fuzzy-hair-man
Local Area
Outside NZ
fuzzy-hair-man's Achievements
Advanced Member (3/5)
62
Did you consider a Nissan Leaf gearbox / motor / inverter stack? The power figures are about the same. I can understand not going the Tesla SDU as the power is a bit ridiculous (but they seem to package well) but the Leaf seems a reasonable option? If set on the hyper9 is the Leaf gearbox an option?
I cropped some of my original photos of the subframe to get them small enough to upload. As you can see I've cut the sides out of the original subframe as the engine and box were wider than would fit. If you're able to move the gearbox further to the driver's side you might be able to keep the sides. Most / all car engine conversions I've seen require this much modification to the subframe. The rear of the gearbox sits about 10mm from the steering rack, the driveshaft allignment is pretty decent still a bit forward but I've seen much worse that still works.
Here's a pretty poor build thread, but it's currently down for php vulnerability reasons. Unless you can make the gearbox more central than mine you'd need to cut out the side of the subframe. More central would be good though as it'd improve driveshaft angles and clearance for CVs. https://www.theminiforum.co.uk/forums/topic/253043-spot-the-micra-mini/&ved=2ahUKEwjAur60ys2XAxU4r1YBHdifCzYQFnoECB8QAQ&usg=AOvVaw0hXT58LZlUQNcn350xdVBv I tried uploading photos but they were all too big. I think the logic that the left pontoon didn't have the structure so the right pontoon doesn't need it holds. I also have a moke I'm rebuilding so know there's precious little structure anyway, the brackets to hold the cylindrical fuel tank in mine provided some structure. The battery boxes themselves could provide any missing structure in my opinion. What about under the rear subframe? There's a fair load of space under there for batteries with no spare wheel well.
I like the idea of a single speed gearbox but may not be an option. I've a nissan micra in a Mini, these fit without choping the wings but did have to cut the subframe some at the rear to bring the diff back. I think the engine and box are generally smaller than the swift so may be worth a look. An EV shouldn't need the clutch so it may be possible to chop of at least some of the bellhousing and bolt directly to the gearbox saving some length.
Roman's 4GR V6 Carina discussion thread
fuzzy-hair-man replied to Roman's topic in Project Discussion
Have you seen these guys channel / videos? The videos I've watch were dealing with issues such as the ones you were asking, minimum port cross section area, port taper, average port speed, maximum port speed and targeting specific rpm. Seems quite generous with the information. https://youtube.com/@bainracing?si=cn_SA_LrSUm5Psdb -
I just finished watching a might car mods where they put a Z pipe in to improve the sound, have you seen these / considered them? Looked at some prices and they made my eyes water, but could be worth copying the concept and seeing if your 3D printing comes out cheaper? https://lpsfab.com/products/formula-z-performance-1-7-8-z-pipe -
fuzzy-hair-man replied to yoeddynz's topic in Project Discussion
I tried to find some aero results and found some photos of wind tunnel wool tufting, but I think the wind tunnel was off, so not valid. I say think because the A pillar is probably sharply angled enough that the majority of the side is separated flow, could it be sucking fumes from the exhaust to the open windows? I seem to remember you had a centre exit, was it any better? What about tipped down exhaust tips aiming the exhaust into the air flowing under the car rather than the wake from tyres and the side that might be eddying up? -
Have you seen this? X vrs Y vrs H vrs twin on a Ferrari V12, with 6 into 1 headers and 3D printed merge and stepped headers etc: Also nerdy sound graphs... https://youtu.be/mU3n_j_H8uQ?si=Izb2vKBx8q0qNDls -
Poll MRT1TRD’s engine conversion or originality
fuzzy-hair-man replied to MRT1TRD's topic in Project Discussion
The BMC B series was copied by Datsun Nissan in the A series so there could be a development line to go down? I've thought about a donor for datsun 1200s, and apart from the sr20s ca18 etc I was wondering about Suzuki M series with a Jimny box, the transfer case on the Jimny is separate so no issues there and engine sizes from 1.3 to 1.8. Tuning parts are probably available as the Suzuki Swift uses the M16. The M might work for yours and allow capacity to grow in displacement. I haven't been able to see a plug and play loom for the M series which I find a little strange a I'd have thought worth the swift there'd be some demand... -
The following might be of some interest, not sure but skip to about 10mins. -
So a rwd diff mounted somewhere in front of the goldwing engine and gearbox right? Hence the lengthened driveshafts, curious he didn't show any of that bit, he might have thought that's where the criticism might come from? I wonder if there's a tiny driveshaft or a housing etc to mount the diff directly to the goldwing gearbox perhaps... Or some other trickery I haven't thought of... -
Good work with your new bushes! Putting the resin (the pot and possibly the part in the mould) under vacuum could also help degas the resin. Not exactly sure the best way to achieve it though. A vacuum tank for fibreglass, that's a bit of kit and kind of expensive.
My alternator is in a similar position but I integrated the belt roller into the same bracket, I also braced it to the lower row of 6mm bolts that hold on the upper timing chain cover. The image attached isn't the final version but it's all I can find, even with the current bracing at certain revs it jiggled around quite a bit in the dyno.
It's a 2GR and I'm not all that fussy about engine sounds but this sounds clean and F1 like @22.40: -
If your chosen wheels turn out too wide there's different width arch extension panels available that can be put on in place of the current ones. But really with all the weight so low, you don't need a wider track imo and I think the wider guards don't look as good. It's something I've learnt with the mini, more offset outwards increases the leverage the wheel has over the steering (scrub radius) making it torque steer more and wander with the road surface.
