All Activity
- Past hour
Daves new school holden shambles. (And finally a Turbo)
@shrike I've copied over timing and fuel tables from a supercharged Map so its able to read positive pressure and put in the specs for injectors and other settings into the ADX. Hence it runs OK it doesn't knock misfire or anything. I've only driven it fairly gently so far to get it up to temp and into closed loop to check for oil leaks etc....... and maybe to make a few dose sounds for motivational purposes only.- 368 replies
- 2
- not as good as a barra
- ecoboost
(and 1 more)
Tagged with:
Roman replied to Muncie's topic in Other Projects
High Performance Academy is the way to go! So much good stuff and some great courses. Yeah factory ECUs can be tricky to tune compared to aftermarket stuff, depending on what information it actually gives you. I dont think myself or KPR actually have any useful experience tuning factory ECUs. Ultimately it's all just about getting the basics right. Get the fuel right, get the ignition right, then you're golden. But if there's limited datalogging or visibility of how/why the factory ECU does things then it can be tricky to know how to head in the right direction. Good luck!- 368 replies
- ecoboost
(and 1 more)
Tagged with:
shrike replied to Muncie's topic in Other Projects
Im sure @Roman & @kpr plus a host of other people on here will be able to give some pointers, sorry guys for volunteering your help Maybe throw up some datalogs/maps/graphs ? You already know this and its teaching you to suck eggs, but I'd say once you sort your ICAV/Vac leak & know your at a good base things should be easier from there, is it worth doing a smoke test? Think we talked about this previously but your still using the factory basemap (tweaked for different injectors and airflow adjustments) off boost right? and without the turbo hooked up it was running fine right? Can always pull the spring out the wastegate to remove boost from the equation to get things dialed in and then go from there Loving the progress and its very exciting- 368 replies
- 1
- ecoboost
(and 1 more)
Tagged with:
- Today
yoeddynz replied to yoeddynz's topic in Project Discussion
Yep for sure. It's getting close! All the little bits left to assemble, modify or build now are fun easy ones too. -
Turned to High Performance Academy for some real information on tuning. The Facebook group that has been useful up till this point has now turned to shit posts about my spark plug leads not been correct or how my wastegate won't work etc. Thanks oldschool.co.nz for hosting this project without the haters. Anyway Time for some data acquisition and fixing annoying things like rattles.- 368 replies
- 4
- ecoboost
(and 1 more)
Tagged with:
timrod joined the community
VitesseEFI replied to yoeddynz's topic in Project Discussion
Anticipation for first start in the car and first drive are building! The excitement ! -
I changed the ignition coil to see if it had any effect. The one which was in the car looks to have been made in 1995. If it is a Lucas DLB198 coil as suggested by its mounting bracket, its secondary resistance was measuring below spec. The new coil is branded "Flame-Thrower", which sold me on it immediately. This should be its theme song. Anyway, it didn't make any difference. The car's intermittent stumbling idle remains, and its misfiring near peak power seems to be getting worse. I read a bunch of forum threads of other people who have tried to crack the bad idle problem with their AJ6 or AJ16 (the revised version of the same motor), and most people seem to test and change a bunch of stuff then give up (the threads just stop). I did find one thread where someone actually fixed it, and the problem in that case turned out to be several exhaust valves which weren't sealing well. The guy took the head off and got the valves reseated or reground or whatever, and then the car idled properly. So.... I wonder if I could have some partially burnt valves or weak valve springs or worn cam lobes or something. I did another compression test today and got similar slightly-too-high readings (190, 183, 190, 180, 188 and 190psi) to the last compression test. Might be my gauge. The spark plugs looked fine. I gapped them down to factory spec, no improvement. I have recently acquired a detailed factory document all about the engine management on the later 4.0 AJ6 which gained oxygen sensors (so many variants of this motor, grrr). The guide has taught me that my fuel tank vacuum pressure relief valve has no vacuum line connected to it: I don't know why there would be a valve if there's no vacuum line for it. Maybe it's for other markets / I hope the vacuum line isn't sitting somewhere disconnected and leaking air. This new guide has given me a thousand things to check. For example, the ECU controls ignition timing and fuel mixture based on airflow and crank position, with a compensation factor for throttle position and coolant temp and air temp, and now I have a bunch of expected voltages and resistances and oscilloscope waveforms for all of this. I just need the motivation to spend weekends chasing my tail.
