Tomble's adorable go cart / distraction / Alto Works
8 hours ago, yoeddynz said:
Have your looked under the sofa or behind the fridge? That's where stuff often goes to hide.
I found myself literally plucking my garage trash bin one item at a time and running a magnet through the very full shop vac bag v.v
It's super annoying. This $4 piece of metal that I totally remember holding at one point has gone walkies, yet I made very sure that everything Alto has a defined place in the garage. I've exhausted all the normal places, the dumb places, the super dumb places, the "out there" places, and now it's in "a mouse made away with it" or "it got knocked off the bench and lodged in someone's shoe grooves" levels of dumb places it could be.
  • Haha 2
  • Replies 88
23 hours ago, Doug Hill said:
You can make a new woodruff key yourself with a little bit of key stock. If you send me the width/length I may have a bit here I can send
Took the best caliper measurements I could to produce the shape in cad.
The ends may or may not be boxed or the curves might continue all the way to the end, I don't recall, but it has a long flat base rather than a curve all the way along its length. I took rough measurements of where the curve finishes and becomes flat at each end.
edit: based on the shape I think it's more likely to be a simple square key actually, that doesn't sit in the curved parts of the keyway... maybe doesn't have rounded ends at all?
edit 2: the part number comes up with some images, seems square
edit 3: yeah I'm a dummy, should have just checked the manual to confirm its shape
I contacted Jesse Streeter and because of the japanese holiday week it's going to be a month :(.
Tomorrow I'm going to hit up Suzuki ATV wreckers and maybe I'll get lucky.
21 hours ago, tomble said:
<3 I'll get some measurements in the morning. I'll also call around on Monday to see if any motorcycle shops or ATV wreckers or whatever have one available. In the mean time I've pushed the button to get one from Japan (right as we enter their holiday week...)
Looks pretty simple to make, ive made them for other applications with a grinder and a mill in the past
One time I also lost one I put in a very special place, and searched the entire garage one item at a time
I got a new one
When I went to install it, the old one was in the way....
I had checked that too, so I'm obviously a target of gangstalking because it was impossible
Anyway
This is more like 4.7, so maybe too big?
I got it from a local bearing/engineering supplier, they have a range of lengths in different sizes
  • Haha 2
15 minutes ago, shrike said:
Did you end up going with a turbo upgrade in the end?
It'll happen but not until more mortgage is paid off ....
4 hours ago, yoeddynz said:
I had a spare bolt but I was getting so annoyed at not being able to find this one. It just had to be found. I called upon hannah to help look. Vacuumed under benches, shone lights everywhere. Fuck. How could it have gone far.
That's exactly how I feel. Girlface is trying to get me to let it go but IT MUST BE FOUND. Its absence is an affront to reality.
  • Haha 2
