rot808 Posted December 9, 2011 Share Posted December 9, 2011 jesus fucking fuck, plus 10 more fucks those tyres, dat villiers, all round mindblowing Quote Link to comment Share on other sites More sharing options...
Raizer Posted December 10, 2011 Share Posted December 10, 2011 Fucking awesome man!! Lol so awesome I think I am going to have to put my 2 new Villiers 97's on something similar! Are you sure yours is a 97cc? Thought the slant head ones are like 73cc. Quote Link to comment Share on other sites More sharing options...
kicker Posted December 10, 2011 Author Share Posted December 10, 2011 Not 100% but this is the mower it came off http://www.oldlawnmowerclub.co.uk/moms/mom30-aks.htm Quote Link to comment Share on other sites More sharing options...
Steelies Posted December 11, 2011 Share Posted December 11, 2011 super. so choice to see in real life. cant wait to se you on it racing Quote Link to comment Share on other sites More sharing options...
kicker Posted December 12, 2011 Author Share Posted December 12, 2011 Am gonna try and use the sweet mower handle bars Now have fuel hose and throttle set up and the engine is running well but there is something missing off the throttle cable causing too much slack making it hard to keep constant revs. Time to go rummage in the garage for something to fix it. Quote Link to comment Share on other sites More sharing options...
lou Posted December 12, 2011 Share Posted December 12, 2011 This thing makes me wanna buy a welder. And I dont even know how to use one. Quote Link to comment Share on other sites More sharing options...
Chris.QCR Posted December 12, 2011 Share Posted December 12, 2011 Looking good bro! Quote Link to comment Share on other sites More sharing options...
tortron Posted December 12, 2011 Share Posted December 12, 2011 might i suggest mounting those handlebars down on the forks makes for super sweet 50cc gp racer stance Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted December 12, 2011 Share Posted December 12, 2011 making it hard to keep constant revs. Time ] only need idle and full noise on board tracker broooeee Quote Link to comment Share on other sites More sharing options...
BlownCorona Posted December 12, 2011 Share Posted December 12, 2011 making it hard to keep constant revs. Time ] only need full noise on board tracker broooeee Quote Link to comment Share on other sites More sharing options...
kicker Posted December 14, 2011 Author Share Posted December 14, 2011 I've been procrastinating with sorting getting drive to the rear wheel So here's a cool operating manual instead. Quote Link to comment Share on other sites More sharing options...
DodgySam Posted December 14, 2011 Share Posted December 14, 2011 I've been procrastinating with sorting getting drive to the rear wheel Im in the exact same boat boe. Think I have made up my mind now and am making headway to getting it done. I really just need to decide what hubs to run in the wheels and get the damn things built. Quote Link to comment Share on other sites More sharing options...
kicker Posted December 15, 2011 Author Share Posted December 15, 2011 Question: Can you get belt pulleys that fit onto a square taper bicycle bottom bracket? Quote Link to comment Share on other sites More sharing options...
DodgySam Posted December 15, 2011 Share Posted December 15, 2011 um...you could probably get a belt drive kit from someone for a square drive BB. They are notoriously weak tho and tend to flog out fairly quickly as they are only made from aluminium. If you wanna go down that route id suggest getting an industrial pulley machined to fit a square taper BB axle. Would be pricey tho. Quote Link to comment Share on other sites More sharing options...
CaMpylobacter Posted December 15, 2011 Share Posted December 15, 2011 good man on a lathe could spin you up a new shaft to run in bottom bracket that'd take whatever kind of pulley you please Quote Link to comment Share on other sites More sharing options...
Goat Posted December 15, 2011 Share Posted December 15, 2011 Your mum takes any pully she pleases... Tack a Bmx rim to your Bmx rim. And Use that as a pully. Xzibit spec Quote Link to comment Share on other sites More sharing options...
EURON8 Posted December 15, 2011 Share Posted December 15, 2011 I have a request sir, Can you please sit on this on somewhat riding position and take side on photo. I sat on mine it it seems to small. Need to get it fully weldied up and rolling so i can test properly Quote Link to comment Share on other sites More sharing options...
kicker Posted December 15, 2011 Author Share Posted December 15, 2011 A custom shaft may be the way to go, modifying the existing axle will probably be more work than knocking up a new one. I could then use some decent bearings which would help the double pulley (all the way) I was thinking of using. Quote Link to comment Share on other sites More sharing options...
kicker Posted December 15, 2011 Author Share Posted December 15, 2011 I have a request sir,Can you please sit on this on somewhat riding position and take side on photo. I sat on mine it it seems to small. Need to get it fully weldied up and rolling so i can test properly I had a similar dilemma, I originally planned to make it longer but I'm glad I didn't now. Will get a pic for you on Sat Quote Link to comment Share on other sites More sharing options...
Steelies Posted December 15, 2011 Share Posted December 15, 2011 square BB or BMX crank spindle would still be the go i reckon. bmx BB will have sealed bearings, plus having factory alignment for chain/belt to rear wheel. fixing pulleys and sprockets to a plain shaft could be a bitch unless you have big faith in grub screws, lock nuts, pins, or have broaching gear to make a keyway.. chop crank arms and turn down to a useable hub to attach gears to? Quote Link to comment Share on other sites More sharing options...