- 35 replies
- 6
87creepin started following Tai's 1976 Chrysler/Mitsubishi Galant Goon
A narrower tyre will make it tip into a corner quicker. Wether it's enough to be noticeable is probably not. New tyres a gr9 . Even the cheap battleaxes I put on my fj1200 were pretty lush once the shine was off them.
New S23 on its bum @36000km It amazes me how much of a difference new tyres make to a bike, doing the front one last year made it handle much nicer, now doing the rear has improved it a lot again. This tyre is the same size but appears slightly narrower which may influence it slightly? I dunno. Last time I rode it I had a couple of "wtf are you doing, have you forgotten how to go around a corner, you cabbage?" whereas this time I did not accuse myself of being any sort of vegetable
HumberSS's Datsun 240c coupe of irrationality yarns
HumberSS replied to HumberSS's topic in Project Discussion
Looks like I may have found a home for it in a fellow OS garage, so hopefully the thread will continue! Unfortunately a basic tidy up of rust isn't really possible, intention was never a full Resto but there's a fair swag of metal work to get through, which I may still be involved with... Will keep you posted -
Otodat replied to HumberSS's topic in Project Discussion
I hope you keep it, even just do a basic tidy up on the rust etc, have it running and driving. But understandable, house is probably more important. -
I found a 185 at zebra so I bought a few bits and bobs. I bought another drivers seat for 40 bux and used some of the fabric to re-cover the drivers side arm rest thing. It came out pretty good, time will tell how much comes unglued and I have to fix it up but it's pretty ace at the moment. The other thing I did with the spare seat was cut the mounts off and put some spacers in to raise the seat up a bit to make the driving position better for normal height people like me. No pix of that because I didn't take any.
I am still torn between original colourscheme or 'blue psycho' bodywork with black vinyl roof and gt style blackouts along the bottom.
Finished pulling out the rest of the pillar trims and seatbelts. Fired up the cup brush and stripped back the last of the insulation under the dash and buffed back the passengers floor..... Before After Still have more to go but the brush is clogged with gum so can use that as todays excuse to stop.
- Yesterday
Have driven this around for about an hour few rattles from exhaust needs lots more mounts who knew 3.5" exhausts were really heavy, go figure.... easy fix though it's quiet enough wastegate has a bark to it. Appears PCV system will need an upgrade its struggling a bit few more oil leaks than normal. Catch can incoming. 2000rpm idle is a bit annoying either I have a vacuum leak or a dead IAC valve, trying a new IAC as current isn't right it's gm but never has been 100% so bought the expensive commodore specific one. If it's a vacuum leak that might be trickier. All in all no check engine lights gets up and boogies seems pretty happy has lightest wastegate spring I have so should be about 4psi. Time to figure out wideband and do road tuning once the niggles are done. Think the stock bumper is perfect BTW.- 368 replies
- 6
- ecoboost
(and 1 more)
Tagged with:
87Creep's 90s projects: AE101, SW20, GF8 WRX
87creepin replied to 87creepin's topic in Other Projects
Priming finished. Apart from the fuel flap but that doesn’t matter too much. Shitty primer was fun, created a bit of extra work but got it done Will let it cure and start sanding shortly. also painted weather strips, door handles, grille and rear garnish 2k matty B. Tried out wiper blade top bits too because faded but the paint reacted. went pretty good except a bug landed in a door handle and on one handle I got it a bit thin on top. Will have to invest in some fly spray. And also cos I’m not used to playing with the fan pattern. Iirc if I narrow down the fan, then I should lower the air pressure to compensate. also my rear garnish should’ve been primed first really but I would like one that has all the lights rather than a plain plastic cover. So not too bothered if it’s not 100% perfect. still got some other stuff like mirrors and other trim to Matty B. -
Tiger Tamers 1964 Hillman Minx Project
Tiger Tamer replied to Tiger Tamer's topic in Projects and Build Ups
While waiting on the new Super Pro suspension bushes to be put back into production I did some googling and found some in the UK which are now on their way. So, while waiting I decided to work on the brakes and replace all the hard lines with new. I bought a 12m roll of 3/16 tube and made-up new lines for the diff and the one from the MC to the distribution block them to the rear. Still have the fronts to do. I went flash and bought a new fancy tube flare tool which is now my new best friend. How easily it makes perfect single, bubble and double flares is super cool. I striped down the MC to see how the bore looked. At first inspection it didn't look well. It was quite rusty around the circlip end so I thought it maybe junk. Though once apart the bore was clean, so I will get some new seals for it. I will give the outside a couple of coats of por15 if a test on some is resistant to brake fluid.- 77 replies
- 11
Yoeddynzs 1965 Hillman imp 911 build. Flat six in....
