted December 4, 2022 Share Posted December 4, 2022 18 minutes ago, SOHC said: Has stuff got it correct? Yes https://www.nzta.govt.nz/media-releases/waka-kotahi-suspends-authority-of-auckland-wof-inspection-site-owners-urged-to-have-vehicles-rechecked-urgently/ 1 Quote Link to comment Share on other sites More sharing options...
Popular Post SOHC Posted December 5, 2022 Popular Post Share Posted December 5, 2022 I got a wof for my mums car from him, not much brake checking went on, I wrote a letter to Waka transport and used google translate to translate it into maori and sent it to them 4 2 10 Quote Link to comment Share on other sites More sharing options...
SOHC Posted December 5, 2022 Share Posted December 5, 2022 I wrote a letter asking if the wof was still valid not to dob him in Quote Link to comment Share on other sites More sharing options...
Early jap nuter Posted December 5, 2022 Share Posted December 5, 2022 3 minutes ago, SOHC said: I wrote a letter asking if the wof was still valid not to dob him in If they pull the wof they send you a letter. My sister got hers pulled, she just had to go get another one from someone else 1 1 Quote Link to comment Share on other sites More sharing options...
ajg193 Posted December 5, 2022 Share Posted December 5, 2022 9 hours ago, cletus said: Vtnz are the gold standard in vehicle inspection! missed the rust and the fact that the shocks had lost all their damping juices To be fair, if the suspension is modified and needs a cert why should they even continue looking at the suspension and surrounding structure? The cert guy will have to do that anyway. No point having double redundancy Quote Link to comment Share on other sites More sharing options...
