dmulally Posted October 4, 2023 Share Posted October 4, 2023 6 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted October 4, 2023 Share Posted October 4, 2023 3 Quote Link to comment Share on other sites More sharing options...
dmulally Posted October 17, 2023 Share Posted October 17, 2023 Hoping the brains trust can help me. The only air filters I can find are pit bike ones on a 45 degree angle. It is 60mm id. I could possibly get a 45 degree reducer to 50mm and then use some VW beetle aftermarket chrome ones. I do have one ramflo but it wont fit without some pipe cut at an angle between. Open to ideas. Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted October 17, 2023 Share Posted October 17, 2023 Ramflo is at least an extra 20 bhp plus the everyday excitement of if it might do this... 1 Quote Link to comment Share on other sites More sharing options...
dmulally Posted October 18, 2023 Share Posted October 18, 2023 6 hours ago, yoeddynz said: Ramflo is at least an extra 20 bhp plus the everyday excitement of if it might do this... So frustrating that I have 3 ramflo filters but all three a different. I'm not at a stage of my life where I can use miss matching air filters. Even Imp owners have some standards. 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted October 18, 2023 Share Posted October 18, 2023 Fit a roof scoop and pipe it down? 1 2 Quote Link to comment Share on other sites More sharing options...
yoeddynz Posted October 27, 2023 Share Posted October 27, 2023 So cool. Congrats on first start. 2 Quote Link to comment Share on other sites More sharing options...
dmulally Posted November 12, 2023 Share Posted November 12, 2023 So I bought a fuse/relay box off Amazon. Looking at the instructions I'm a little lost. It happens. Can anybody smarter than me (that's all of you) please let me know which of the yellow and blue wires go to the fan/pump/whatever? Quote Link to comment Share on other sites More sharing options...
Nominal Posted November 12, 2023 Share Posted November 12, 2023 For each set of white/blue/yellow (I assume they are bundled together), Then if you want a 30A fused fan switch relay (#2 as per pic although you could change the fuses) Connect the fan switch/temp switch to supply + 12V to the white wire of the bundle when you want the fan on, and the fan motor to the yellow wire of the bundle. Don't use the blue wire, just wrap the end with tape or something so you don't get a short. Does that make sense? Quote Link to comment Share on other sites More sharing options...
dmulally Posted November 12, 2023 Share Posted November 12, 2023 Yep perfect sense. Thanks. No idea what that relay 1 does. Has a wire less and is a little different to the others. Quote Link to comment Share on other sites More sharing options...
fuzzy-hair-man Posted November 18, 2023 Share Posted November 18, 2023 The blue wires are normally closed, (on when the switch is off, off when the switch is on) you could use them for fail safe things like if the sensor or switch for a temp sensor were to fail the pump or fan comes on as default, although most sensors would be normally open, so you'd need to be specific about using the blue. Googling the relay number it says its a accessories relay.. but only giving 5A to accessories seems problematic.. I know you could change it. Maybe one of the red positives is switched and the other is permanently live? 1 Quote Link to comment Share on other sites More sharing options...
dmulally Posted November 20, 2023 Share Posted November 20, 2023 On 18/11/2023 at 22:46, fuzzy-hair-man said: The blue wires are normally closed, (on when the switch is off, off when the switch is on) you could use them for fail safe things like if the sensor or switch for a temp sensor were to fail the pump or fan comes on as default, although most sensors would be normally open, so you'd need to be specific about using the blue. Googling the relay number it says its a accessories relay.. but only giving 5A to accessories seems problematic.. I know you could change it. Maybe one of the red positives is switched and the other is permanently live? Im just about to test the red wires now. I hooked them both up to the beefy red wire from the engine bay but I still need power to the other side of the switches on the dash. So either that number 1 relay will provide it if it's always hot or one of the red wires will have to come off. Stand by. Quote Link to comment Share on other sites More sharing options...
dmulally Posted November 20, 2023 Share Posted November 20, 2023 On 18/11/2023 at 22:46, fuzzy-hair-man said: The blue wires are normally closed, (on when the switch is off, off when the switch is on) you could use them for fail safe things like if the sensor or switch for a temp sensor were to fail the pump or fan comes on as default, although most sensors would be normally open, so you'd need to be specific about using the blue. Googling the relay number it says its a accessories relay.. but only giving 5A to accessories seems problematic.. I know you could change it. Maybe one of the red positives is switched and the other is permanently live? Right so the second red wire will go to the switches. With both connected to the battery the blue wires are off. Ill tape those off so they dont get into mischief. Few more things to test but I dont mind wiring. Quote Link to comment Share on other sites More sharing options...
Nominal Posted December 5, 2023 Share Posted December 5, 2023 4BT swap should sort out that dieseling issue. 4 Quote Link to comment Share on other sites More sharing options...
dmulally Posted December 6, 2023 Share Posted December 6, 2023 4 hours ago, Nominal said: 4BT swap should sort out that dieseling issue. I have a 4BE1 ready to go into it when I knock a couple of projects off the list first. I'm reluctant to make a finished project an unfinished project. 1 Quote Link to comment Share on other sites More sharing options...
Nominal Posted December 6, 2023 Share Posted December 6, 2023 Sensible chap. 1 1 Quote Link to comment Share on other sites More sharing options...
dmulally Posted December 12, 2023 Share Posted December 12, 2023 Hi All, Does anybody know if I can take t piece and stick it in the hose line for vacuum advance to the dizzy in order to plumb in a smiths vacuum gauge? Quote Link to comment Share on other sites More sharing options...
locost_bryan Posted December 13, 2023 Share Posted December 13, 2023 Smiths fitting instructions say no, needs a fitting on the manifold. 1 Quote Link to comment Share on other sites More sharing options...
tortron Posted December 13, 2023 Share Posted December 13, 2023 Yeah I tried like that inline and was no good. Tapped onto under carb and worked fine. 1 Quote Link to comment Share on other sites More sharing options...
dmulally Posted December 13, 2023 Share Posted December 13, 2023 Ta. I have plenty of space to tap into it so it should be sweet. Cheers. Quote Link to comment Share on other sites More sharing options...