yoeddynz replied to yoeddynz's topic in Projects and Build Ups
Sealing up the cut out tunnel top and under the rear seat was to be the next stage but first I decided to make some new beefed up engine mounts. The originals I had made from a mixture of 3 and 4mm steel were probably fine but i wanted to move the crossmember backwards away from the engine for a little bit more clearance. So while I was at it I thought it best to use thicker steel. To start with I made a jig based off the original mounts. Now there were datum points to build to, allowing for extra clearance while I was at it. I popped into G3 engineering where I get a lot of my steel offcuts from and grabbed some 4mm plate. I had 5mm at home for the main backing plates. Used the hefty steel bender.. Tigged the majority of the welds except the inside ones I couldn't reach which got mig welded. Plenty of heat. These wont fail. Added gussets just to be sure... The new mounts now set the crossmember further back by about 5mm. I could now drill the holes through the chassis rails. I made up a new pair of backing plates with extra holes and captive nuts. The plates extend further forwards to line up with the holes that Datsun crossmember bolts through. I can now easily bolt in either crossmember. I was super happy to discover that due to the flat six being only 3 cylinders long I have enough room to pull the engine back so its gearbox bobbins are clear of the gearbox crossmember. I can then raise the car up and away from the engine, all without having to remove the rear bumper and valance. Now the engine was in its final position I could replace the lid on the tunnel, now 50mm higher. I started with this bit and had to cut out a section to allow for access to the toyota spec gearbox speedo sensor plug... Making sure there was ample clearance all round so the box cant knock the tinwork on rough roads I proceeded to box the tunnel back in... Kneeling down on folded up bits of foam and towels was my home for the next few hours... Cardboard trials, then steel, cut, trim, tack, check, weld... Finally boxed in. Another access hole let in so I can get to the top universal joint and lube the gearbox selector shaft. It was a very good part of the build to finish. Seeing it all sealed up, strong again. I have yet to check the rear seat squab but I feel confident it'll fit with some modifications to the wire frame within. Underneath looked neat... Hannah has now painted the tunnel inside and out with Epoxy paint. After I have finished any other little fabrication bits or hole filling/drilling in the engine bay I'll give it a flick of blue paint (hopefully not making everything else in the workshop blue like the first time) Now it was onto the rear suspension arms. I am using the set that came on the green imp 2. Surface rust needed wire brushing off outside... Painted with KBS rust seal (Aussie por 15 clone).. Another bit I could have got away without doing but I thought best to make while I'm under the car was this brace... Pulling up tight to the floor via spreader plates under the seat base... I have added it to brace the floor halves inline to help keep the suspension mounts inline during hard corning. Like said, I'm not sure if its essential but it might just help avoid any weird effects like rear steering. I know its a bit ugly but hey, at least its hidden under the car. On the subject of bracing I also made this little brace... To help stiffen the top of the tunnel near the shifter so it doesn't flex. again, not really needed but I do want a really positive shift action without an excess movement. So now my next job is to run out the brake/clutch/fuel pipes back along the tunnel and then reassemble the rear suspension so I can setup the handbrake cables. I'll have to paint some bits too. The crossmember, mounts, fuel tank etc. The work area looks like this with bits everywhere... In other news we had these treats turn up in the mail, a surprise present from my brother in Wales... He had gone to a big collectables/toy and model show local to him where he then spent a good amount of time asking at the various collectors stalls for any Hillman Imp models and found what is quite a rare and sought after Dinky toy car... Plus a cool little Imp police car .. They turned up in the post yesterday as a surprise and made our evening. Very cool. Thanks bro!- 101 replies
- 40
Cam is going strong, 1500kms of ripping round, haven't had any issues to report. Did a decent loop today, about 250kms of varying road type. Next step is to CC the pistons and the head again to up the CR a bit, slightly more boggy down low and I think upping the CR a bit will help this. ALSO. SSR MK2's are back, need to be painted. These were fully intended for the Wagon build, but with the rust progress not happening - I think these can do on the Sedan for now. Watch this space
Oh yeah it goes hard! Got a go pro vid of first drive will edit get that up.- 368 replies
- 4
- ecoboost
(and 1 more)
Tagged with:
Finished up the intercooler pipes managed to make the passengers side one piece really happy with how it turned out. Everything done by eye only welded one pipe on backwards.- 368 replies
- 5
- ecoboost
(and 1 more)
Tagged with:
