  • Replies 58
On 05/04/2020 at 18:12, yetchh said:
How far did you strip it back? Got any pics?
Mostly to bare metal. Didn't get any pics of it just before paint unfortunately, here is about 90% stripped.
Mostly strip disc on the grinder. Used a wire brush attachment for the grinder and drill to get some of the bits round the seams. Manual sanding with 80 grit for the rest.
No worries mate, I'll probably have heaps of questions when it comes to reassembling it!
  • 8 months later...
  • 3 months later...
1 hour ago, moparmuppet said:
Looking good. What is the brand of epoxy primer you are brushing on? Looks plenty fine for underneath and no messy overspray is a win. Thanks.Vaughan
Thanks. I am using PPG Epotec 408 primer
What did you find out about belts on b pillar?
I'm about to take my mk3 for Revin and am worried about my belt mounts requiring cert.
Nothing concrete. I put a post on facebook and several others also had the bolt though the piller. I think it must have been an NZDM thing, hence it didn't make it into the workshop manuals.
Let me know how you get on please.
The bolt through the pillar is fairly common for the era. Shouldn't be a problem on a vehicle that is otherwise stock.
Regards from Cuba! I own a Ford Zephyr mk2 1957 and I am working as you to restore.
wonderful work you are doing! Congratulations.
Frank
Late to the party here re seat belts, I've had three Mk3's and they've all had different seat belt mountings. One was bolted through the pillar and two just had a 'captive' nut with a large washer inside the pillar that the belts were mounted too. Both methods were fairly common as far as I'm aware.
Late to the party here re seat belts as well but on early models, the bolt went right through while later models had a captive nut and a one piece chrome strip on the outside
On 15/12/2019 at 20:15, Benno said:
In more exciting news, I've got my hands on some triple carbs for it. Not sure what the condition of the SU's is like, but externally they look all good.
Hey @Benno what did you pay for those SU's? These triple zeniths have come up on the tard that I'm fairly keen on picking up. They're fairly pricey but then again they never come up.
Talked to zep (galeforce zephyrs) a while back and he reckoned the triple zeniths had more initial punch than su's but its a struggle to get an air filter to fit under the bonnet..
I paid $350 for them, manifold is homemade but should do the trick. I saw those, wee bit pricey but they're the first setup like that I have seen  up for sale so probably worth it.
A mate of mines dad said he went from twin zodiac zeniths to triple SUs back in the day and preferred the SUs.
Yeah there's the other triple on there that's homemade but it finishes before the other one so there's no back up haha..
I find there seems to be a distinct lack of information regarding the zephyr 6 engine, especially since gale force went under. I want to do some porting and upgrade pistons/valve train but there is zero information..
I've been finding the same thing, my head has already been ported and polished etc but I'm now unsure about the induction side of things. I've got an adapter for a Weber 36/36 for the original manifold but I wouldn't be able to run an air filter with it. I've been wondering about running a 350 Holley or perhaps a big side draught carby but it would probably mean a custom manifold and tbh I've no idea where to start as far as sussing what's suitable.
